HMS behind Exchange server - no mails from specific domain
derelvis
Post by derelvis » 2019-01-07 16:07
Hi there,
I have a strange problem with our HMS setup.
We receive and send mails in hms through an external Exchange server where our domain is hosted.
clients <--- imap/smtp ---> hms (domain2.de) <--- pop3/stmp ---> exchange (domain1.de, domain2.de)
When someone sends mails from another domain also hosted on this exchange, mails don't even show up in the logs.
But they can be seen within webmail on the exchange server.
It looks like hms does not fetch them during pop3 session. Already tried whitelisting, no change.
Also checked all used blacklist dns servers for entries of the exchange ip/adress, nothing.
All other mails from internal senders or external senders (with no domain on the exchange server) get delivered.
awstats.log shows the complete mailflow except the messages send from domain1.de to domain2.de on the exchange server.
Does anyone has a clue on what to look at or where to search?
More info needed? Please let me know.
Thanks very much in advance!
Best regards
derelvis
HMS 5.7.0-B2428 (x64) - MySQL 8.0.15 (DB version 5700)
ClamWin0.99.4 + Clamd service - SpamAssassin 3.4.1.38
Windows Server 2012 - 64Bit
Re: HMS behind Exchange server - no mails from specific domain
Post by mattg » 2019-01-07 22:46
Almost seems like an issue with the Exchange server
hMailserver should POP the mail like all other mail for the same account, it makes no sense that hMailserver knows what accounts are hosted on the Exchange server, and which ones aren't.
It is like the Exchange server stores mail differently when from another domain hosted on it. What does the support team for Exchange say?
derelvis
Post by derelvis » 2019-01-08 01:48
Hi mattg,
thank you very much for your reply!
Yes, you are right. That's quite what I thought too.
What I did now is to setup the exact same pop account like in hms in thunderbird and despite my expectation the missing emails get correctly delivered from exchange there.
I then deleted the external pop account from hms and set it up new again. After that hms stated to download all mails again (I only let them delete after 93 days) and - what should I say - again without any mail from the other hosted domain on exchange.
This is really starting to drive me crazy :(
Any other ideas?
I will ask the exchange support but for sure they will claim it is not on their side :|
Post by Dravion » 2019-01-08 04:18
Try to enable Exchange log settings
so you can see if hMailServer is trying to fetch Exchange IMAP and POP3 Inboxes.
Check espacially errorprone logon attemps on Exchangesite.
Test if Exchange POP3 and IMAP Ports are open and
accessible by telnet.
64-Bit builds of hMailserver
derelvis
Post by derelvis » 2019-01-12 10:30
Hi Dravion,
thanks for your reply.
As I have no access to the external Exchange server I am not able to do that myself and they don't grant me access to the logs :-(
Are imap ports really needed to be open on exchange side? I mean it is only possible to choose type pop3 within hms creating a new external mail account.
The strange thing is, why does thunderbird get the mails though direct pop3 fetch rom exchange which hms does not get through pop3 fetch from exchange?
How is that possible? They should really see the same on exchange using the same protocol and so also get the same to fetch.
But I know, hard to say without the logs from the other side :roll:
Thanks to everyone getting into this issue. I fear I will not be able to fix it without help from exchange side.
Best regards
derelvis
Post by jimimaseye » 2019-01-12 15:40
To be sure we are setting the full picture run this and post the results: viewtopic.php?f=20&t=30914.
Also temporarily (because you will get huge logs) enable debug and pop3 logging, run the download them post the resultant logging here (that shows the connection and download request).
derelvis
Post by derelvis » 2019-01-12 18:32
Hi Jimimaseye,
Here comes the log. "Domain1.com" ist the domain where it happens when the account user@Domain1.com fetches from problematic-exchange-domain[dot]de (91.xxx.xx.7).
2019-01-12   Hmailserver: 5.6.7-B2425
DOMAINS
   "Domain1.com" - asxxxxxxxxxxxxxxxxxx.de        Enabled: True
                                                Private key: d:\hmailserver\Domain1.com\dkim-private.pem
                                                Selector:    dkim
   "Domain2.com" - asxxxxxxxxxx.inxx              Enabled: True
        Greylisting:     False
   "Domain3.com" - grxxxx.inxx                    Enabled: True
        Greylisting:     False
   "Domain4.com" - kexxxxxxxx.de                  Enabled: True
        Greylisting:     False
   "Domain5.com" - prxxxxxxxxx.inxx               Enabled: True
        Greylisting:     False
IP RANGES
     External To Local    - False     !! Inbound on Sub IP ranges or External Downloads only !!
     External To External - False
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:      5
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
No. Connections:  0  No Retries:  5 Mins:  1   Plain Text:        False  Bind:
Max Msg Size:102400  Relay:-                   Incorrect endings:  True  Use STARTTLS:      True
                     Port:  25                                           Loop limit:           5
                     Con. Sec.: StartTLS Required
  Routes:
    asx.local                - S: Remote  R: Remote - Addr: All         (ok)
    Domain4.com              - S: Local   R: Remote - Addr: All         (ok)
    Domain5.com              - S: Local   R: Remote - Addr: All         (ok)
POP3
  No. Connections: 0
IMAP
  No. Connections:   0      Public folder name:               IMAP sort:  True
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Add X-HmailServer-Subject:  True    Verify DKIM:       False        Use SA score: False -   5
              Subject Text: "[SPAM]"
  Spam delete threshold: 8         Maximum message size: 2048
DNSBL ENTRIES:
                  zen.spamhaus.org      Score: 5     Result: 127.0.0.2-8|127.0.0.10-11
            b.barracudacentral.org      Score: 2     Result: 127.0.0.2
     hostkarma.junkemailfilter.com      Score: 2     Result: 127.0.0.2|127.0.0.4
           bl.spameatingmonkey.net      Score: 2     Result: 127.0.0.2-3
                   cbl.abuseat.org      Score: 2     Result: 127.0.0.2
SURBL ENTRIES:
                   multi.surbl.org      Score: 3
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              drucker[@t]Domain1.com
              0.0.0.0            to    255.255.255.255              Brandschutz[@t]xxxxx[dot]de
              91.xxx.xx.7        to    91.xxx.xx.7                  support[@t]problematic-exchange-domain[dot]de
ANTIVIRUS
GENERAL:
  Max Message Size: 26214
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 993   / IMAP   -   None
    !! No SMTP Port 25 defined. Direct external SMTP inbound not possible !!
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-01-12.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-01-12.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL Compact
Backup directory D:\hMailServer is writable.
HMAILSERVER.INI
Data folder:     D:\hMailServer
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
And here is the the part of the debug log:
"DEBUG"	18424	"2019-01-12 17:14:46.209"	"Adding task ExternalFetchTask to work queue External fetch queue"
"DEBUG"	17068	"2019-01-12 17:14:46.209"	"Executing task ExternalFetchTask in work queue External fetch queue"
"DEBUG"	17068	"2019-01-12 17:14:46.209"	"Retrieving messages from external account user@Domain1.com"
"DEBUG"	17068	"2019-01-12 17:14:46.209"	"Creating session 9065"
"DEBUG"	17748	"2019-01-12 17:14:46.229"	"TCP connection started for session 9065"
"DEBUG"	17748	"2019-01-12 17:14:46.229"	"Performing SSL/TLS handshake for session 9065. Verify certificate: True, Expected remote host name: pop.problematic-exchange-domain.de"
"DEBUG"	16280	"2019-01-12 17:14:46.289"	"Certificate verification succeeded for session 9065."
"POP3C"	17748	9065	"2019-01-12 17:14:46.379"	"91.xxx.xx.7"	"RECEIVED: +OK Hello there."
"POP3C"	17748	9065	"2019-01-12 17:14:46.379"	"91.xxx.xx.7"	"SENT: USER user@Domain1.com"
"POP3C"	17268	9065	"2019-01-12 17:14:46.399"	"91.xxx.xx.7"	"RECEIVED: +OK Password required."
"POP3C"	17268	9065	"2019-01-12 17:14:46.399"	"91.xxx.xx.7"	"SENT: ***"
"POP3C"	16280	9065	"2019-01-12 17:14:46.434"	"91.xxx.xx.7"	"RECEIVED: +OK logged in."
"POP3C"	16280	9065	"2019-01-12 17:14:46.434"	"91.xxx.xx.7"	"SENT: UIDL"
"POP3C"	17748	9065	"2019-01-12 17:14:46.694"	"91.xxx.xx.7"	"RECEIVED: +OK[nl]1 UID4636-1481794787[nl]2 UID4637-1481794787[nl]3 UID4638-1481794787[nl]4 UID4639-1481794787[nl]5 UID4640-1481794787[nl]6 UID4641-1481794787[nl]7 UID4642-1481794787[nl]8 UID4643-1481794787[nl]9 UID4644-1481794787[nl]10 UID4645-1481794787[nl]11 UID4646-1481794787[nl]12 UID4647-1481794787[nl]13 UID4648-1481794787[nl]14 UID4649-1481794787[nl]15 UID4650-1481794787[nl]16 UID4651-1481794787[nl]17 UID4652-1481794787[nl]18 UID4653-1481794787[nl]19 UID4654-1481794787[nl]20 UID4655-1481794787[nl]21 UID4656-1481794787[nl]22 UID4657-1481794787[nl]23 UID4658-1481794787[nl]24 UID4659-1481794787[nl]25 UID4660-1481794787[nl]26 UID4661-1481794787[nl]27 UID4662-1481794787[nl]28 UID4663-1481794787[nl]29 UID4664-1481794787[nl]30 UID4665-1481794787[nl]31 UID4666-1481794787[nl]32 UID4667-1481794787[nl]33 UID4668-1481794787[nl]34 UID4669-1481794787[nl]35 UID4670-1481794787[nl]36 UID4671-1481794787[nl]37 UID4672-1481794787[nl]38 UID4673-1481794787[nl]39 UID4674-1481794787[nl]40 UID4675-1481794787[nl]41 UID4676-1481794787[nl]42 UID4677-1481794787[nl]43 UID4678-1481794787[nl]44 UID4679-1481794787[nl]45 UID4680-1481794787[nl]46 UID4681-1481794787[nl]47 UID4682-1481794787[nl]48 UID4683-1481794787[nl]49 UID4684-1481794787[nl]50 UID4685-1481794787[nl]51 UID4686-1481794787[nl]52 UID4687-1481794787[nl]53 UID4688-1481794787[nl]54 UID4689-1481794787[nl]55 UID4690-1481794787[nl]56 UID4691-1481794787[nl]57 UID4692-1481794787[nl]58 UID4693-1481794787[nl]59 UID4694-1481794787[nl]60 UID4695-1481794787[nl]61 UID4696-1481794787[nl]62 UID4697-1481794787[nl]63 UID4698-1481794787[nl]64 UID4699-1481794787[nl]65 UID4700-1481794787[nl]66 UID4701-1481794787[nl]67 UID4702-1481794787[nl]68 UID4703-1481794787[nl]69 UID4704-1481794787[nl]70 UID4705-1481794787[nl]71 UID4706-1481794787[nl]72 UID4707-1481794787[nl]73 UID4708-1481794787[nl]74 UID4709-1481794787[nl]75 UID4710-1481794787[nl]76 UID4711-1481794787[nl]77 UID4712-1481794787[nl]78 UID4713-1481794787[nl]79 UID4714-1481794787[nl]80 UID4715-1481794787[nl]81 UID4716-1481794787[nl]82 UID4717-1481794787[nl]83 UID4718-1481794787[nl]84 UID4719-1481794787[nl]85 UID4720-1481794787[nl]86 UID4721-1481794787[nl]87 UID4722-1481794787[nl]88 UID4723-1481794787[nl]89 UID4724-1481794787[nl]90 UID4725-1481794787[nl]91 UID4726-1481794787[nl]92 UID4727-1481794787[nl]93 UID4728-1481794787[nl]94 UID4729-1481794787[nl]95 UID4730-1481794787[nl]96 UID4731-1481794787[nl]97 UID4732-1481794787[nl]98 UID4733-1481794787[nl]99 UID4734-1481794787[nl]100 UID4735-1481794787[nl]101 UID4736-1481794787[nl]102 UID4737-1481794787[nl]103 UID4738-1481794787[nl]104 UID4739-1481794787[nl]105 UID4740-1481794787[nl]106 UID4741-1481794787[nl]107 UID4742-1481794787[nl]108 UID4743-1481794787[nl]109 UID4744-1481794787[nl]110 UID4745-1481794787[nl]111 UID4746-1481794787[nl]112 UID4747-1481794787[nl]113 UID4748-1481794787[nl]114 UID4749-1481794787[nl]115 UID4750-1481794787[nl]116 UID4751-1481794787[nl]117 UID4752-1481794787[nl]118 UID4753-1481794787[nl]119 UID4754-1481794787[nl]120 UID4755-1481794787[nl]121 UID4756-1481794787[nl]122 UID4757-1481794787[nl]123 UID4758-1481794787[nl]124 UID4759-1481794787[nl]125 UID4760-1481794787[nl]126 UID4761-1481794787[nl]127 UID4762-1481794787[nl]128 UID4763-1481794787[nl]129 UID4764-1481794787[nl]130 UID4765-1481794787[nl]131 UID4766-1481794787[nl]132 UID4767-1481794787[nl]133 UID4768-1481794787[nl]134 UID4769-1481794787[nl]135 UID4770-1481794787[nl]136 UID4771-1481794787[nl]137 UID4772-1481794787[nl]138 UID4773-1481794787[nl]139 UID4774-1481794787[nl]140 UID4775-1481794787[nl]141 UID4776-1481794787[nl]142 UID4777-1481794787[nl]143 UID4778-1481794787[nl]144 UID4779-1481794787[nl]145 UID4780-1481794787[nl]146 UID4781-1481794787[nl]147 UID4782-1481794787[nl]148 UID4783-1481794787[nl]149 UID4784-1481794787[nl]150 UID4785-1481794787[nl]151 UID4786-1481794787[nl]152 UID4787-1481794787[nl]153 UID4788-1481794787[nl]154 UID4789-1481794787[nl]155 UID4790-1481794787[nl]156 UID4791-1481794787[nl]157 UID4792-1481794787[nl]158 UID4793-1481794787[nl]159 UID4794-1481794787[nl]160 UID4795-1481794787[nl]161 UID4796-1481794787[nl]162 UID4797-1481794787[nl]163 UID4798-1481794787[nl]164 UID4799-1481794787[nl]165 UID4800-1481794787[nl]166 UID4801-1481794787[nl]167 UID4802-1481794787[nl]168 UID4803-1481794787[nl]169 UID4804-1481794787[nl]170 UID4805-1481794787[nl]171 UID4806-1481794787[nl]172 UID4807-1481794787[nl]173 UID4808-1481794787[nl]174 UID4809-1481794787[nl]175 UID4810-1481794787[nl]176 UID4811-1481794787[nl]177 UID4812-1481794787[nl]178 UID4813-1481794787[nl]179 UID4814-1481794787[nl]180 UID4815-1481794787[nl]181 UID4816-1481794787[nl]182 UID4817-1481794787[nl]183 UID4818-1481794787[nl]184 UID4819-1481794787[nl]185 UID4820-1481794787[nl]186 UID4821-1481794787[nl]187 UID4822-1481794787[nl]188 UID4823-1481794787[nl]189 UID4824-1481794787[nl]190 UID4825-1481794787[nl]191 UID4826-1481794787[nl]192 UID4827-1481794787[nl]193 UID4828-1481794787[nl]194 UID4829-1481794787[nl]195 UID4830-1481794787[nl]196 UID4831-1481794787[nl]197 UID4832-1481794787[nl]198 UID4833-1481794787[nl]199 UID4834-1481794787[nl]200 UID4835-1481794787[nl]201 UID4836-1481794787[nl]202 UID4837-1481794787[nl]203 UID4838-1481794787[nl]204 UID4839-1481794787[nl]205 UID4840-1481794787[nl]206 UID4841-1481794787[nl]207 UID4842-1481794787[nl]208 UID4843-1481794787[nl]209 UID4844-1481794787[nl]210 UID4845-1481794787[nl]211 UID4846-1481794787[nl]212 UID4847-1481794787[nl]213 UID4848-1481794787[nl]214 UID4849-1481794787[nl]215 UID4850-1481794787[nl]216 UID4851-1481794787[nl]217 UID4852-1481794787[nl]218 UID4853-1481794787[nl]219 UID4854-1481794787[nl]220 UID4855-1481794787[nl]221 UID4856-1481794787[nl]222 UID4857-1481794787[nl]223 UID4858-1481794787[nl]224 UID4859-1481794787[nl]225 UID4860-1481794787[nl]226 UID4861-1481794787[nl]227 UID4862-1481794787[nl]228 UID4863-1481794787[nl]229 UID4864-1481794787[nl]230 UID4865-1481794787[nl]231 UID4866-1481794787[nl]232 UID4867-1481794787[nl]233 UID4868-1481794787[nl]234 UID4869-1481794787[nl]235 UID4870-1481794787[nl]236 UID4871-1481794787[nl]237 UID4872-1481794787[nl]238 UID4873-1481794787[nl]239 UID4874-1481794787[nl]240 UID4875-1481794787[nl]241 UID4876-1481794787[nl]242 UID4877-1481794787[nl]243 UID4878-1481794787[nl]244 UID4879-1481794787[nl]245 UID4880-1481794787[nl]246 UID4881-1481794787[nl]247 UID4882-1481794787[nl]248 UID4883-1481794787[nl]249 UID4884-1481794787[nl]250 UID4885-1481794787[nl]251 UID4886-1481794787[nl]252 UID4887-1481794787[nl]253 UID4888-1481794787[nl]254 UID4889-1481794787[nl]255 UID4890-1481794787[nl]256 UID4891-1481794787[nl]257 UID4892-1481794787[nl]258 UID4893-1481794787[nl]259 UID4894-1481794787[nl]260 UID4895-1481794787[nl]261 UID4896-1481794787[nl]262 UID4897-1481794787[nl]263 UID4898-1481794787[nl]264 UID4899-1481794787[nl]265 UID4900-1481794787[nl]266 UID4901-1481794787[nl]267 UID4902-1481794787[nl]268 UID4903-1481794787[nl]269 UID4904-1481794787[nl]270 UID4905-1481794787[nl]271 UID4906-1481794787[nl]272 UID4907-1481794787[nl]273 UID4908-1481794787[nl]274 UID4909-1481794787[nl]275 UID4910-1481794787[nl]276 UID4911-1481794787[nl]277 UID4912-1481794787[nl]278 UID4913-1481794787[nl]279 UID4914-1481794787[nl]280 UID4915-1481794787[nl]281 UID4916-1481794787[nl]282 UID4917-1481794787[nl]283 UID4918-1481794787[nl]284 UID4919-1481794787[nl]285 UID4920-1481794787[nl]286 UID4921-1481794787[nl]287 UID4922-1481794787[nl]288 UID4923-1481794787[nl]289 UID4924-1481794787[nl]290 UID4925-1481794787[nl]291 UID4926-1481794787[nl]292 UID4927-1481794787[nl]293 UID4928-1481794787[nl]294 UID4929-1481794787[nl]295 UID4930-1481794787[nl]296 UID4931-1481794787[nl]297 UID4932-1481794787[nl]298 UID4933-1481794787[nl]299 UID4934-1481794787[nl]300 UID4935-1481794787[nl]301 UID4936-1481794787[nl]302 UID4937-1481794787[nl]303 UID4938-1481794787[nl]304 UID4939-1481794787[nl]305 UID4940-1481794787[nl]306 UID4941-1481794787[nl]307 UID4942-1481794787[nl]308 UID4943-1481794787[nl]309 UID4944-1481794787[nl]310 UID4945-1481794787[nl]311 UID4946-1481794787[nl]312 UID4947-1481794787[nl]313 UID4948-1481794787[nl]314 UID4949-1481794787[nl]315 UID4950-1481794787[nl]316 UID4951-1481794787[nl]317 UID4952-1481794787[nl]318 UID4953-1481794787[nl]319 UID4954-1481794787[nl]320 UID4955-1481794787[nl]321 UID4956-1481794787[nl]322 UID4957-1481794787[nl]323 UID4958-1481794787[nl]324 UID4959-1481794787[nl]325 UID4960-1481794787[nl]326 UID4961-1481794787[nl]327 UID4962-1481794787[nl]328 UID4963-1481794787[nl]329 UID4964-1481794787[nl]330 UID4965-1481794787[nl]331 UID4966-1481794787[nl]332 UID4967-1481794787[nl]333 UID4968-1481794787[nl]334 UID4969-1481794787[nl]335 UID4970-1481794787[nl]336 UID4971-1481794787[nl]337 UID4972-1481794787[nl]338 UID4973-1481794787[nl]339 UID4974-1481794787[nl]340 UID4975-1481794787[nl]341 UID4976-1481794787[nl]342 UID4977-1481794787[nl]343 UID4978-1481794787[nl]344 UID4979-1481794787[nl]345 UID4980-1481794787[nl]346 UID4981-1481794787[nl]347 UID4982-1481794787[nl]348 UID4983-1481794787[nl]349 UID4984-1481794787[nl]350 UID4985-1481794787[nl]351 UID4986-1481794787[nl]352 UID4987-1481794787[nl]353 UID4988-1481794787[nl]354 UID4989-1481794787[nl]355 UID4990-1481794787[nl]356 UID4991-1481794787[nl]357 UID4992-1481794787[nl]358 UID4993-1481794787[nl]359 UID4994-1481794787[nl]360 UID4995-1481794787[nl]361 UID4996-1481794787[nl]362 UID4997-1481794787[nl]363 UID4998-1481794787[nl]364 UID4999-1481794787[nl]365 UID5000-1481794787[nl]366 UID5001-1481794787[nl]367 UID5002-1481794787[nl]368 UID5003-1481794787[nl]369 UID5004-1481794787[nl]370 UID5005-1481794787[nl]371 UID5006-1481794787[nl]372 UID5007-1481794787[nl]373 UID5008-1481794787[nl]374 UID5009-1481794787[nl]375 UID5010-1481794787[nl]376 UID5011-1481794787[nl]377 UID5012-1481794787[nl]378 UID5013-1481794787[nl]379 UID5014-1481794787[nl]380 UID5015-1481794787[nl]381 UID5016-1481794787[nl]382 UID5017-1481794787[nl]383 UID5018-1481794787[nl]384 UID5019-1481794787[nl]385 UID5020-1481794787[nl]386 UID5021-1481794787[nl]387 UID5022-1481794787[nl]388 UID5023-1481794787[nl]389 UID5024-1481794787[nl]390 UID5025-1481794787[nl]391 UID5026-1481794787[nl]392 UID5027-1481794787[nl]393 UID5028-1481794787[nl]394 UID5029-1481794787[nl]395 UID5030-1481794787[nl]396 UID5031-1481794787[nl]397 UID5032-1481794787[nl]398 UID5033-1481794787[nl]399 UID5034-1481794787[nl]400 UID5035-1481794787[nl]401 UID5036-1481794787[nl]402 UID5037-1481794787[nl]403 UID5038-1481794787[nl]404 UID5039-1481794787[nl]405 UID5040-1481794787[nl]406 UID5041-1481794787[nl]407 UID5042-1481794787[nl]408 UID5043-1481794787[nl]409 UID5044-1481794787[nl]410 UID5045-1481794787[nl]411 UID5046-1481794787[nl]412 UID5047-1481794787[nl]413 UID5048-1481794787[nl]414 UID5049-1481794787[nl]415 UID5050-1481794787[nl]416 UID5051-1481794787[nl]417 UID5052-1481794787[nl]418 UID5053-1481794787[nl]419 UID5054-1481794787[nl]420 UID5055-1481794787[nl]421 UID5056-1481794787[nl]422 UID5057-1481794787[nl]423 UID5058-1481794787[nl]424 UID5059-1481794787[nl]425 UID5060-1481794787[nl]426 UID5061-1481794787[nl]427 UID5062-1481794787[nl]428 UID5063-1481794787[nl]429 UID5064-1481794787[nl]430 UID5065-1481794787[nl]431 UID5066-1481794787[nl]432 UID5067-1481794787[nl]433 UID5068-1481794787[nl]434 UID5069-1481794787[nl]435 UID5070-1481794787[nl]436 UID5071-1481794787[nl]437 UID5072-1481794787[nl]438 UID5073-1481794787[nl]439 UID5074-1481794787[nl]440 UID5075-1481794787[nl]441 UID5076-1481794787[nl]442 UID5077-1481794787[nl]443 UID5078-1481794787[nl]444 UID5079-1481794787[nl]445 UID5080-1481794787[nl]446 UID5081-1481794787[nl]447 UID5082-1481794787[nl]448 UID5083-1481794787[nl]449 UID5084-1481794787[nl]450 UID5085-1481794787[nl]451 UID5086-1481794787[nl]452 UID5087-1481794787[nl]453 UID5088-1481794787[nl]454 UID5089-1481794787[nl]455 UID5090-1481794787[nl]456 UID5091-1481794787[nl]457 UID5092-1481794787[nl]458 UID5093-1481794787[nl]459 UID5094-1481794787[nl]460 UID5095-1481794787[nl]461 UID5096-1481794787[nl]462 UID5097-1481794787[nl]463 UID5098-1481794787[nl]464 UID5099-1481794787[nl]465 UID5100-1481794787[nl]466 UID5101-1481794787[nl]467 UID5102-1481794787[nl]468 UID5103-1481794787[nl]469 UID5104-1481794787[nl]470 UID5105-1481794787[nl]471 UID5106-1481794787[nl]472 UID5107-1481794787[nl]473 UID5108-1481794787[nl]474 UID5109-1481794787[nl]475 UID5110-1481794787[nl]476 UID5111-1481794787[nl]477 UID5112-1481794787[nl]478 UID5113-1481794787[nl]479 UID5114-1481794787[nl]480 UID5115-1481794787[nl]481 UID5116-1481794787[nl]482 UID5117-1481794787[nl]483 UID5118-1481794787[nl]484 UID5119-1481794787[nl]485 UID5120-1481794787[nl]486 UID5121-1481794787[nl]487 UID5122-1481794787[nl]488 UID5123-1481794787[nl]489 UID5124-1481794787[nl]490 UID5125-1481794787[nl]491 UID5126-1481794787[nl]492 UID5127-1481794787[nl]493 UID5128-1481794787[nl]494 UID5129-1481794787[nl]495 UID5130-1481794787[nl]496 UID5131-1481794787[nl]497 UID5132-1481794787[nl]498 UID5133-1481794787[nl]499 UID5134-1481794787[nl]500 UID5135-1481794787[nl]501 UID5136-1481794787[nl]502 UID5137-1481794787[nl]503 UID5138-1481794787[nl]504 UID5139-1481794787[nl]505 UID5140-1481794787[nl]506 UID5141-1481794787[nl]507 UID5142-1481794787[nl]508 UID5143-1481794787[nl]509 UID5144-1481794787[nl]510 UID5145-1481794787[nl]511 UID5146-1481794787[nl]512 UID5147-1481794787[nl]513 UID5148-1481794787[nl]514 UID5149-1481794787[nl]515 UID5150-1481794787[nl]516 UID5151-1481794787[nl]517 UID5152-1481794787[nl]518 UID5153-1481794787[nl]519 UID5154-1481794787[nl]520 UID5155-1481794787[nl]521 UID5156-1481794787[nl]522 UID5157-1481794787[nl]523 UID5158-1481794787[nl]524 UID5159-1481794787[nl]525 UID5160-1481794787[nl]526 UID5161-1481794787[nl]527 UID5162-1481794787[nl]528 UID5163-1481794787[nl]529 UID5164-1481794787[nl]530 UID5165-1481794787[nl]531 UID5166-1481794787[nl]532 UID5167-1481794787[nl]533 UID5168-1481794787[nl]534 UID5169-1481794787[nl]535 UID5170-1481794787[nl]536 UID5171-1481794787[nl]537 UID5172-1481794787[nl]538 UID5173-1481794787[nl]539 UID5174-1481794787[nl]540 UID5175-1481794787[nl]541 UID5176-1481794787[nl]542 UID5177-1481794787[nl]543 UID5178-1481794787[nl]544 UID5179-1481794787[nl]545 UID5180-1481794787[nl]546 UID5181-1481794787[nl]547 UID5182-1481794787[nl]548 UID5183-1481794787[nl]549 UID5184-1481794787[nl]550 UID5185-1481794787[nl]551 UID5186-1481794787[nl]552 UID5187-1481794787[nl]553 UID5188-1481794787[nl]554 UID5189-1481794787[nl]555 UID5190-1481794787[nl]556 UID5191-1481794787[nl]557 UID5192-1481794787[nl]558 UID5193-1481794787[nl]559 UID5194-1481794787[nl]560 UID5195-1481794787[nl]561 UID5196-1481794787[nl]562 UID5197-1481794787[nl]563 UID5198-1481794787[nl]564 UID5199-1481794787[nl]565 UID5200-1481794787[nl]566 UID5201-1481794787[nl]567 UID5202-1481794787[nl]568 UID5203-1481794787[nl]569 UID5204-1481794787[nl]570 UID5205-1481794787[nl]571 UID5206-1481794787[nl]572 UID5207-1481794787[nl]573 UID5208-1481794787[nl]574 UID5209-1481794787[nl]575 UID5210-1481794787[nl]576 UID5211-1481794787[nl]577 UID5212-1481794787[nl]578 UID5213-1481794787[nl]579 UID5214-1481794787[nl]580 UID5215-1481794787[nl]581 UID5216-1481794787[nl]582 UID5217-1481794787[nl]583 UID5218-1481794787[nl]584 UID5219-1481794787[nl]585 UID5220-1481794787[nl]586 UID5221-1481794787[nl]587 UID5222-1481794787[nl]588 UID5223-1481794787[nl]589 UID5224-1481794787[nl]590 UID5225-1481794787[nl]591 UID5226-1481794787[nl]592 UID5227-1481794787[nl]593 UID5228-1481794787[nl]594 UID5229-1481794787[nl]595 UID5230-1481794787[nl]596 UID5231-1481794787[nl]597 UID5232-1481794787[nl]598 UID5233-1481794787[nl]599 UID5234-1481794787[nl]600 UID5235-1481794787[nl]601 UID5236-1481794787[nl]602 UID5237-1481794787[nl]603 UID5238-1481794787[nl]604 UID5239-1481794787[nl]605 UID5240-1481794787[nl]606 UID5241-1481794787[nl]607 UID5242-1481794787[nl]608 UID5243-1481794787[nl]609 UID5244-1481794787[nl]610 UID5245-1481794787[nl]611 UID5246-1481794787[nl]612 UID5247-1481794787[nl]613 UID5248-1481794787[nl]614 UID5249-1481794787[nl]615 UID5250-1481794787[nl]616 UID5251-1481794787[nl]617 UID5252-1481794787[nl]618 UID5253-1481794787[nl]619 UID5254-1481794787[nl]620 UID5255-1481794787[nl]621 UID5256-1481794787[nl]622 UID5257-1481794787[nl]623 UID5258-1481794787[nl]624 UID5259-1481794787[nl]625 UID5260-1481794787[nl]626 UID5261-1481794787[nl]627 UID5262-1481794787[nl]628 UID5263-1481794787[nl]629 UID5264-1481794787[nl]630 UID5265-1481794787[nl]631 UID5266-1481794787[nl]632 UID5267-1481794787[nl]633 UID5268-1481794787[nl]634 UID5269-1481794787[nl]635 UID5270-1481794787[nl]636 UID5271-1481794787[nl]637 UID5272-1481794787[nl]638 UID5273-1481794787[nl]639 UID5274-1481794787[nl]640 UID5275-1481794787[nl]641 UID5276-1481794787[nl]642 UID5277-1481794787[nl]643 UID5278-1481794787[nl]644 UID5279-1481794787[nl]645 UID5280-1481794787[nl]646 UID5281-1481794787[nl]647 UID5282-1481794787[nl]648 UID5283-1481794787[nl]649 UID5284-1481794787[nl]650 UID5285-1481794787[nl]651 UID5286-1481794787[nl]652 UID5287-1481794787[nl]653 UID5288-1481794787[nl]654 UID5289-1481794787[nl]655 UID5290-1481794787[nl]656 UID5291-1481794787[nl]657 UID5292-1481794787[nl]658 UID5293-1481794787[nl]659 UID5294-1481794787[nl]660 UID5295-1481794787[nl]661 UID5296-1481794787[nl]662 UID5297-1481794787[nl]663 UID5298-1481794787[nl]664 UID5299-1481794787[nl]665 UID5300-1481794787[nl]666 UID5301-1481794787[nl]667 UID5302-1481794787[nl]668 UID5303-1481794787[nl]669 UID5304-1481794787[nl]670 UID5305-1481794787[nl]671 UID5306-1481794787[nl]672 UID5307-1481794787[nl]673 UID5308-1481794787[nl]674 UID5309-1481794787[nl]675 UID5310-1481794787[nl]676 UID5311-1481794787[nl]677 UID5312-1481794787[nl]678 UID5313-1481794787[nl]679 UID5314-1481794787[nl]680 UID5315-1481794787[nl]681 UID5316-1481794787[nl]682 UID5317-1481794787[nl]683 UID5318-1481794787[nl]684 UID5319-1481794787[nl]685 UID5320-1481794787[nl]686 UID5321-1481794787[nl]687 UID5322-1481794787[nl]688 UID5323-1481794787[nl]689 UID5324-1481794787[nl]690 UID5325-1481794787[nl]691 UID5326-1481794787[nl]692 UID5327-1481794787[nl]693 UID5328-1481794787[nl]694 UID5329-1481794787[nl]695 UID5330-1481794787[nl]696 UID5331-1481794787[nl]697 UID5332-1481794787[nl]698 UID5333-1481794787[nl]699 UID5334-1481794787[nl]700 UID5335-1481794787[nl]701 UID5336-1481794787[nl]702 UID5337-1481794787[nl]703 UID5338-1481794787[nl]704 UID5339-1481794787[nl]705 UID5340-1481794787[nl]706 UID5341-1481794787[nl]707 UID5342-1481794787[nl]708 UID5343-1481794787[nl]709 UID5344-1481794787[nl]710 UID5345-1481794787[nl]711 UID5346-1481794787[nl]712 UID5347-1481794787[nl]713 UID5348-1481794787[nl]714 UID5349-1481794787[nl]715 UID5350-1481794787[nl]716 UID5351-1481794787[nl]717 UID5352-1481794787[nl]718 UID5353-1481794787[nl]719 UID5354-1481794787[nl]720 UID5355-1481794787[nl]721 UID5356-1481794787[nl]722 UID5357-1481794787[nl]723 UID5358-1481794787[nl]724 UID5359-1481794787[nl]725 UID5360-1481794787[nl]726 UID5361-1481794787[nl]727 UID5362-1481794787[nl]728 UID5363-1481794787[nl]729 UID5364-1481794787[nl]730 UID5365-1481794787[nl]731 UID5366-1481794787[nl]732 UID5367-1481794787[nl]733 UID5368-1481794787[nl]734 UID5369-1481794787[nl]735 UID5370-1481794787[nl]736 UID5371-1481794787[nl]737 UID5372-1481794787[nl]738 UID5373-1481794787[nl]739 UID5374-1481794787[nl]740 UID5375-1481794787[nl]741 UID5376-1481794787[nl]742 UID5377-1481794787[nl]743 UID5378-1481794787[nl]744 UID5379-1481794787[nl]745 UID5380-1481794787[nl]746 UID5381-1481794787[nl]747 UID5382-1481794787[nl]748 UID5383-1481794787[nl]749 UID5384-1481794787[nl]750 UID5385-1481794787[nl]751 UID5386-1481794787[nl]752 UID5387-1481794787[nl]753 UID5388-1481794787[nl]754 UID5389-1481794787[nl]755 UID5390-1481794787[nl]756 UID5391-1481794787[nl]757 UID5392-1481794787[nl]758 UID5393-1481794787[nl]759 UID5394-1481794787[nl]760 UID5395-1481794787[nl]761 UID5396-1481794787[nl]762 UID5397-1481794787[nl]763 UID5398-1481794787[nl]764 UID5399-1481794787[nl]765 UID5400-1481794787[nl]766 UID5401-1481794787[nl]767 UID5402-1481794787[nl]768 UID5403-1481794787[nl]769 UID5404-1481794787[nl]770 UID5405-1481794787[nl]771 UID5406-1481794787[nl]772 UID5407-1481794787[nl]773 UID5408-1481794787[nl]774 UID5409-1481794787[nl]775 UID5410-1481794787[nl]776 UID5411-1481794787[nl]777 UID5412-1481794787[nl]778 UID5413-1481794787[nl]779 UID5414-1481794787[nl]780 UID5415-1481794787[nl]781 UID5416-1481794787[nl]782 UID5417-1481794787[nl]783 UID5418-1481794787[nl]784 UID5419-1481794787[nl]785 UID5420-1481794787[nl]786 UID5421-1481794787[nl]787 UID5422-1481794787[nl]788 UID5423-1481794787[nl]789 UID5424-1481794787[nl]790 UID5425-1481794787[nl]791 UID5426-1481794787[nl]792 UID5427-1481794787[nl]793 UID5428-1481794787[nl]794 UID5429-1481794787[nl]795 UID5430-1481794787[nl]796 UID5431-1481794787[nl]797 UID5432-1481794787[nl]798 UID5433-1481794787[nl]799 UID5434-1481794787[nl]800 UID5435-1481794787[nl]801 UID5436-1481794787[nl]802 UID5437-1481794787[nl]803 UID5438-1481794787[nl]804 UID5439-1481794787[nl]805 UID5440-1481794787[nl]806 UID5441-1481794787[nl]807 UID5442-1481794787[nl]808 UID5443-1481794787[nl]809 UID5444-1481794787[nl]810 UID5445-1481794787[nl]811 UID5446-1481794787[nl]812 UID5447-1481794787[nl]813 UID5448-1481794787[nl]814 UID5449-1481794787[nl]815 UID5450-1481794787[nl]816 UID5451-1481794787[nl]817 UID5452-1481794787[nl]818 UID5453-1481794787[nl]819 UID5454-1481794787[nl]820 UID5455-1481794787[nl]821 UID5456-1481794787[nl]822 UID5457-1481794787[nl]823 UID5458-1481794787[nl]824 UID5459-1481794787[nl]825 UID5460-1481794787[nl]826 UID5461-1481794787[nl]827 UID5462-1481794787[nl]828 UID5463-1481794787[nl]829 UID5464-1481794787[nl]830 UID5465-1481794787[nl]831 UID5466-1481794787[nl]832 UID5467-1481794787[nl]833 UID5468-1481794787[nl]834 UID5469-1481794787[nl]835 UID5470-1481794787[nl]836 UID5471-1481794787[nl]837 UID5472-1481794787[nl]838 UID5473-1481794787[nl]839 UID5474-1481794787[nl]840 UID5475-1481794787[nl]841 UID5476-1481794787[nl]842 UID5477-1481794787[nl]843 UID5478-1481794787[nl]844 UID5479-1481794787[nl]845 UID5480-1481794787[nl]846 UID5481-1481794787[nl]847 UID5482-1481794787[nl]848 UID5483-1481794787[nl]849 UID5484-1481794787[nl]850 UID5485-1481794787[nl]851 UID5486-1481794787[nl]852 UID5487-1481794787[nl]853 UID5488-1481794787[nl]854 UID5489-1481794787[nl]855 UID5490-1481794787[nl]856 UID5491-1481794787[nl]857 UID5492-1481794787[nl]858 UID5493-1481794787[nl]859 UID5494-1481794787[nl]860 UID5495-1481794787[nl]861 UID5496-1481794787[nl]862 UID5497-1481794787[nl]863 UID5498-1481794787[nl]864 UID5499-1481794787[nl]865 UID5500-1481794787[nl]866 UID5501-1481794787[nl]867 UID5502-1481794787[nl]868 UID5503-1481794787[nl]869 UID5504-1481794787[nl]870 UID5505-1481794787[nl]871 UID5506-1481794787[nl]872 UID5507-1481794787[nl]873 UID5508-1481794787[nl]874 UID5509-1481794787[nl]875 UID5510-1481794787[nl]876 UID5511-1481794787[nl]877 UID5512-1481794787[nl]878 UID5513-1481794787[nl]879 UID5514-1481794787[nl]880 UID5515-1481794787[nl]881 UID5516-1481794787[nl]882 UID5517-1481794787[nl]883 UID5518-1481794787[nl]884 UID5519-1481794787[nl]885 UID5520-1481794787[nl]886 UID5521-1481794787[nl]887 UID5522-1481794787[nl]888 UID5523-1481794787[nl]889 UID5524-1481794787[nl]890 UID5525-1481794787[nl]891 UID5526-1481794787[nl]892 UID5527-1481794787[nl]893 UID5528-1481794787[nl]894 UID5529-1481794787[nl]895 UID5530-1481794787[nl]896 UID5531-1481794787[nl]897 UID5532-1481794787[nl]898 UID5533-1481794787[nl]899 UID5534-1481794787[nl]900 UID5535-1481794787[nl]901 UID5536-1481794787[nl]902 UID5537-1481794787[nl]903 UID5538-1481794787[nl]904 UID5539-1481794787[nl]905 UID5540-1481794787[nl]906 UID5541-1481794787[nl]907 UID5542-1481794787[nl]908 UID5543-1481794787[nl]909 UID5544-1481794787[nl]910 UID5545-1481794787[nl]911 UID5546-1481794787[nl]912 UID5547-1481794787[nl]913 UID5548-1481794787[nl]914 UID5549-1481794787[nl]915 UID5550-1481794787[nl]916 UID5551-1481794787[nl]917 UID5552-1481794787[nl]918 UID5553-1481794787[nl]919 UID5554-1481794787[nl]920 UID5555-1481794787[nl]921 UID5556-1481794787[nl]922 UID5557-1481794787[nl]923 UID5558-1481794787[nl]924 UID5559-1481794787[nl]925 UID5560-1481794787[nl]926 UID5561-1481794787[nl]927 UID5562-1481794787[nl]928 UID5563-1481794787[nl]929 UID5564-1481794787[nl]930 UID5565-1481794787[nl]931 UID5566-1481794787[nl]932 UID5567-1481794787[nl]933 UID5568-1481794787[nl]934 UID5569-1481794787[nl]935 UID5570-1481794787[nl]936 UID5571-1481794787[nl]937 UID5572-1481794787[nl]938 UID5573-1481794787[nl]939 UID5574-1481794787[nl]940 UID5575-1481794787[nl]941 UID5576-1481794787[nl]942 UID5577-1481794787[nl]943 UID5578-1481794787[nl]944 UID5579-1481794787[nl]945 UID5580-1481794787[nl]946 UID5581-1481794787[nl]947 UID5582-1481794787[nl]948 UID5583-1481794787[nl]949 UID5584-1481794787[nl]950 UID5585-1481794787[nl]951 UID5586-1481794787[nl]952 UID5587-1481794787[nl]953 UID5588-1481794787[nl]954 UID5589-1481794787[nl]955 UID5590-1481794787[nl]956 UID5591-1481794787[nl]957 UID5592-1481794787[nl]958 UID5593-1481794787[nl]959 UID5594-1481794787[nl]960 UID5595-1481794787[nl]961 UID5596-1481794787[nl]962 UID5597-1481794787[nl]963 UID5598-1481794787[nl]964 UID5599-1481794787[nl]965 UID5600-1481794787[nl]966 UID5601-1481794787[nl]967 UID5602-1481794787[nl]968 UID5603-1481794787[nl]969 UID5604-1481794787[nl]970 UID5605-1481794787[nl]971 UID5606-1481794787[nl]972 UID5607-1481794787[nl]973 UID5608-1481794787[nl]974 UID5609-1481794787[nl]975 UID5610-1481794787[nl]976 UID5611-1481794787[nl]977 UID5612-1481794787[nl]978 UID5613-1481794787[nl]979 UID5614-1481794787[nl]980 UID5615-1481794787[nl]981 UID5616-1481794787[nl]982 UID5617-1481794787[nl]983 UID5618-1481794787[nl]984 UID5619-1481794787[nl]985 UID5620-1481794787[nl]986 UID5621-1481794787[nl]987 UID5622-1481794787[nl]988 UID5623-1481794787[nl]989 UID5624-1481794787[nl]990 UID5625-1481794787[nl]991 UID5626-1481794787[nl]992 UID5627-1481794787[nl]993 UID5628-1481794787[nl]994 UID5629-1481794787[nl]995 UID5630-1481794787[nl]996 UID5631-1481794787[nl]997 UID5632-1481794787[nl]998 UID5633-1481794787[nl]999 UID5634-1481794787[nl]1000 UID5635-1481794787[nl]1001 UID5636-1481794787[nl]1002 UID5637-1481794787[nl]1003 UID5638-1481794787[nl]1004 UID5639-1481794787[nl]1005 UID5640-1481794787[nl]1006 UID5641-1481794787[nl]1007 UID5642-1481794787[nl]1008 UID5643-1481794787[nl]1009 UID5644-1481794787[nl]1010 UID5645-1481794787[nl]1011 UID5646-1481794787[nl]1012 UID5647-1481794787[nl]1013 UID5648-1481794787[nl]1014 UID5649-1481794787[nl]1015 UID5650-1481794787[nl]1016 UID5651-1481794787[nl]1017 UID5652-1481794787[nl]1018 UID5653-1481794787[nl]1019 UID5654-1481794787[nl]1020 UID5655-1481794787[nl]1021 UID5656-1481794787[nl]1022 UID5657-1481794787[nl]1023 UID5658-1481794787[nl]1024 UID5659-1481794787[nl]1025 UID5660-1481794787[nl]."
"DEBUG"	17748	"2019-01-12 17:14:46.739"	"POP3 External Account: Normal QUIT."
"POP3C"	17748	9065	"2019-01-12 17:14:46.739"	"91.xxx.xx.7"	"SENT: QUIT"
"POP3C"	17268	9065	"2019-01-12 17:14:46.754"	"91.xxx.xx.7"	"RECEIVED: +OK Bye-bye."
"DEBUG"	17268	"2019-01-12 17:14:46.759"	"Ending session 9065"
"DEBUG"	17068	"2019-01-12 17:14:46.759"	"Completed retrieval of messages from external account."
Post by jimimaseye » 2019-01-13 02:26
In the report above, is domain1 and domain2 both hosted on the exchange too? And which of them (on hms) is doing the external download? Which is the sending domain that doesn't get downloaded to hms when being sent to by the other? And could you show a screenshot of that external download setup please?
derelvis
Post by derelvis » 2019-01-13 16:27
domain1: hosted on exchange (MX record) and on hms
domain2: hosted on 1und1.de (MX record) and on hms
domain3: hosted on exchange (MX record) and on hms
domain4: hosted on exchange (MX record) and on hms
domain5: hosted on exchange (MX record) and on hms
All of the user mailboxes within the domains(1 to 5) on hms are being fetched via pop3 from the appropriate mailboxes hosted on the exchange (MX record) or in case of domain2 from 1und1.de (MX record).
domain1 does the external download where the problem occurs when mails are being send from a different domain only hosted on the exchange.
In the example the sending domain that doesn't get downloaded is "problematic-exchange-domain[dot]de" (I had to rename it because it showed up in whitelist with real name).
Example:
- user@problematic-exchange-domain[dot]de (only hosted on exchange) sends mail to user@domain1 (hosted on exchange with MX record and on HMS): mail gets delivered to exchange mailbox and can be seen in webmail or direct imap access to exchange or direct pop3 fetch in thunderbird from exchange but does not get fetched by pop3 download from exchange configured in HMS (screenshot) = NOK
- user@problematic-exchange-domain[dot]de (only hosted on exchange) sends mail to user@domain2 (hosted on 1und1.de with MX record and on HMS): mail gets delivered to 1und1 mailbox and also gets correctly fetched by pop3 download configured in HMS = OK
- user@any-other-domain-not-hosted-on-exchange sends mail to user@domain1 (or to any other user at any domain hosted on exchange and hms): mail gets delivered to exchange mailbox and also gets correctly fetched by pop3 download configured in HMS = OK
Post by jimimaseye » 2019-01-13 19:02
Have you tried deleting the external download and then set it up again? Or, as a period of concept, set up a 2nd external download under the same user with the same details. Theory being that as a new download it will not have any previous download uid data so everything will be new.
Also: what rules used do you have for this account? (Can you run the diag script again but include rules for this account when prompted).
derelvis
Post by derelvis » 2019-01-13 22:32
Yes, already tried this. All mails get downloaded newly again but again without any of the ones sended from the problematic exchange domain.
Did not yet try the second proposal because I fear that will again end up in hundreds of duplicate unread emails I will then have to cleanup again.
No rules within the affected mail account.
Some global rules active but only concerning SPAM and Antivirus including one against mail loop.
But as I can see in the logs they newer hit during the fetch because the mails simply don't get downloaded.
From all other senders rule processing shows up as expected for this account.
Log with global rules and rules for the affected account included:
2019-01-13   Hmailserver: 5.6.7-B2425
DOMAINS
                                                Selector:    dkim
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
        Greylisting:     False
GLOBAL RULES
  1, Against mail loop            Criteria:  Use AND
     Custom: X-hMailServer-LoopCount   Greater Than    0
                                  -----Actions-----
             Stop Rule Processing
  2, ExternalScore7               Criteria:  Use OR
     Custom: X-Spam-Level              Contains        *******
             Subject                   Regular Expr    (?i:^Virus found.*$)
             Subject                   Regular Expr    (?i:^Virus gefunden.*$)
                                  -----Actions-----
             Move To Folder                            SPAM
             Forward                                   abuse@Domain1.com
  3, SPAM                         Criteria:  Use OR
             Subject                   Contains        *****SPAM*****
             Subject                   Contains        [SPAM]
                                  -----Actions-----
             Move To Folder                            SPAM
IP RANGES
    No entries
AUTOBAN
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
  Routes:
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
DNSBL ENTRIES:
SURBL ENTRIES:
GREYLISTING:
  Greylisting:  False
WHITELISTING
              0.0.0.0            to    255.255.255.255              Brandschutz[@t]xxxxxx[dot]de
ANTIVIRUS
GENERAL:
     CLAMWIN:   False
     CUSTOMAV:  False
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
SSL CERTIFICATES
   No entries
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2019-01-13.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2019-01-13.log
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -      .
                        TCPIP       -      .
                        DEBUG       -    True
                        AWSTATS     -    True
SYSTEM TESTS
HMAILSERVER.INI
Type=              MSSQLCE
Username=
Port=              0
Server=
Internal=          1
Thanks again!
Post by jimimaseye » 2019-01-13 22:52
derelvis wrote:
2019-01-13 22:32
You could set up a temporary account with the same external download and view the results with an additional temporary email client imap connection to this temporary account to compare against the live account. (Once you're done it can then simply be deleted again).
derelvis
Post by derelvis » 2019-01-14 00:17
Done. Exact same result.
Only new thing I found was that 4 "undelivered mail returned to sender" (because of mail size exceeded) mails from the exchange domain where fetched in the meantime, but again nothing else from it.
