SMTP Relay - No mail servers could be found
NivekLR
Post by NivekLR » 2019-02-02 23:18
Hi everyone,
I've tried to use my gmail account as SMTP relay but the mail could not be sent to external addresses.
The error is this one :
But when I run a diagnostic test I have :
I have configured the Send mail as option on my gmail account.
Would anyone have an idea?
Kind regards,
Re: SMTP Relay - No mail servers could be found
Post by jimimaseye » 2019-02-02 23:29
run this and post the results: viewtopic.php?f=20&t=30914
Post by mattg » 2019-02-03 02:38
In your internal diagnostics you have masked the SMTP Relayer address used to test
If that was gmail's address you wouldn't need to do that.
What do you have in your SMTP relayer section?
jimimaseye's diagnostics script will show that, so I agree, run the diagnostics in the link provided please
Post by palinka » 2019-02-03 14:35
Gmail will only relay mail from the gmail account address unless you have a paid g-suite account. The only way to relay mail from addresses other than the single gmail account address you're using to setup the relay is to upgrade to paid g-suite AND follow the instructions below.
https://support.google.com/a/answer/2956491?hl=en
NivekLR
Post by NivekLR » 2019-02-03 15:40
Thank you for all your answers.
@jimimaseye - Here is the diag's result :
2019-02-03   Hmailserver: 5.6.7-B2427
DOMAINS
   "Domain1.com" - klxxxxxxxxxx.ovx               Enabled: True
                                                Private key: d:\wampserver\cert-auth\ca\intermediate\private\dkim.Domain1.com.pkey.pem
                                                Selector:    dkim
IP RANGES
IP: 127.0.0.1 - 127.0.0.1     Priority: 30     Name: My computer
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  6 Mins: 10   Plain Text:        False  Bind:
                     Port: 465                                           Loop limit:           5
                     Con. Sec.: SSL/TLS
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 5    Use SA score:        True
              Subject Text: "[SPAM]"
  Spam delete threshold: 8         Maximum message size: 2048
DNSBL ENTRIES:
   No 'enabled' entries
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: True
  Max Message Size: 26214
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   IMAP
       Certificate: D:\WAMPServer\cert-auth\ca\intermediate\certs\imap.Domain1.com.cert.pem
       Private key: D:\WAMPServer\cert-auth\ca\intermediate\private\imap.Domain1.com.pkey.pem
   POP
       Certificate: D:\WAMPServer\cert-auth\ca\intermediate\certs\pop.Domain1.com.cert.pem
       Private key: D:\WAMPServer\cert-auth\ca\intermediate\private\pop.Domain1.com.pkey.pem
   SMTP
       Certificate: D:\WAMPServer\cert-auth\ca\intermediate\certs\smtp.Domain1.com.cert.pem
       Private key: D:\WAMPServer\cert-auth\ca\intermediate\private\smtp.Domain1.com.pkey.pem
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: SMTP
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: IMAP
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: POP
  Paths:-
    Current:  D:\WAMPPlugins\hMailServer\Logs\hmailserver_2019-02-03.log
    Error:    D:\WAMPPlugins\hMailServer\Logs\ERROR_hmailserver_2019-02-03.log
    Event:    D:\WAMPPlugins\hMailServer\Logs\hmailserver_events.log - Not present
    Awstats:  D:\WAMPPlugins\hMailServer\Logs\hmailserver_awstats.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MySQL
Backup directory D:\WAMPBackup\hMailServer is writable.
There are no error logs in the log directory.
HMAILSERVER.INI
Program folder:  D:\WAMPPlugins\hMailServer\
Database folder:
Data folder:     D:\WAMPPlugins\hMailServer\Data
Log folder:      D:\WAMPPlugins\hMailServer\Logs
Temp folder:     D:\WAMPPlugins\hMailServer\Temp
Event folder:    D:\WAMPPlugins\hMailServer\Events
Type=              MYSQL
Username=          klr-mail
Port=              3306
Server=            localhost
Internal=          0
@mattg - My SMTP Relayer is configured as below :
@palinka - I have in the past (8 months ago appr.) succeed to send mail from my gmail account. Does an update in Google's services be applied to block this functionality ? If so, which free alternative I have ?
Kind regards,
Post by palinka » 2019-02-03 16:38
This gmail relay rule has been in place since forever.
You *may* be able to send from @not-gmail.com via smtp.gmail.com, but it will transform the sender to your user@gmail.com. I haven't tried that in a long time.
The correct way for relaying is through smtp-relay.gmail.com which can only be done through a paid g-suite account.
It's not that expensive and it's not a bad option if you don't mind Google snooping all of your outgoing mail. There are better options, IMHO.
By the way, i'm also using a relay since i'm on residential broadband that's blocking port 25 outgoing.
Post by jimimaseye » 2019-02-03 19:17
NivekLR wrote:
2019-02-02 23:18
Hi everyone,
Can you post the SMTPC entries from hms (in text form, not an image) that match these delivery attempts.
NivekLR
Post by NivekLR » 2019-02-03 20:12
@jimimaseye - Here :
"APPLICATION"	8928	"2019-02-03 14:20:30.445"	"SMTPDeliverer - Message 37: Delivering message from contact@xxx.xxx to person@xxx.xxx. File: D:\WAMPPlugins\hMailServer\Data\{40693B3C-C36B-46FA-9D4A-A7CA316C5215}.eml"
"APPLICATION"	8928	"2019-02-03 14:20:30.467"	"SMTPDeliverer - Message 37: Relaying to host smtp.gmail.com."
"APPLICATION"	8928	"2019-02-03 14:20:30.467"	"SMTPDeliverer - Message 37: No mail servers could be found for the address person@xxx.xxx."
"APPLICATION"	8928	"2019-02-03 14:20:30.467"	"SMTPDeliverer - Message 37: Message could not be delivered. Scheduling it for later delivery in 10 minutes."
"APPLICATION"	8928	"2019-02-03 14:20:30.467"	"SMTPDeliverer - Message 37: Message delivery thread completed."
Kind regards,
NivekLR
Post by NivekLR » 2019-02-03 20:14
2019-02-03 16:38
What solution do you use as SMTP relay ?
Post by palinka » 2019-02-03 20:20
NivekLR wrote:
2019-02-03 20:14
I use smtp2go. They have a free option which has limitations, but if your usage falls within those limitations, you should give it a try. Or, try before you buy.
There are others too. You can search for "smtp relay service". Gmail is an option too. Their $5/user/month option includes relaying. They have limitations too, but they're pretty broad.
Post by mattg » 2019-02-03 23:07
Or you can just send directly from hMailserver...
2019-02-03 19:17
NivekLR wrote:
2019-02-03 20:12
Kind regards,
These are all 'application' entries
We need to see SMTP entries, specifically SMTPC
Ensure that you have SMTP logging enabled please
NivekLR
Post by NivekLR » 2019-02-04 11:58
Hello to all,
@mattg - SMTP Logging is activated but I have no error lines that contain "SMTP..."
I have decided to create an external server with Postfix to execute as a SMTP relay.
I have an issue that I will post in another topic :)
Thank you to all for your help !
Kind regards,
Post by mattg » 2019-02-04 13:03
On the 'protocols' branch of the admin GUI, can you confirm that SMTP is checked
