Delete EML files from the server (and keep DB updated)
anico64
Post by anico64 » 2018-12-18 13:21
Hi.
I have the problem that EML files are not deleted when I delete the email in my client.
So, now I have thousands of EML unused files that take up space in the server.
I searched in the forum a solution but I found only a solution for the reverse (rebuild DB starting from EML files).
I would delete all EML that are not linked in the DB (or that they are flagged as deleted).
Anyone have the solution ?
Thank you.
Alberto.
Configuration:
Hmail server: 5.6.6. B2383
DB: MSSQL CE
Client: Windows Live mail 2012
Emails: managed in IMAP
Re: Delete EML files from the server (and keep DB updated)
Post by Dravion » 2018-12-18 13:26
Take a look at this tool, this should do the trick
viewtopic.php?f=10&t=31606
64-Bit builds of hMailserver
Post by mattg » 2018-12-18 14:19
It probably because your mail client doesn't expunge
without expunging, mail is only marked for deletion, not actually deleted.
What mail client do you use?
Post by jimimaseye » 2018-12-18 14:44
Also viewtopic.php?f=20&t=27646 might help.
But follow mattg's advice first.
