smtp relay AFTER direct delivery attempt
Giuseppe_R
Post by Giuseppe_R » 2019-02-25 20:46
Good evening,
I use hmail from a while, coming from Alt-N MDaemon on Windows Server.
My hMail is working pretty, but the feature that I can't find, is the ability to send out smtp mail using smart host **ONLY** after failed direct delivery attempt.
Thank you very much in advance for your replies.
Regards
mikedibella
Re: smtp relay AFTER direct delivery attempt
Post by mikedibella » 2019-02-25 22:11
I don't think hMailServer can do that, but you could host Microsoft SMTP Service on the same machine on a custom listening port and configure it to use your Smart Host, but check the box "Attempt direct delivery before sending to smart host". Then configure hMailServer to use this local MTA as it's Smart Host.
Post by jimimaseye » 2019-02-25 22:31
Should be simple enough (of top of my head).
Rule:
if delivery attempts > 1 then
Send using route .....
(Or something like that).
