ERROR starting hmailServer
plus-pc
Post by plus-pc » 2018-12-18 10:19
I use hmailserver on a virtual machine (HyperV) on Windows 10 Pro - after some days and restarts I get the following error when I try to log in the administrative console:
service restart does not solve the problem.
The following link does not solve the problem: https://support.microsoft.com/de-at/hel ... ed-error-m
Has anyone similar problem?
Re: ERROR starting hmailServer
Post by mattg » 2018-12-18 11:18
Check the DCOM permissions for the user that you are running the hMailserver as
https://www.hmailserver.com/documentati ... ermissions
also, make sure that the Admin GUI is closed when you re-start the hMailserver service
Post by Dravion » 2018-12-18 11:19
Use this script to ReRegister hMailServer and fix the Error
viewtopic.php?f=21&t=33357
plus-pc
Post by plus-pc » 2018-12-20 12:49
DCOM permission now are set correct, but the error still appears and hmailserver does not work - so not only the administrativ console won´t open, also the mails were not accepted...
Post by mattg » 2018-12-20 13:49
Have you rebooted that server?
If not, can you
plus-pc
Post by plus-pc » 2018-12-20 16:37
yes - I did and yes I can, it is a HyperV virtual machine for testing;
the problem is solved by now - I´m not sure, if the reregistering help´s (by the way - the script above does not work - I did it right on commandline)
Thank´s everyone who try´s to help!!!!!
