[HMail Server] SMTP credentials transmitted unencrypted
eric_xtremax
Post by eric_xtremax » 2019-03-18 10:07
Our team is setup HMail server act as SMTP Relay in our internal infrastructure.
Currently, our security auditor is scanning our environment and found this vulnerability in our HMail server.
3.2.4. SMTP credentials transmitted unencrypted (smtp-plaintext-auth)
How I can fix this vulnerability? I think we already setup the server not to use plain authentication.
jim.bus
Re: [HMail Server] SMTP credentials transmitted unencrypted
Post by jim.bus » 2019-03-19 00:49
I definitely am not well versed in how hMailServer treats unencrypted authentication but being a novice I would I would check is to see if your server which relays through hMailServer specifies that hMailServer (the relaying server) requires authentication.
You should also check to see if your server relaying to hMailServer designates that the Relay should use connection security.
I would also check in hMailServer IP Ranges to see if you have indicated that Authentication is required for this action.
Post by mattg » 2019-03-19 02:05
In your hmailserver.ini
add this to the bottom
[settings]
DisableAUTHList=25
In hMailserver Admin GUI, set Port 587 to 'Require StartTLS' (Assuming that you have a valid cert installed)
Then restart the hMailserver.
**All of your mail clients will need to Authenticate over port 587 (not port 25), and must then use StartTLS
This 'vulnerability' is exactly the SMTP specification.
By doing the above steps you don't allow anyone to authenticate over port 25... at all...ever, but you still need port 25 open to receive mail from the world.
Whomever did the security audit should also have checked IMAP and POP3 ports, and you should (assuming that you have a valid cert installed) set those ports -110 and 143, to 'require StartTLS' as well.
You should also set port 25 to be 'StartTLS optional', encouraging as much secure traffic as you can.
Which database do you use? Some security auditors require encrypted connections to the database, and that can be a bit trickier, but not impossible to achieve.
FYI, since 1 Oct 2018, I've been solely TLSv1.2 on my hMailserver. I have two senders who struggle with that, one is the accountant of a business client, and I've been talking to his tech people (don't know that they are listening though), the second is the Australian Taxation Office server used to send newsletters; After it tries every hour for three days, it passes the newsletter message to another ATO server that sends the message first go - I've been in contact with them too. Everyone else sends without an encrypted connection if they can't negotiate my ciphers / security level.
eric_xtremax
Post by eric_xtremax » 2019-03-19 06:05
Thanks for the advise.
Let me try first in our environment.
Thank you
