Assuming I have a problem with a file I'm not able to solve, I wish to try to re-install hMailServer from scratch.
Is there a guide to follow to install again hMailServer and not lose Database content, e-mails and configuration ?
Regards, L.
Re-install hMailServer
- jimimaseye
- Moderator
Re: Re-install hMailServer
Run internal backup ticking EVERY tick box.
Copy save your eventhandlers script (if it has been customised)
Uninstall via program manager.
(Delete the program directory if you want to be sure)
Reinstall as new
Internal restore from backup.
Restore eventhandlers if needed.
Relocate your ssl certificates in the settings.
Restart the service.
All of that assumes you data is not too big for the internal backup (you will find out when you run it but don't worry there are solutions).
Reinstall as new
Thank you very much.
The procedure is also valid for installations using MySQL DB ?
- jimimaseye
- Moderator
Yes
Procedure succesfully ran, but unfortunately the previous error I wish to solve still is there.
- jimimaseye
- Moderator
If you share your problem then somebody may be able to help you.
Thanks for suggestion, here you are the thread where problem is described:
viewtopic.php?f=7&t=32984
