hMailserver: Secure with letsencrypt SMTP SetUP - Trusted Cert Issue
abdrahim999
Post by abdrahim999 » 2019-03-12 00:25
I'm trying to configure hMailserver with a 3rd party SSL cert. I'v
1) Installed the SSL key & cert 2) Placed the hash named CA and intermediate in to the \externals\cs folder
Now, the connection between the mail client and the server is secure and works. The issue is that mail clients outlook, apple mail, others issue an untrusted cert warning.
I've followed several threads on the forums, but none seem to solve this problem
and i Want to Autoban some special spammer Chinese and Russian and north african 8)
Re: hMailserver: Secure with letsencrypt SMTP SetUP - Trusted Cert Issue
Post by Dravion » 2019-03-12 01:08
what
"3rd party SSL cert"
Post by mattg » 2019-03-12 01:31
abdrahim999 wrote:
2019-03-12 00:25
Why did you do that?
Use the chained cert instead of the cert that you have used
abdrahim999 wrote:
2019-03-12 00:25
...and i Want to Autoban some special spammer Chinese and Russian and north african
Do you have SpamAssassin set up?
You could also use zz.countries.nerd.dk as a DNS BL
abdrahim999
Post by abdrahim999 » 2019-05-11 13:57
let's encrypt
Post by RvdH » 2019-05-11 14:09
Post by mattg » 2019-05-12 00:29
abdrahim999 wrote:
2019-05-11 13:57
let's encrypt
2019-03-12 01:31
Post by Dravion » 2019-05-12 01:55
There are multiple variants to get your Certchain working.
1) Combine your SSL-Cert with Root or Intermediate
CA Cert (a SSL Certbundle).
2) Use a SSL Certstore -(a folder with all Trusted
Root CAs)
3) Or have an openssl.cnf while which points to
valid Root CA or Intermediate CA Certificate.
Shouldnt be necessary if all Certs are known
by your Mailprograms trusted CA.
Post by mattg » 2019-05-12 04:29
Letsencrypt typically send back two certs, one is the just the named cert, the other includes the trust
I think the OP just used the wrong one
