Need to block Client Initiated Renegotiation
raidensnake
Post by raidensnake » 2018-09-22 10:29
I ran into an issue with a PCI scan that failed as hmailserver is allowing clients to renegotiate the ssl encryption. Is there any way of disabling it?
Re: Need to block Client Initiated Renegotiation
Post by mattg » 2018-09-22 23:49
Of course
In your SSL settings, turn off SSLv3.0, TLS1.0 and TLSv1.1
Then ONLY TLSv1.2 will be allowed (and you won't connect older iphones, default Windows 7 machines or get emails from Facebook - to name a few examples of why this PCI crap doesn't work in the real world)
OH and you can't use MS SQL as the database without building your own hMailserver from source as the connection to the database ON THE SAME MACHINE isn't encrypted. Use PostGreSQL or MySQL (or MariaDB)
raidensnake
Post by raidensnake » 2018-09-23 10:27
Already tried that before and it still fails due to the renegotiation still being enabled. hmailserver's source is allowing users to renegotiate the connection and ciphers used.
Post by Dravion » 2018-09-23 11:27
Build hMailServer from source and disable it.
64-Bit builds of hMailserver
raidensnake
Post by raidensnake » 2018-09-23 13:20
Any suggestions on how to do that as I'm using vs2017.
raidensnake
Post by raidensnake » 2018-10-23 04:06
Still any ideas? no one has got back to me in a month...
Post by mattg » 2018-10-23 15:53
Can you explain how you know this to be the case?
raidensnake wrote:
2018-09-23 10:27
tunis
Post by tunis » 2018-10-23 15:53
Look at this on github.
It seem he using vs2017 for his built.
https://github.com/mologie/hmailserver/ ... tp-xclient
HMS 5.6.8 B2437.17 on Windows Server 2016 Core VM.
raidensnake
Post by raidensnake » 2018-10-29 08:27
2018-10-23 15:53
pci compliancy probes confirmed this.
Frag1le
Post by Frag1le » 2018-12-04 11:41
Hi, (my first post)
I would like to know this as well.
I also ran into hmailserver not having an option to disable client initiated renegonation.
Yes you can give an answer that i have to disable it myself and build from source, but i bet this isn't an option for 95% of the users here (hell perhaps even 99,9%).
From an online email tester:
We check if a sending mail server can initiate a renegotiation with your receiving mail server (MX). There seems to be no need to support client-initiated renegotiation. Although the option does not bear a risk for confidentiality, it does make your mail server vulnerable to DoS attacks within the same TLS connection. Therefore you should not support it.
So i hope anyone has a real answer.
Post by mattg » 2018-12-04 13:19
Can you show me a link to this online tester so that I can check it
raidensnake
Post by raidensnake » 2018-12-04 15:01
Post by mattg » 2018-12-04 15:33
Running the Detail test, I scored 100% with my server
Running the detailed SSL probe now
 Service set:            STARTTLS via SMTP
 Testing protocols via sockets
 SSLv2      not offered (OK)
 SSLv3      not offered (OK)
 TLS 1      not offered
 TLS 1.1    not offered
 TLS 1.2    offered (OK)
 TLS 1.3    not offered
 Testing cipher categories
 NULL ciphers (no encryption)                  not offered (OK)
 Anonymous NULL Ciphers (no authentication)    not offered (OK)
 Export ciphers (w/o ADH+NULL)                 not offered (OK)
 LOW: 64 Bit + DES encryption (w/o export)     not offered (OK)
 Weak 128 Bit ciphers (SEED, IDEA, RC[2,4])    not offered (OK)
 Triple DES Ciphers (Medium)                   not offered (OK)
 High encryption (AES+Camellia, no AEAD)       offered (OK)
 Strong encryption (AEAD ciphers)              offered (OK)
 Testing robust (perfect) forward secrecy, (P)FS -- omitting Null Authentication/Encryption, 3DES, RC4
 PFS is offered (OK), ciphers follow (client/browser support is important here)
Hexcode  Cipher Suite Name (OpenSSL)       KeyExch.   Encryption  Bits     Cipher Suite Name (RFC)
 x1302   TLS_AES_256_GCM_SHA384            any        AESGCM      256      TLS_AES_256_GCM_SHA384                             not a/v
 x1303   TLS_CHACHA20_POLY1305_SHA256      any        ChaCha20    256      TLS_CHACHA20_POLY1305_SHA256                       not a/v
 xcc14   ECDHE-ECDSA-CHACHA20-POLY1305-OLD ECDH       ChaCha20    256      TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256_OLD  not a/v
 xcc13   ECDHE-RSA-CHACHA20-POLY1305-OLD   ECDH       ChaCha20    256      TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256_OLD    not a/v
 xcc15   DHE-RSA-CHACHA20-POLY1305-OLD     DH         ChaCha20    256      TLS_DHE_RSA_WITH_CHACHA20_POLY1305_SHA256_OLD      not a/v
 xc030   ECDHE-RSA-AES256-GCM-SHA384       ECDH 256   AESGCM      256      TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384              available
 xc02c   ECDHE-ECDSA-AES256-GCM-SHA384     ECDH       AESGCM      256      TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384            not a/v
 xc028   ECDHE-RSA-AES256-SHA384           ECDH 256   AES         256      TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384              available
 xc024   ECDHE-ECDSA-AES256-SHA384         ECDH       AES         256      TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384            not a/v
 xc014   ECDHE-RSA-AES256-SHA              ECDH 256   AES         256      TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA                 available
 xc00a   ECDHE-ECDSA-AES256-SHA            ECDH       AES         256      TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA               not a/v
 xa3     DHE-DSS-AES256-GCM-SHA384         DH         AESGCM      256      TLS_DHE_DSS_WITH_AES_256_GCM_SHA384                not a/v
 x9f     DHE-RSA-AES256-GCM-SHA384         DH 2048    AESGCM      256      TLS_DHE_RSA_WITH_AES_256_GCM_SHA384                available
 xcca9   ECDHE-ECDSA-CHACHA20-POLY1305     ECDH       ChaCha20    256      TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256      not a/v
 xcca8   ECDHE-RSA-CHACHA20-POLY1305       ECDH       ChaCha20    256      TLS_ECDHE_RSA_WITH_CHACHA20_POLY1305_SHA256        not a/v
 xccaa   DHE-RSA-CHACHA20-POLY1305         DH         ChaCha20    256      TLS_DHE_RSA_WITH_CHACHA20_POLY1305_SHA256          not a/v
 xc0af   ECDHE-ECDSA-AES256-CCM8           ECDH       AESCCM8     256      TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8                 not a/v
 xc0ad   ECDHE-ECDSA-AES256-CCM            ECDH       AESCCM      256      TLS_ECDHE_ECDSA_WITH_AES_256_CCM                   not a/v
 xc0a3   DHE-RSA-AES256-CCM8               DH         AESCCM8     256      TLS_DHE_RSA_WITH_AES_256_CCM_8                     not a/v
 xc09f   DHE-RSA-AES256-CCM                DH         AESCCM      256      TLS_DHE_RSA_WITH_AES_256_CCM                       not a/v
 x6b     DHE-RSA-AES256-SHA256             DH 2048    AES         256      TLS_DHE_RSA_WITH_AES_256_CBC_SHA256                available
 x6a     DHE-DSS-AES256-SHA256             DH         AES         256      TLS_DHE_DSS_WITH_AES_256_CBC_SHA256                not a/v
 x39     DHE-RSA-AES256-SHA                DH 2048    AES         256      TLS_DHE_RSA_WITH_AES_256_CBC_SHA                   available
 x38     DHE-DSS-AES256-SHA                DH         AES         256      TLS_DHE_DSS_WITH_AES_256_CBC_SHA                   not a/v
 xc077   ECDHE-RSA-CAMELLIA256-SHA384      ECDH       Camellia    256      TLS_ECDHE_RSA_WITH_CAMELLIA_256_CBC_SHA384         not a/v
 xc073   ECDHE-ECDSA-CAMELLIA256-SHA384    ECDH       Camellia    256      TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384       not a/v
 xc4     DHE-RSA-CAMELLIA256-SHA256        DH         Camellia    256      TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA256           not a/v
 xc3     DHE-DSS-CAMELLIA256-SHA256        DH         Camellia    256      TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA256           not a/v
 x88     DHE-RSA-CAMELLIA256-SHA           DH         Camellia    256      TLS_DHE_RSA_WITH_CAMELLIA_256_CBC_SHA              not a/v
 x87     DHE-DSS-CAMELLIA256-SHA           DH         Camellia    256      TLS_DHE_DSS_WITH_CAMELLIA_256_CBC_SHA              not a/v
 xc043   DHE-DSS-ARIA256-CBC-SHA384        DH         ARIA        256      TLS_DHE_DSS_WITH_ARIA_256_CBC_SHA384               not a/v
 xc045   DHE-RSA-ARIA256-CBC-SHA384        DH         ARIA        256      TLS_DHE_RSA_WITH_ARIA_256_CBC_SHA384               not a/v
 xc049   ECDHE-ECDSA-ARIA256-CBC-SHA384    ECDH       ARIA        256      TLS_ECDHE_ECDSA_WITH_ARIA_256_CBC_SHA384           not a/v
 xc04d   ECDHE-RSA-ARIA256-CBC-SHA384      ECDH       ARIA        256      TLS_ECDHE_RSA_WITH_ARIA_256_CBC_SHA384             not a/v
 xc053   DHE-RSA-ARIA256-GCM-SHA384        DH         ARIAGCM     256      TLS_DHE_RSA_WITH_ARIA_256_GCM_SHA384               not a/v
 xc057   DHE-DSS-ARIA256-GCM-SHA384        DH         ARIAGCM     256      TLS_DHE_DSS_WITH_ARIA_256_GCM_SHA384               not a/v
 xc05d   ECDHE-ECDSA-ARIA256-GCM-SHA384    ECDH       ARIAGCM     256      TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384           not a/v
 xc061   ECDHE-ARIA256-GCM-SHA384          ECDH       ARIAGCM     256      TLS_ECDHE_RSA_WITH_ARIA_256_GCM_SHA384             not a/v
 xc07d   -                                 DH         CamelliaGCM 256      TLS_DHE_RSA_WITH_CAMELLIA_256_GCM_SHA384           not a/v
 xc081   -                                 DH         CamelliaGCM 256      TLS_DHE_DSS_WITH_CAMELLIA_256_GCM_SHA384           not a/v
 xc087   -                                 ECDH       CamelliaGCM 256      TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_GCM_SHA384       not a/v
 xc08b   -                                 ECDH       CamelliaGCM 256      TLS_ECDHE_RSA_WITH_CAMELLIA_256_GCM_SHA384         not a/v
 x1301   TLS_AES_128_GCM_SHA256            any        AESGCM      128      TLS_AES_128_GCM_SHA256                             not a/v
 x1304   TLS_AES_128_CCM_SHA256            any        AESCCM      128      TLS_AES_128_CCM_SHA256                             not a/v
 x1305   TLS_AES_128_CCM_8_SHA256          any        AESCCM8     128      TLS_AES_128_CCM_8_SHA256                           not a/v
 xc02f   ECDHE-RSA-AES128-GCM-SHA256       ECDH 256   AESGCM      128      TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256              available
 xc02b   ECDHE-ECDSA-AES128-GCM-SHA256     ECDH       AESGCM      128      TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256            not a/v
 xc027   ECDHE-RSA-AES128-SHA256           ECDH 256   AES         128      TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256              available
 xc023   ECDHE-ECDSA-AES128-SHA256         ECDH       AES         128      TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256            not a/v
 xc013   ECDHE-RSA-AES128-SHA              ECDH 256   AES         128      TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA                 available
 xc009   ECDHE-ECDSA-AES128-SHA            ECDH       AES         128      TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA               not a/v
 xa2     DHE-DSS-AES128-GCM-SHA256         DH         AESGCM      128      TLS_DHE_DSS_WITH_AES_128_GCM_SHA256                not a/v
 x9e     DHE-RSA-AES128-GCM-SHA256         DH 2048    AESGCM      128      TLS_DHE_RSA_WITH_AES_128_GCM_SHA256                available
 xc0ae   ECDHE-ECDSA-AES128-CCM8           ECDH       AESCCM8     128      TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8                 not a/v
 xc0ac   ECDHE-ECDSA-AES128-CCM            ECDH       AESCCM      128      TLS_ECDHE_ECDSA_WITH_AES_128_CCM                   not a/v
 xc0a2   DHE-RSA-AES128-CCM8               DH         AESCCM8     128      TLS_DHE_RSA_WITH_AES_128_CCM_8                     not a/v
 xc09e   DHE-RSA-AES128-CCM                DH         AESCCM      128      TLS_DHE_RSA_WITH_AES_128_CCM                       not a/v
 x67     DHE-RSA-AES128-SHA256             DH 2048    AES         128      TLS_DHE_RSA_WITH_AES_128_CBC_SHA256                available
 x40     DHE-DSS-AES128-SHA256             DH         AES         128      TLS_DHE_DSS_WITH_AES_128_CBC_SHA256                not a/v
 x33     DHE-RSA-AES128-SHA                DH 2048    AES         128      TLS_DHE_RSA_WITH_AES_128_CBC_SHA                   available
 x32     DHE-DSS-AES128-SHA                DH         AES         128      TLS_DHE_DSS_WITH_AES_128_CBC_SHA                   not a/v
 xc076   ECDHE-RSA-CAMELLIA128-SHA256      ECDH       Camellia    128      TLS_ECDHE_RSA_WITH_CAMELLIA_128_CBC_SHA256         not a/v
 xc072   ECDHE-ECDSA-CAMELLIA128-SHA256    ECDH       Camellia    128      TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256       not a/v
 xbe     DHE-RSA-CAMELLIA128-SHA256        DH         Camellia    128      TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA256           not a/v
 xbd     DHE-DSS-CAMELLIA128-SHA256        DH         Camellia    128      TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA256           not a/v
 x9a     DHE-RSA-SEED-SHA                  DH         SEED        128      TLS_DHE_RSA_WITH_SEED_CBC_SHA                      not a/v
 x99     DHE-DSS-SEED-SHA                  DH         SEED        128      TLS_DHE_DSS_WITH_SEED_CBC_SHA                      not a/v
 x45     DHE-RSA-CAMELLIA128-SHA           DH         Camellia    128      TLS_DHE_RSA_WITH_CAMELLIA_128_CBC_SHA              not a/v
 x44     DHE-DSS-CAMELLIA128-SHA           DH         Camellia    128      TLS_DHE_DSS_WITH_CAMELLIA_128_CBC_SHA              not a/v
 xc042   DHE-DSS-ARIA128-CBC-SHA256        DH         ARIA        128      TLS_DHE_DSS_WITH_ARIA_128_CBC_SHA256               not a/v
 xc044   DHE-RSA-ARIA128-CBC-SHA256        DH         ARIA        128      TLS_DHE_RSA_WITH_ARIA_128_CBC_SHA256               not a/v
 xc048   ECDHE-ECDSA-ARIA128-CBC-SHA256    ECDH       ARIA        128      TLS_ECDHE_ECDSA_WITH_ARIA_128_CBC_SHA256           not a/v
 xc04c   ECDHE-RSA-ARIA128-CBC-SHA256      ECDH       ARIA        128      TLS_ECDHE_RSA_WITH_ARIA_128_CBC_SHA256             not a/v
 xc052   DHE-RSA-ARIA128-GCM-SHA256        DH         ARIAGCM     128      TLS_DHE_RSA_WITH_ARIA_128_GCM_SHA256               not a/v
 xc056   DHE-DSS-ARIA128-GCM-SHA256        DH         ARIAGCM     128      TLS_DHE_DSS_WITH_ARIA_128_GCM_SHA256               not a/v
 xc05c   ECDHE-ECDSA-ARIA128-GCM-SHA256    ECDH       ARIAGCM     128      TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256           not a/v
 xc060   ECDHE-ARIA128-GCM-SHA256          ECDH       ARIAGCM     128      TLS_ECDHE_RSA_WITH_ARIA_128_GCM_SHA256             not a/v
 xc07c   -                                 DH         CamelliaGCM 128      TLS_DHE_RSA_WITH_CAMELLIA_128_GCM_SHA256           not a/v
 xc080   -                                 DH         CamelliaGCM 128      TLS_DHE_DSS_WITH_CAMELLIA_128_GCM_SHA256           not a/v
 xc086   -                                 ECDH       CamelliaGCM 128      TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_GCM_SHA256       not a/v
 xc08a   -                                 ECDH       CamelliaGCM 128      TLS_ECDHE_RSA_WITH_CAMELLIA_128_GCM_SHA256         not a/v
 Elliptic curves offered:     prime256v1
 Testing server preferences
 Has server cipher order?     nope (NOT ok)
 Negotiated protocol          TLSv1.2
 Negotiated cipher            ECDHE-RSA-AES256-GCM-SHA384, 256 bit ECDH (P-256) (limited sense as client will pick)
 Negotiated cipher per proto  (limited sense as client will pick)
Seems the only thing I fail is that my server offers choice of strong cipher
