MYsql DB installation
4evernoob
Post by 4evernoob » 2019-02-24 19:51
I installed the latest mysql db v8x and when I run the dbsetup I get this
Starting task...
Please wait while creating database...
Error:
The MySQL client (libmysql.dll, 32 bit) could not be loaded.
hMailServer needs this file to be able to connect to MySQL.
The MySQL client needs to be manually copied to the hMailServer Bin directory. The file is not included in the hMailServer installation.
Path: C:\Program Files (x86)\hMailServer\Bin\libmysql.dll
I have copied that dll from the mysql server directory but no joy.
Re: MYsql DB installation
Post by jimimaseye » 2019-02-24 21:38
viewtopic.php?f=10&t=33531
Post by mattg » 2019-02-25 00:54
You need to use the 32 bit dll, even for a 64 bit database
4evernoob
Post by 4evernoob » 2019-02-25 03:29
Thanks that got it. I used the LTS version and everything works.
Post by Dravion » 2019-02-26 12:42
Its not a Problem because hMailServers DDL and DML Queries are quite ANSI SQL 92 compliant.
The only permissions required are SELECT, INSERT, UPDATE and DELETE for everyday operations and DB Admin permissions if you want to update hMailServer.
Libmysql.dll 5.24+ (Connector/C) must be used which is ABI compatible with MariaDB 10.4+ and above.
You only run into trouble if you use a version 6.x of libmysql.dll because its ABI isnt binary compatible anymore.
