Cannot forward mail with SMTP Authentication enabled.
Microquest
Post by Microquest » 2019-01-31 00:58
Hello.
I am trying to use hmail to receive and send out mail from our software program installed at clients sites. I have setup hmail with the domain of let’s say “xyz.ca” which is a separate domain from our main domain and email address that we use of let’s say “abc.ca”. We have software that is installed at client’s sites that has the ability to email us when a backup fails, but when I configure the software we do not receive the email. The software is configured to send to “myemail@abc.ca” using credentials from “backupfail@xyz.com” on hmail pointing to our hmail server external IP address.
I have in hmail “Require SMTP Authentication Local to External, External to Local, External to External” selected and I have Local to Local unselected. With all three selected and authentication turned off on our software program I get an authentication is required error, so I know it is hitting the server. If I deselect “Local to External” and leave authentication off on our program the emails send normally.
When I select Local to External and enable Authentication on our software I get mail error 504 gateway timeout error instantly. I have included parts of the log from hmail server. Can anyone point me in the direction of what I have misconfigured?
Below is a failure with authentication enabled:
"DEBUG" 5452 "2019-01-30 10:16:55.968" "Creating session 12662"
"TCPIP" 5452 "2019-01-30 10:16:55.968" "TCP - 174.3.x.x connected to 192.168.x.x:587."
"DEBUG" 5452 "2019-01-30 10:16:55.968" "TCP connection started for session 12658"
"SMTPD" 5452 12658 "2019-01-30 10:16:55.968" "174.3.x.x" "SENT: 220 mail.xyz.ca ESMTP"
"SMTPD" 3580 12658 "2019-01-30 10:16:56.014" "174.3.x.x" "RECEIVED: EHLO RIPPER"
"SMTPD" 3580 12658 "2019-01-30 10:16:56.014" "174.3.x.x" "SENT: 250-mail.xyz.ca[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 5452 12658 "2019-01-30 10:16:56.061" "174.3.x.x" "RECEIVED: QUIT"
"SMTPD" 5452 12658 "2019-01-30 10:16:56.061" "174.3.x.x" "SENT: 221 goodbye"
"DEBUG" 3580 "2019-01-30 10:16:56.061" "Ending session 12658"
Below is one that was delivered with authentication disabled:
"DEBUG" 5452 "2019-01-30 10:17:59.532" "Creating session 12663"
"TCPIP" 5452 "2019-01-30 10:17:59.532" "TCP - 174.3.x.x connected to 192.168.x.x:587."
"DEBUG" 5452 "2019-01-30 10:17:59.532" "TCP connection started for session 12662"
"SMTPD" 5452 12662 "2019-01-30 10:17:59.532" "174.3.x.x" "SENT: 220 mail.xyz.ca ESMTP"
"SMTPD" 3580 12662 "2019-01-30 10:17:59.595" "174.3.x.x" "RECEIVED: EHLO RIPPER"
"SMTPD" 3580 12662 "2019-01-30 10:17:59.595" "174.3.x.x" "SENT: 250-mail.xyz.ca[nl]250-SIZE 20480000[nl]250-AUTH LOGIN[nl]250 HELP"
"SMTPD" 5452 12662 "2019-01-30 10:17:59.642" "174.3.x.x" "RECEIVED: MAIL FROM:<backup@xyz.ca>"
"SMTPD" 5452 12662 "2019-01-30 10:17:59.642" "174.3.x.x" "SENT: 250 OK"
"SMTPD" 3580 12662 "2019-01-30 10:17:59.689" "174.3.x.x" "RECEIVED: RCPT TO:<davids@abc.ca>"
"SMTPD" 3580 12662 "2019-01-30 10:17:59.689" "174.3.x.x" "SENT: 250 OK"
"SMTPD" 5452 12662 "2019-01-30 10:17:59.735" "174.3.x.x" "RECEIVED: DATA"
"SMTPD" 5452 12662 "2019-01-30 10:17:59.735" "174.3.x.x" "SENT: 354 OK, send."
"DEBUG" 5452 "2019-01-30 10:17:59.845" "Adding task AsynchronousTask to work queue Asynchronous task queue"
"DEBUG" 5216 "2019-01-30 10:17:59.845" "Executing task AsynchronousTask in work queue Asynchronous task queue"
"DEBUG" 5216 "2019-01-30 10:17:59.860" "Saving message: {CEDC9811-525D-4631-A397-6651190DF98C}.eml"
"DEBUG" 5216 "2019-01-30 10:17:59.860" "Requesting SMTPDeliveryManager to start message delivery"
"SMTPD" 5216 12662 "2019-01-30 10:17:59.860" "174.3.x.x" "SENT: 250 Queued (0.128 seconds)"
"DEBUG" 2500 "2019-01-30 10:17:59.860" "Adding task DeliveryTask to work queue SMTP delivery queue"
"DEBUG" 2076 "2019-01-30 10:17:59.860" "Executing task DeliveryTask in work queue SMTP delivery queue"
"DEBUG" 2076 "2019-01-30 10:17:59.860" "Delivering message..."
"APPLICATION" 2076 "2019-01-30 10:17:59.860" "SMTPDeliverer - Message 1821946: Delivering message from backup@xyz.ca to davids@abc.ca. File: C:\Program Files (x86)\hMailServer\Data\{CEDC9811-525D-4631-A397-6651190DF98C}.eml"
"DEBUG" 2076 "2019-01-30 10:17:59.860" "Applying rules"
"DEBUG" 2076 "2019-01-30 10:17:59.860" "Performing local delivery"
"DEBUG" 2076 "2019-01-30 10:17:59.860" "Local delivery completed"
"TCPIP" 2076 "2019-01-30 10:17:59.860" "DNS MX lookup: abc.ca"
"SMTPD" 4956 12662 "2019-01-30 10:17:59.907" "174.3.x.x" "RECEIVED: QUIT"
"SMTPD" 4956 12662 "2019-01-30 10:17:59.907" "174.3.x.x" "SENT: 221 goodbye"
"DEBUG" 6096 "2019-01-30 10:17:59.907" "Ending session 12662"
"TCPIP" 2076 "2019-01-30 10:18:00.126" "DNS - MX Result: 1 IP addresses were found."
"DEBUG" 2076 "2019-01-30 10:18:00.126" "Starting external delivery process. Server: abc-ca.mail.protection.outlook.com (104.47.60.36), Port: 25, Security: 2, User name: "
"DEBUG" 2076 "2019-01-30 10:18:00.126" "Creating session 12664"
"TCPIP" 2076 "2019-01-30 10:18:00.126" "Connecting to 104.47.60.36:25..."
"DEBUG" 3580 "2019-01-30 10:18:00.220" "TCP connection started for session 12664"
"SMTPC" 3580 12664 "2019-01-30 10:18:05.517" "104.47.60.36" "RECEIVED: 220 QB1CAN01FT004.mail.protection.outlook.com Microsoft ESMTP MAIL Service ready at Wed, 30 Jan 2019 17:17:59 +0000"
"SMTPC" 3580 12664 "2019-01-30 10:18:05.532" "104.47.60.36" "SENT: EHLO mail.xyz.ca"
"SMTPC" 3612 12664 "2019-01-30 10:18:05.611" "104.47.60.36" "RECEIVED: 250-QB1CAN01FT004.mail.protection.outlook.com Hello [68.179.56.65][nl]250-SIZE 157286400[nl]250-PIPELINING[nl]250-DSN[nl]250-ENHANCEDSTATUSCODES[nl]250-STARTTLS[nl]250-8BITMIME[nl]250-BINARYMIME[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC" 3612 12664 "2019-01-30 10:18:05.611" "104.47.60.36" "SENT: STARTTLS"
"SMTPC" 5648 12664 "2019-01-30 10:18:05.704" "104.47.60.36" "RECEIVED: 220 2.0.0 SMTP server ready"
"DEBUG" 5648 "2019-01-30 10:18:05.704" "Performing SSL/TLS handshake for session 12664. Verify certificate: True, Expected remote host name: abc-ca.mail.protection.outlook.com"
"DEBUG" 3580 "2019-01-30 10:18:05.798" "Certificate verification succeeded for session 12664."
"TCPIP" 5452 "2019-01-30 10:18:05.908" "TCPConnection - TLS/SSL handshake completed. Session Id: 12664, Remote IP: 104.47.60.36, Version: TLSv1.2, Cipher: ECDHE-RSA-AES256-SHA384, Bits: 256"
"SMTPC" 5452 12664 "2019-01-30 10:18:05.908" "104.47.60.36" "SENT: EHLO mail.xyz.ca"
"SMTPC" 4956 12664 "2019-01-30 10:18:06.001" "104.47.60.36" "RECEIVED: 250-QB1CAN01FT004.mail.protection.outlook.com Hello [68.179.56.65][nl]250-SIZE 157286400[nl]250-PIPELINING[nl]250-DSN[nl]250-ENHANCEDSTATUSCODES[nl]250-8BITMIME[nl]250-BINARYMIME[nl]250-CHUNKING[nl]250 SMTPUTF8"
"SMTPC" 4956 12664 "2019-01-30 10:18:06.001" "104.47.60.36" "SENT: MAIL FROM:<backup@xyz.ca>"
"SMTPC" 5452 12664 "2019-01-30 10:18:18.142" "104.47.60.36" "RECEIVED: 250 2.1.0 Sender OK"
"SMTPC" 5452 12664 "2019-01-30 10:18:18.158" "104.47.60.36" "SENT: RCPT TO:<davids@abc.ca>"
"SMTPC" 5452 12664 "2019-01-30 10:18:44.049" "104.47.60.36" "RECEIVED: 250 2.1.5 Recipient OK"
"SMTPC" 5452 12664 "2019-01-30 10:18:44.049" "104.47.60.36" "SENT: DATA"
"SMTPC" 5648 12664 "2019-01-30 10:18:44.190" "104.47.60.36" "RECEIVED: 354 Start mail input; end with <CRLF>.<CRLF>"
"SMTPC" 5648 12664 "2019-01-30 10:18:44.253" "104.47.60.36" "SENT: [nl]."
"SMTPC" 5452 12664 "2019-01-30 10:19:02.394" "104.47.60.36" "RECEIVED: 250 2.6.0 <A3F14514-B3D0-47A0-A6B3-0AB338824B80@mail.xyz.ca> [InternalId=1627792606594, Hostname=YTBPR01MB2976.CANPRD01.PROD.OUTLOOK.COM] 8228 bytes in 0.159, 50.484 KB/sec Queued mail for delivery"
"SMTPC" 5452 12664 "2019-01-30 10:19:02.394" "104.47.60.36" "SENT: QUIT"
"SMTPC" 5648 12664 "2019-01-30 10:19:02.488" "104.47.60.36" "RECEIVED: 221 2.0.0 Service closing transmission channel"
"DEBUG" 5648 "2019-01-30 10:19:02.488" "Ending session 12664"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "External delivery process completed"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "Summarizing delivery result"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "AWStats::LogDeliverySuccess"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "Summarized delivery results"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "Deleting message"
"DEBUG" 2076 "2019-01-30 10:19:02.488" "Deleting message file."
"APPLICATION" 2076 "2019-01-30 10:19:02.488" "SMTPDeliverer - Message 1821946: Message delivery thread completed."
Dave
Re: Cannot forward mail with SMTP Authentication enabled.
Post by jimimaseye » 2019-01-31 01:15
run this and post the results: viewtopic.php?f=20&t=30914
Post by mattg » 2019-01-31 04:15
Microquest wrote:
2019-01-31 00:58
I think your client software doesn't like to AUTH...
Microquest
Post by Microquest » 2019-01-31 19:01
Thank you for checking on it jimimaseye
2019-01-31   Hmailserver: 5.6.5-B2367
DOMAINS
   "Domain1.com" - hexxxxxxxxx.ca                 Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
GLOBAL RULES
IP RANGES
     POP3:  False                              Antivirus:  False
     External To Local    -  True              External To Local    -  True
     External To Local    -  True           !! External To Local    -  True !!
       !! EXTERNAL INBOUND ON SUB IP RANGES OR EXTERNAL DOWNLOADS ONLY !!
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
                              Minutes Before Reset:           15  (0.25 hours, 0.01 days)
                              Minutes to Autoban:          10080  (168.00 hours, 7.00 days)
There is a total of 12 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries: 10 Mins:  1   Plain Text:        False  Bind:
                     Host: EXTERNAL.TLD        Empty sender:      False  Batch recipients:   100
                                               Max number commands:  25  Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
   No 'enabled' entries
GREYLISTING:
  Greylisting:  False
WHITELISTING
   No entries
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.pif             Program Information file
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :  False
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               192.168.1.125   / 110   / POP3   -   None
               192.168.1.125   / 143   / IMAP   -   None
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-01-31.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-01-31.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory C:\hMailServer_Backup is writable.
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Post by mattg » 2019-01-31 23:44
in your current config (as posted)
You won't receive ANY mail from the internet without AUTH, which means that you won't receive ANY mail from the internet
On the IP ranges tab - press the default button and try again
ALSO
There are errors in your error log
Please post the contents of that
