hmail Server trouble since 1 week
PeterP
Post by PeterP » 2018-11-22 14:53
hello guys,
i have inherited a hmail Server which is on a Server 2008 R2 and use a SQL database.
It is only used as "IMAP Share", which is used with Outlook 2016 Client, this means there are created a Domain with accounts >100 which does not communicate with other Services. It only provide the Mailbox, which the users interate in Outlook and fill with data..
now, since 1 week the users are claiming that suddenly all mails are not visible any more and that the sync off hmail seems to be interrupted.
When i check the loggs, i see that it created suddenly dumps since few days and that it has ERROR_hmailserver_logs nearly every day ;(
Can somehow help where to start from and how i am able to fix the Problems. thanks in advance !
PeterP
dmp.zip
(487.08 KiB) Downloaded 37 times
Re: hmail Server trouble since 1 week
Post by Dravion » 2018-11-22 17:34
After taking a look, there are
"ERROR" 2360 "2018-11-22 06:51:09.447"
"Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
Bad allocation is Virtual Memory related. Plain and simple, your RAM Memory Modules (Hardware) are faulty and needs to be replaced.
Its not clear which Memory Module is fault, so you can check it by trial and error, but this will cost time and effort or you just replace
it simply by brand new modules.
But: Test your RAM Modules, even if they are new, they can allready be faulty. New isnt a gurantee and i had seen a few Modules
which where faulty fresh from the shop and you noticed it only if you use Apps which needs more Memory.
PeterP
Post by PeterP » 2018-11-23 10:13
thanks dravion,
i changed all RAM Modules, but get still Errors.. Now i will test the old RAM Modules first until i change the ram again.
PeterP
Post by PeterP » 2018-11-23 13:57
the RAM Modules seems to be okay, no error detected ;( I will try an other RAM test Software to verify.
I just look and see following Errors, couls it be the Harddisk? Would a checkdisk help?
"ERROR" 2372 "2018-11-22 00:17:23.107" "Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR" 2372 "2018-11-22 00:17:23.107" "Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - e:\hMailServer\Data\.projects\10041982\D3\{D34D04E3-66A1-429D-83AB-688D3C7168A4}.eml"
"ERROR" 2372 "2018-11-22 00:17:23.107" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 2372 "2018-11-22 00:17:23.108" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 213, Data: 3om8 UID FETCH 1506:1543,1545:1689,1691:2099,2101:2208,2210:2214,2216:2330,2334:2338,2340:2345,2347:2393,2398,2400:2459,2461:2578,2580:2582,2585:2594,2598:2606,2619 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: 10.80.247.68"
"ERROR" 2372 "2018-11-22 00:17:23.108" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 2372 "2018-11-22 00:17:23.179" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2018-11-22 001723_{B8347656-8E0A-47B8-B7CD-43DFC6C511B9}.dmp"
"ERROR" 2316 "2018-11-22 00:40:55.536" "Severity: 3 (Medium), Code: HM5125, Source: IMAPFolders::Refresh(), Description: Unable to retrieve folder list for account. 100K+ loops trying to sort. Account: 143, Parent: -1"
"ERROR" 2348 "2018-11-22 01:17:22.860" "Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR" 2348 "2018-11-22 01:17:22.861" "Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - e:\hMailServer\Data\.projects\10041982\08\{08D6CCE4-6B16-4FA7-BE28-F0B5337B9275}.eml"
"ERROR" 2348 "2018-11-22 01:17:22.861" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 2348 "2018-11-22 01:17:22.862" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 213, Data: zi58 UID FETCH 1516:1543,1545:1689,1691:2099,2101:2208,2210:2214,2216:2330,2334:2338,2340:2345,2347:2393,2398,2400:2459,2461:2578,2580:2582,2585:2594,2598:2606,2619 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: 10.80.247.68"
"ERROR" 2348 "2018-11-22 01:17:22.862" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 2348 "2018-11-22 01:17:22.927" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2018-11-22 011722_{7A126CBC-62D2-45F2-9286-0D7D17141863}.dmp"
"ERROR" 2320 "2018-11-22 01:41:04.468" "Severity: 3 (Medium), Code: HM5125, Source: IMAPFolders::Refresh(), Description: Unable to retrieve folder list for account. 100K+ loops trying to sort. Account: 143, Parent: -1"
"ERROR" 2372 "2018-11-22 02:17:24.124" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 2372 "2018-11-22 02:17:24.126" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 213, Data: ap0v UID FETCH 1526:1543,1545:1689,1691:2099,2101:2208,2210:2214,2216:2330,2334:2338,2340:2345,2347:2393,2398,2400:2459,2461:2578,2580:2582,2585:2594,2598:2606,2619 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: 10.80.247.68"
"ERROR" 2372 "2018-11-22 02:17:24.127" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 2372 "2018-11-22 02:17:24.179" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2018-11-22 021724_{DBC75DD1-EFF7-4703-B48D-7A309EC1D12C}.dmp"
"ERROR" 2344 "2018-11-22 02:41:11.600" "Severity: 3 (Medium), Code: HM5125, Source: IMAPFolders::Refresh(), Description: Unable to retrieve folder list for account. 100K+ loops trying to sort. Account: 143, Parent: -1"
"ERROR" 2324 "2018-11-22 03:17:24.764" "Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR" 2324 "2018-11-22 03:17:24.764" "Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - e:\hMailServer\Data\.projects\10041982\D3\{D34D04E3-66A1-429D-83AB-688D3C7168A4}.eml"
"ERROR" 2324 "2018-11-22 03:17:24.764" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 2324 "2018-11-22 03:17:24.765" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 213, Data: anje UID FETCH 1535:1543,1545:1689,1691:2099,2101:2208,2210:2214,2216:2330,2334:2338,2340:2345,2347:2393,2398,2400:2459,2461:2578,2580:2582,2585:2594,2598:2606,2619 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: 10.80.247.68"
"ERROR" 2324 "2018-11-22 03:17:24.765" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 2324 "2018-11-22 03:17:24.831" "Severity: 1 (Critical), Code: HM5519, Source: StackLogger::Log, Description: An error has been detected. A mini dump has been written to C:\Program Files (x86)\hMailServer\Logs\minidump_2018-11-22 031724_{F739BBF7-4C4D-4409-978E-0E81F49FE0FA}.dmp"
"ERROR" 2348 "2018-11-22 03:41:15.254" "Severity: 3 (Medium), Code: HM5125, Source: IMAPFolders::Refresh(), Description: Unable to retrieve folder list for account. 100K+ loops trying to sort. Account: 143, Parent: -1"
"ERROR" 2332 "2018-11-22 04:17:25.051" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 2332 "2018-11-22 04:17:25.052" "Severity: 3 (Medium), Code: HM4227, Source: File::ReadFile, Description: An unknown error occurred while reading file from disk."
"ERROR" 2332 "2018-11-22 04:17:25.052" "Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR" 2332 "2018-11-22 04:17:25.052" "Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. - e:\hMailServer\Data\i.projects\10041982\D3\{D34D04E3-66A1-429D-83AB-688D3C7168A4}.eml"
Post by Dravion » 2018-11-23 14:24
In this log, there a bad alloc again. We need to get rid of your RAM Memmory Module Problems first.
I highly recommend using Memtedt86+
https://www.memtest86.com/download.htm
Burn it to a DVD and boot from it.
Dont use RAM Module Testsoftware which runs on top of Windows because it cannot test blocks occupied by Windows.
PeterP
Post by PeterP » 2018-11-26 17:37
Hi Dravion,
all RAM Modules are tested with memtest86 successfully and no errors was found ;(
Any other idea what i can do?
PeterP
Post by Dravion » 2018-11-26 18:00
Ok, delete your old hMailServer logs and provide new hMailServer logs (after your checked and replaced the RAM Modules
and attach it to your next repllx. Also attach your latest crahsdump (*.dmp) file of hMailSerever.
We also need to know your excat Mainboard Info (Serialnumber, Brand and Modelname), the Name and serial Number of your
installed RAM Modules (if you have mixed RAM Modules from various Manufacturers) add the Infos to it.
Please provide a few infos about the Antimaleware Software your are using (Name, if its a free version, ect) and
what version of Windows your are running (for example Windows 10 1803 x64 or Windows Server 2016 ect).
PeterP
Post by PeterP » 2018-11-30 10:54
thanks Davion for your help.
I will take the Server offline today and clone the HDDisk. Somehow i see in the logs "An unknown error occurred while reading file from disk" and i hope the new disk fixes the Problems..
The Hardware is running since several years and as i already told i changed the memory modules, where no error was found with memtest86.
dmp.7z
(69.36 KiB) Downloaded 32 times
blasto
Post by blasto » 2018-12-01 22:59
Dear all,
in my opinion the issue mentioned in this post by PeterP is not an hardware error. I've encountered the same and posted here viewtopic.php?f=7&t=32554. Still having the same problem when a new "Outlook 2016" client connects and starts to download imap mail. No other client cause this error.
I tested the memory by memtest, I changed them with new ones, I've changed the drive, I even tried on a completely different server. But the same read file and bad allocation errors keep happening when a new outlook client initiates an imap download.
I believe dev team should look into this closer...
Thanks!
Post by Dravion » 2018-12-02 04:51
Hmm, ok.
Please add your latest DMP and logs files.
What hMailServer version exactly do you run and does this only happen durning Outlook IMAP
Operations?
Do you have shared Mailboxes where multiple Users
accessing the Mailbox the same time?
Ps. if this Situation persist, would it be possible to remotely login via Teamviewer to the faulty hMailServer Machine? Maybe we need to run your hMailServer Installation in the Dev Enviroment in Debuggingmode to find out which Instruction exactly causes your Access Violation.
Post by Dravion » 2018-12-02 13:05
Ok, i checked your Crahsdumps with in the Debugger
Do you really run this hMailServer for all your 100 Mailboxes on Windows 7 SP1? (see: BUILDLAB_STR: win7sp1_gdr)
Summary
The Error occurs while executing the C++ new() operator from the MS CRuntime (see: msvcr120.dll!operator_new)
The new command in C++ is used to allocated Virtual Memory (in lame mans term, Memory) which fails because the
command cannot execute successfully. In general, if a Program cannot reserve Memory it cannot funtioning correctly,
it will simply crash. The Dumpfile isnt created by hMailServer itself, the Programcrash is noticed by the Windows Kernel
which executes WERFAULT.EXE in Windows System Directory to dump relavant Memory state into the DMP Crashump file.
In most cases, this type of Error is caused by faulty Hardware (like RAM Memory Modules) but isnt restricted to it.
Windows (like any modern Operating System) uses a Memory Managementdesign which is called "Virtual Memory".
The cool thing about it is, any Program has its own, isolated RAM Area without interferend Programs which can cause
Problems. Virtual Memory on the other side isnt restricted to RAM Chips, its also takes advandage of your Harddisk/SSD
in an File (for example: C:\Pagefile.sys) which simply can be used if you running out of RAM Memmory space for your App
and its called "swapping". Of cause Harddisks and SSD's are way slower and thats why you should use lots of RAM and
a OS which can handle lots of RAM:
Conclusion
If your REALLY and CAREFULLY tested your RAM Modules, next is check your Harddisk/SSD and disable
Windows swapping to C:\Pagefile.sys.Next update your OS to the latest Servicepack+Updates and Device drivers
(espacially Chipsetdrivers) and lookup if your Mainboard needs some BIOS or UEFI-Firmware updates.
0:056> !analyze -v
* Exception Analysis *
GetUrlPageData2 (WinHttp) failed: 12007.
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
Timeline: !analyze.Start
Time: 2018-12-02T10:39:35.682Z
Diff: 184286682 mSec
Timeline: Dump.Current
Time: 2018-11-30T07:28:09.0Z
Diff: 0 mSec
Timeline: Process.Start
Time: 2018-11-30T04:00:01.0Z
Diff: 12488000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
CONTEXT: (.ecxr)
eax=0777ea14 ebx=0777eccc ecx=00000003 edx=00000000 esi=73b3c7fc edi=0777eab4
eip=75c0c52f esp=0777ea14 ebp=0777ea64 iopl=0 nv up ei pl nz ac pe nc
cs=0023 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000216
KERNELBASE!RaiseException+0x58:
75c0c52f c9 leave
Resetting default scope
FAULTING_IP:
KERNELBASE!RaiseException+58
75c0c52f c9 leave
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 75c0c52f (KERNELBASE!RaiseException+0x00000058)
ExceptionCode: e06d7363 (C++ EH exception)
ExceptionFlags: 00000001
NumberParameters: 3
Parameter[0]: 19930520
Parameter[1]: 0777eab4
Parameter[2]: 73b3c7fc
BUGCHECK_STR: CPP_EXCEPTION
DEFAULT_BUCKET_ID: CPP_EXCEPTION
ERROR_CODE: (NTSTATUS) 0xe06d7363 - <Unable to get error code text>
EXCEPTION_CODE: (NTSTATUS) 0xe06d7363 - <Unable to get error code text>
EXCEPTION_CODE_STR: e06d7363
EXCEPTION_PARAMETER1: 19930520
EXCEPTION_PARAMETER2: 0777eab4
EXCEPTION_PARAMETER3: 73b3c7fc
WATSON_BKT_PROCSTAMP: 5a32ccc1
WATSON_BKT_PROCVER: 1.0.0.1
WATSON_BKT_MODULE: KERNELBASE.dll
WATSON_BKT_MODSTAMP: 56a1c79e
WATSON_BKT_MODOFFSET: c52f
WATSON_BKT_MODVER: 6.1.7601.19135
MODULE_VER_PRODUCT: Microsoft® Windows® Operating System
BUILD_VERSION_STRING: 6.1.7601.19135 (win7sp1_gdr.160121-1718)
MODLIST_WITH_TSCHKSUM_HASH: 32885e1dfa0b8633fc15779fb3b89540d7a9fd1b
MODLIST_SHA1_HASH: 8e4dfdee664f51b5cf782140331dafc6bd664f4a
DUMP_FLAGS: 0
DUMP_TYPE: 2
PROCESS_NAME: unknown
ANALYSIS_SESSION_HOST: CAMELOT
ANALYSIS_SESSION_TIME: 12-02-2018 11:39:35.0682
ANALYSIS_VERSION: 10.0.17763.132 x86fre
THREAD_ATTRIBUTES:
PRIMARY_PROBLEM_CLASS: CPP_EXCEPTION
PROBLEM_CLASSES:
Type: [@APPLICATION_FAULT_STRING]
Class: Primary
Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
BUCKET_ID
Data: Add
String: [CPP_EXCEPTION]
PID: [Unspecified]
TID: [Unspecified]
Frame: [0]
LAST_CONTROL_TRANSFER: from 73b29339 to 75c0c52f
STACK_TEXT:
0777ea64 73b29339 e06d7363 00000001 00000003 KERNELBASE!RaiseException+0x58
0777eaa4 73b6da6a 0777eab4 73b3c7fc 73b3d1cc msvcr120!_CxxThrowException+0x5b
0777eac4 003a164f 015f7c20 3f191eda ffffffff msvcr120!operator new+0x50
WARNING: Stack unwind information not available. Following frames may be wrong.
0777ec70 003a0648 0777eccc 0777edb4 30351958 hMailServer+0x21164f
0777ee0c 0038b3a3 0777eef4 186492b8 0c84bdc8 hMailServer+0x210648
0777ef6c 003953e2 0777efc4 186492b8 0c84bdc8 hMailServer+0x1fb3a3
0777f0bc 00399b24 0777f148 186492b8 0c84bdc8 hMailServer+0x2053e2
0777f220 0039bd86 08b27d40 08a35c48 3f19018a hMailServer+0x209b24
0777f320 0039c5de 0777f450 186493e0 0777f4f4 hMailServer+0x20bd86
0777f330 002c5921 0777f450 3f19065e 00000000 hMailServer+0x20c5de
0777f4f4 002c8a58 0777f584 00000046 0777f5f8 hMailServer+0x135921
0777f504 002c3dba 0777f584 0777f594 3f190752 hMailServer+0x138a58
0777f5f8 002bb5c4 0777f680 00000046 00000000 hMailServer+0x133dba
0777f60c 002c9c97 0777f640 0777f668 3f19040a hMailServer+0x12b5c4
0777f6a0 0023ec75 00916700 41cf5790 0777f6d0 hMailServer+0x139c97
0777f6fc 002411f5 00916700 0777f748 3f190592 hMailServer+0xaec75
0777f738 00241114 0777f748 06d82a88 00000000 hMailServer+0xb11f5
0777f750 002b02a0 3f190536 00938410 06d82a88 hMailServer+0xb1114
0777f79c 001e15c7 0777f914 3f190562 77a4e262 hMailServer+0x1202a0
0777f7c8 001e1a89 3f190a02 00938410 06d82a88 hMailServer+0x515c7
0777f8a8 001e19f5 0777f92c 0777f90c 3f190a4a hMailServer+0x51a89
0777f8e0 002b01ad 0777f92c 0777f90c 0777f92c hMailServer+0x519f5
0777f954 002d05b6 3f190b2a 00938410 0777fac4 hMailServer+0x1201ad
0777f980 001e15c7 0777fbd4 3f190b06 004aa850 hMailServer+0x1405b6
0777f9ac 001e1a89 3f190826 00938410 0777fac4 hMailServer+0x515c7
0777fa8c 001e19f5 0777fc34 0777fbcc 3f19086e hMailServer+0x51a89
0777fac4 002d2608 0777fc34 0777fbcc 3f190e26 hMailServer+0x519f5
0777fc8c 002d1e0f 06d82a88 06d32dc8 3f190e12 hMailServer+0x142608
0777fcb8 002d3d4d 00938410 00000000 00000000 hMailServer+0x141e0f
0777fce4 002d3f1d 0777fd0c 0777fd0c 3f190f9e hMailServer+0x143d4d
0777fd34 0023ec75 0098e388 06d81b78 0777fd64 hMailServer+0x143f1d
0777fd90 002411e1 0098e388 0777fddc 3f190f66 hMailServer+0xaec75
0777fdcc 00241114 0777fddc 00938410 00000000 hMailServer+0xb11e1
0777fde4 002d2825 3f190c26 00000000 0098c160 hMailServer+0xb1114
0777fe8c 003fc7ee 3f190c1e 00000000 009876a8 hMailServer+0x142825
0777feb4 73b3c01d 0098c160 19399752 00000000 hMailServer+0x26c7ee
0777feec 73b3c001 00000000 0777ff04 76cf338a msvcr120!_callthreadstartex+0x1b
0777fef8 76cf338a 00986f18 0777ff44 77a59a02 msvcr120!_threadstartex+0x7c
0777ff04 77a59a02 00986f18 56956389 00000000 kernel32!BaseThreadInitThunk+0xe
0777ff44 77a599d5 73b3bfb4 00986f18 ffffffff ntdll!__RtlUserThreadStart+0x70
0777ff5c 00000000 73b3bfb4 00986f18 00000000 ntdll!_RtlUserThreadStart+0x1b
THREAD_SHA1_HASH_MOD_FUNC: bdcc59331263125a8ab02c88c291e738365043b9
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: dedd148452f82167fdde2c935f4830af7145b176
THREAD_SHA1_HASH_MOD: 4bf7538c1feb4c5be84f8e697043fcb7bc30ccfc
FOLLOWUP_IP:
msvcr120!operator new+50 [f:\dd\vctools\crt\crtw32\heap\new.cpp @ 62]
73b6da6a cc int 3
FAULT_INSTR_CODE: ce856cc
FAULTING_SOURCE_LINE: f:\dd\vctools\crt\crtw32\heap\new.cpp
FAULTING_SOURCE_FILE: f:\dd\vctools\crt\crtw32\heap\new.cpp
FAULTING_SOURCE_LINE_NUMBER: 62
FAULTING_SOURCE_CODE:
No source found for 'f:\dd\vctools\crt\crtw32\heap\new.cpp'
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: msvcr120!operator new+50
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: msvcr120
IMAGE_NAME: msvcr120.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 524f7ce6
STACK_COMMAND: ~56s ; .ecxr ; kb
BUCKET_ID: CPP_EXCEPTION_msvcr120!operator_new+50
FAILURE_EXCEPTION_CODE: e06d7363
FAILURE_IMAGE_NAME: msvcr120.dll
BUCKET_ID_IMAGE_STR: msvcr120.dll
FAILURE_MODULE_NAME: msvcr120
BUCKET_ID_MODULE_STR: msvcr120
FAILURE_FUNCTION_NAME: operator_new
BUCKET_ID_FUNCTION_STR: operator_new
BUCKET_ID_OFFSET: 50
BUCKET_ID_MODTIMEDATESTAMP: 524f7ce6
BUCKET_ID_MODCHECKSUM: fb320
BUCKET_ID_MODVER_STR: 12.0.21005.1
BUCKET_ID_PREFIX_STR: CPP_EXCEPTION_
FAILURE_PROBLEM_CLASS: CPP_EXCEPTION
FAILURE_SYMBOL_NAME: msvcr120.dll!operator_new
FAILURE_BUCKET_ID: CPP_EXCEPTION_e06d7363_msvcr120.dll!operator_new
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/un ... Retriage=1
TARGET_TIME: 2018-11-30T07:28:09.000Z
OSBUILD: 7601
OSSERVICEPACK: 19135
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 274
PRODUCT_TYPE: 3
OSPLATFORM_TYPE: x86
OSNAME: Windows 7
OSEDITION: Windows 7 Server (Service Pack 1) Enterprise TerminalServer SingleUserTS
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-01-22 07:09:33
BUILDDATESTAMP_STR: 160121-1718
BUILDOSVER_STR: 6.1.7601.19135
ANALYSIS_SESSION_ELAPSED_TIME: 17cd
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:cpp_exception_e06d7363_msvcr120.dll!operator_new
FAILURE_ID_HASH: {54b9cd6c-8bc9-51dd-2cc6-a69b6e43fd3d}
Followup: MachineOwner
PeterP
Post by PeterP » 2018-12-03 18:00
thanks Dravion for your Information.
The OS is Windows Server 2008 R2 .
Now i replaced the HDD to SSD and the error (minidumps, similar error log files..) seems still to be there ;(
After the 16GB RAM was checked and replaced the hdd also did not fix the issue .. .
With the change of the hdd i also changed the pagefile.sys location, means it was created new..
Should i disable the Pagefile.sys completely anyway to see if that helps?
Post by Dravion » 2018-12-03 18:25
Yes, please do so and look carefully at the new logfiles. Try also to update your drivers (i highly recommend snappy, its opensource and finds allmost any new driver).Its User interface is a bit hacky, but its free and works. Use the Lite Installer,click download indexes only and select "This PC" to avoid downloading the fulll 14 GBytes.
https://sdi-tool.org/download/
PeterP
Post by PeterP » 2018-12-04 13:00
thanks davion for your help,
disabling the swap did not solve the problems.
I am not able to renew all drivers from this "old" Hardware which runs the last 4-5 years without any problems.. I get in trouble when it comes to bigger problems afterwards. there are more that 500Gb data on hmail ;(..
I have to look how this old machine can be backed up first.
Is there any maintance which i can do through the hmail data, perhaps there is some corruptness on it.
RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: x.x.x.x"
"ERROR" 3244 "2018-12-04 09:44:56.382" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 3256 "2018-12-04 09:54:58.702" "Severity: 3 (Medium), Code: HM5125, Source: IMAPFolders::Refresh(), Description: Unable to retrieve folder list for account. 100K+ loops trying to sort. Account: 143, Parent: -1"
"ERROR" 3116 "2018-12-04 10:03:11.841" "Severity: 3 (Medium), Code: HM5042, Source: File::ReadTextFile, Description: An unknown error occurred while reading a text file from disk."
"ERROR" 3116 "2018-12-04 10:03:11.857" "Severity: 1 (Critical), Code: HM5062, Source: IMAPFetch::ReportCriticalError_, Description: ERROR HM10001 - IMAP FETCH: Error when loading MIME message. -xxx\C4\{C4E49F2C-A85E-4356-93F2-35E14420BD99}.eml"
"ERROR" 3116 "2018-12-04 10:03:11.857" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 3116 "2018-12-04 10:03:11.857" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 113, Data: h34x UID FETCH 1853:2507,2509:2718,2720:3138,3140:3313,3315:3317 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: x,x.x.x"
"ERROR" 3116 "2018-12-04 10:03:11.857" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 3260 "2018-12-04 10:03:12.418" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 3260 "2018-12-04 10:03:12.418" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 665, Data: 3iyv UID FETCH 61:159,162:186,188:199,201:242,244:246,248:258,260:271,273:294,296,298:299,301:304,306,309:329,331:336,338:342,344:353,355:360,362:363,365:373,375:377,380,383:401,403:406,408:415,417:454,456:465,469:475,477,479:489,491:549,551:559,561:584,586:591,594:604,606:618,620,622:625,628:630,632:647,649:650,652:660,662:664,666,668:677,680:685,688:760,762:766,769:772,774:782,785,787,789:821,823:825,827:830,832:936,938:940,943:948,950:1009,1011:1028,1030:1032,1034,1037:1089,1091:1114,1116:1123,1125,1127:1139,1141:1147,1149:1160,1162:1278,1280:1306,1308:1310,1312:1337,1339:1457,1459:1460,1462,1464:1494,1499 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: x.x.x.x"
"ERROR" 3260 "2018-12-04 10:03:12.418" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask', Message: bad allocation"
"ERROR" 3256 "2018-12-04 10:07:02.612" "Severity: 2 (High), Code: HM4208, Source: File::ReadFile(), Description: An error occured when reading file., Message: bad allocation"
"ERROR" 3256 "2018-12-04 10:07:02.612" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 998, Data: 9ysf UID FETCH 1401,1403,1405:1436,1440:1453,1456:1477,1479:1482,1485:1490,1492:1495,1497:1561,1564:1581,1584:1593,1595:1608,1610,1612:1617,1619:1624,1626,1628,1630:1637,1639:1643,1646:1647,1649:1654,1656:1661,1663:1665,1667:1676,1678:1680,1682:1692,1695:1724,1726:1727,1729:1742,1744:1756,1760,1762:1765,1767:1770,1772:1811,1813:1814,1816:1854,1856:1867,1869:1874,1876:1925,1929:1941,1943:1965,1967:1989,1992:2005,2007,2010:2021,2023:2049,2051:2069,2071:2090,2093:2103,2105:2107,2109:2110,2112:2117,2120:2124,2127:2132,2134:2135,2137:2141,2143:2156,2159:2161,2163:2180,2182:2192,2194:2216,2218:2232,2234:2235,2237:2241,2243:2258,2260:2264,2266:2292,2295:2314,2316:2333,2335:2343,2345:2455,2457:2467,2469:2486,2488:2498,2500,2502:2515,2517:2526,2529:2531,2533:2552,2554:2560,2562:2568,2570:2646,2648:2649,2652,2654:2690,2692:2694,2696:2700,2702:2706,2708:2719,2721:2728,2730:2736,2738:2781,2784:2815,2817:2834,2837:2847,2851:2869,2871,2873,2875:2895 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: x.x.x.x"
Post by mattg » 2018-12-04 13:26
PeteP, what version of hMailserver are you running?
This looks like an old issue with a race condition that appeared suddenly many many versions ago
Post by Dravion » 2018-12-04 16:05
Ok Pete,
Take into account (like Matt allready) said, it could be a older hMailServer Error. Unless you are running versio 5.3 or ealier,
your should upgrade to the latest, official Production release - which is today: hMailServer 5.6.7 - Build 2425
Download it from:
https://www.hmailserver.com/download
Updating is verry simple. Just run the installer and you will be fine.
Of course, you should backup your hMailServer installation.
Backupprocedures:
* Your DATA-Folder (default location is: C:\Program Files (x86)\hMailServer\Data)
-> It contains any Email your ever send our receiced with hMailServer as a bunch single, independent *.eml files
* Backup the Database, which hMailServer is connected to (can be MS-SQL CE, MS-SQL, MySQL/MariaDB or PostgreSQL)
-> You should backup and restore it with the Backup/Restore tools of your SQL-Database
For smaller Installations, we recommend the internal hMailServer Backupsystem, but its not made to handle 500 GBytes
of Inbox Data.
Jimmie wrote a nice Tutorial regarding backup, take a look at it
viewtopic.php?f=21&t=28139
PeterP
Post by PeterP » 2018-12-05 09:59
it is the Version 5.6.7-B2425 ;(
perhaps i should reinstall it over the night?no Settings will be deleted or?
i checked all the Settings from the hmail Server twice and try to understand them.
Our Setting is quit easy we have 3 Domains with around 400 accounts. Around 100 accounts are only active. several of theses accounts are >30Gb.
thhe hole accouts are only used as imap storage box, there is no connection to any domain. the boxes are added to Outlook Client and the customers are moving there mails in that .
there are few Settings which are not clear for me , but i am little careful about changing them for testing, like disbling cache in the Performance tap and threading Settings.. whatever perhaps there are some advises which Settings are useful for our set up and which not..
Post by jimimaseye » 2018-12-05 10:01
PeterP wrote:
2018-12-05 09:59
If you want, run this and post the results, we can review and guide you: viewtopic.php?f=20&t=30914
PeterP
Post by PeterP » 2019-01-06 19:47
thanks jimimaseye,
attached you will find the diagnostic.
The Database was on an other machine with SQL EXPRESS 2014.
I changed the machine and the database is now on an SQL EXPRESS2017. Somewhere i read this could also be the reason for my troubles..
thanks in advanced
PeterP
HMSDiagnostic_201901041907.zip
(2.4 KiB) Downloaded 26 times
Post by mattg » 2019-01-06 23:22
on the ip ranges page there is a 'default' button - push that (You currently have two IP ranges covering the same internet range that will allow your machine be used to send spam to the world...
Also, there are some errors present in your error's log
Can you post the contents of that log
Post by mattg » 2019-01-06 23:28
I'd also look your database and fix the paths as you have a custom path and some messages at least that have full paths stored for them in the database. There is likely a heap of messages that your hmailserver can't find due to the data folder change
PeterP
Post by PeterP » 2019-01-07 17:52
thanks mattg for your help!
the crashes are the logs witch i provided in the post at the beginning. i have still the same Problems as before, also after updating and moving the SQL database database and changing the RAM and HD from the Server..
perhaps your mentioned changes are also a reason for the crashes..
regarding "the ip ranges page there is a 'default' button" - do you mean the tab und advanced / tcp/ip ports? there i have the following four entries:
0.0.0.0 / 500 /SMTP
0.0.0.0 / 25 /SMTP
0.0.0.0 / 143 / IMAP
0.0.0.0 / 110 /POP3
there is also a Default button, i guess i have to mark one of the Settings and make it to Default.
Because i am using only IMAP i would say i have to mark the IMAP Setting and click on Default , or?
POP3 is not used , can i delete this entry? SMTP i dont know if it is relevant, the accounts are mapped as "stand alone" imap accounts , no emails can be send out through the imap accounts. emails are only used from few groups as email-share, they are moving other mails into this imap accounts ..
regarding database and fix path. What you mean with that? Do you mean the SQL Database or somewhere in hmail?
PeterP
Post by Dravion » 2019-01-07 22:18
Ok, this is really getting weird.
Can you update to a Win10 or Windowd Server 2016 Version?
I also had a Customer where Hardware was ok but there where Micropeaks in the Powergrid which caused some Problems. We solved it by setting up a
UPS and plugged it into the Server and connecting the UPS to the Powergrid. Allmost instanteanously the Problems didnt reappear anymore.
You have to keep in Mind: Your Error is "bad alloc"
This is basicly just a Memory block which hMailServer is trying to request from Windows but Windows response was "bad malloc.
hMailServer didnt create the Error, its only the Messenger of Windows fault.
But Windows doesnt do it without a reason.
It relies on healty Hardware and drivers to accomplish its duties.
Post by mattg » 2019-01-07 22:54
@Dravion
From the diagnostics, the data directory is on a different drive, and the SQL Server is on a separate machine
I'm not sure if those drives / machines where tested
@PeterP
'IP ranges' is completely different section that TCP/IP settings
From the TCP/IP ports section, go up about 5 branches, past 'server messages', 'performance', 'mirror' and 'incoming relays'
Whilst IPranges will be an issue, the paths will be a bigger issue, and the hardware errors are likely to be fatal one day
Post by Dravion » 2019-01-08 04:49
@MattG
Yeah, there are multiple errors in the log. The cannot read text file is of course Storage related.
Maybe copying the DATA folder to the hMailServer Computer and letting hMailServer.ini pointing to it could solve the Problem.
Post by mattg » 2019-01-08 06:35
Dravion wrote:
2019-01-08 04:49
ONLY if all paths are removed form the database first
PeterP
Post by PeterP » 2019-01-08 13:37
The Hard drive from hmail was completely changed where. The hardware of SQL is moved to new hardware..
A Storage problem I can not image of.. Will check if I could migrate the hole hmail to new hardware :(
I checked the path values on sql, and there is a mix between full path and not full path. What is the best way to clean this? any sql statement? The hmail database is around 400MB ;(
I also found the IP Ranges Setting, I pushed the button. Will check if I can adjust the allow connections settings and other.. I dont eh in I need SMTP and Pop3 and anti-virus and anti-spam setting.. This computer is not connected to outside..
PeterP
Post by jimimaseye » 2019-01-08 13:59
viewtopic.php?f=21&t=28914
PeterP
Post by PeterP » 2019-01-10 13:14
I guess i found one reason for the "Message: bad allocation".
I add few hmail accounts to see if i get also Problems with them.
After a while i get a Virus message from my antivirus Scanner F-Secure that an attachment is infected and that Fsecure deleted it.
After that message i looked at the logs i see the same messages "An error occured when reading file., Message: bad allocation" and "An unknown error occurred while reading a text file from disk." for the added imap account.
It Looks like with deleting the attachmend the hmail Server could not load the eml any more which i guess was the attachment..could that be?
Post by mattg » 2019-01-10 16:23
It certainly could be that the Antivirus software was holding the file, and therefore it couldn't be loaded properly by hMailserver
PeterP
Post by PeterP » 2019-01-13 14:55
@mattg: You told someone else with similar problems "I'll bet that you haven't excluded the data directory from Antivirus scanning and that your anti-virus has removed or quarantined those messages". I have no anti virus software on the machine where hmail is running, but the errors look the same. He fixed his problem by removing data records from the database. Don't know what this mean, hopefully he will answer in his post:
viewtopic.php?f=7&t=32554&p=209251#p209251
I think the problems I have are anti-virus related.
Post by mattg » 2019-01-13 23:07
'bad allocation' errors ARE NOT native hMailserver errors.
This is the wording of the error message supplied by the underlying Windows OS.
The number of methods that such an error message is generated is not finite, but certainly includes read/write from disk I/O
Normally 'bad allocation' is directly related to the hard discs failing.
In some circumstances if the system Anti-Virus holds files for a length of time, Windows may think that there is a disc problem, due to lack of response (time out)
This may also be an issue with network infrastructure and routing if you are using network storage
There are many, many things that could cause this, but ALL of them are environmental, ie they only happen to you because of something in your environment
PeterP
Post by PeterP » 2019-01-15 13:27
thanks mattg for the Information.
Is there any maintenance possibility of the SQL database (SQL EXPRESS 2017) possible which is searching for non exiting files ?
Post by jimimaseye » 2019-01-15 15:36
Perhaps this could be a starter and provide inspiration: viewtopic.php?f=20&t=27646
