A way to auto-ban on "SENT: 550 Unknown user"
bagu
Post by bagu » 2018-08-12 16:04
I use the latest hmailserver and i wonder if there is a way to auto-ban an ip for a configurable time on "SENT: 550 Unknown user" message ?
Thanks a lot for your help.
Re: A way to auto-ban on "SENT: 550 Unknown user"
Post by jimimaseye » 2018-08-12 19:19
No. Autobans are for attempted breakins or unauthorised access (not typo's in email addresses).
bagu
Post by bagu » 2018-08-12 19:58
Even trough a vbs script ?
Post by Dravion » 2018-08-12 20:46
Maybe you can scan the hMailServer logfiles by an external program which simply add the ip to a Windows Firewall blocklist which caused the Unknown user Message.
Post by mattg » 2018-08-12 23:45
I do something similar for checking 504 rejections in my logs. I have AUTH banned on port 25, and this looks for those IPs that attempt to AUTH on port 25.
I run this as standalone VBS (It's actually an extract, so not tested as is)
Rem
Rem Checks logs and bans AUTH attempts on port 25
Rem
Option Explicit
Private const g_sAdminPassword = "Top_Secret_Password"
Dim oApp
' hMailServer settings.
Dim sYear, iMonth, iDay, sMonth, sDay
Dim s, FSO, OBJfile, OBJfile1, OBJoutfile
Dim FileIn, FileOut, Filebase
Dim a, b(5), c, d, i, j, e, f, g(5), t
Dim LastLogLine(15), NoIndexIssueFound, DateToUse
NoIndexIssueFound = true
'DateToUse = DateAdd("d",-1,Now())
DateToUse = Now()
sYear = Year(DateToUse)
iMonth = Month(DateToUse)
iDay = Day(DateToUse)
if  iMonth < 10 then
	sMonth = "0" + cstr(iMonth)
Else 'iMonth >= 10
	sMonth = cstr(iMonth)
End if
If iDay < 10 then
	sDay = "0" + cstr(iDay)
Else 'sDay >= 10
	sDay = cstr(iDay)
End if
Filebase = oapp.Settings.Directories.LogDirectory
FileOut = Filebase + "\504 Rejections" & "_" & sYear & "-" & sMonth & ".log"
Call CreateFiles(FileOut)
Set OBJoutfile = FSO.opentextfile(FileOut,8)
FileIn = filebase & "\hMailserver_" & cstr(sYear) & "-" & sMonth & "-" & sDay & ".log"
If fso.FileExists(Filein) Then
	set OBJfile = FSO.opentextfile(filein,1,0)
	While Not OBJfile.atendofstream
		s = OBJfile.ReadLine
		For i = 15 To 2 Step -1
			LastLogLine(i) = LastLogLine(i-1)
		LastLogLine(1) = s
		If InStr(s,"SENT: 504 Authentication not enabled.") > 0 Then
'			OBJoutfile.writeline s
			a = Split(s,Chr(9))
			i = 0
			For Each c In a
				b(i) = c
				i = i + 1
			Next 'c
			set OBJfile1 = FSO.opentextfile(filein,1,0)
			While Not OBJfile1.atendofstream
				t = OBJfile1.ReadLine
				If InStr(t,b(2)) > 0 And InStr(t,"SMTPD") > 0 Then
					If InStr(t,"RECEIVED: HELO") > 0 Or InStr(t,"RECEIVED: EHLO") > 0 Then
						e = Split(t,Chr(9))
						j = 0
						For Each f In e
							g(j) = f
							j = j + 1
						Next 'f
'						OBJoutfile.WriteLine b(3) & Chr(9) & g(4) & Chr(9) & g(5) & Chr(9) & b(5)
						Call AutobanIP(Replace(g(4),Chr(34),""),7,"Port 25 AUTH - " & Replace(g(5),"RECEIVED: ",""))
						t = OBJfile1.ReadAll
					End If ' get HELO/EHLO
				End If 'same messageID
			Wend
	Wend
	OBJfile.close
	set Objfile = Nothing
Sub CreateFiles(Name)
	If Not FSO.FileExists(Name) Then
		Dim txtFile
		Set txtFile = FSO.CreateTextFile(Name,true)
		txtFile.close
Sub AutobanIP(IPAddress, NumberOfDays, ReasonForBan)
	'custom event
	'uses functions:
	Dim i
	For i = 0 To oApp.Settings.SecurityRanges.Count -1
		If IPAddress = oApp.Settings.SecurityRanges.Item(i).LowerIP Then Exit sub
	With oApp.Settings.SecurityRanges.Add()
		.lowerip = ipaddress
		.upperip = ipaddress
		.priority = 20
		.allowdeliveryfromlocaltolocal = False
		.allowdeliveryfromlocaltoremote = False
		.allowdeliveryfromremotetolocal = False
		.allowdeliveryfromremotetoremote = False
		.allowimapconnections = False
		.allowsmtpconnections = False
		.allowpop3connections = False
		.expires = True
		.ExpiresTime = DateAdd("d", NumberOfDays, Now())
		.name = ReasonForBan & " - banned for " & NumberOfDays & " days - " & ipaddress
		On Error Resume Next
		.save
		If (Err.Number = 0) Then
			OBJoutfile.WriteLine "Autoban IP range saved for IP Address " & IPAddress & " with Reason-" & reasonforban
		ElseIf (Err.Number <> 0) Then
			OBJoutfile.WriteLine"ERROR: EventHandlers.vbs : Function LockFile"
			OBJoutfile.WriteLine"Error       : " & Err.Number
			OBJoutfile.WriteLine"Source      : " & Err.Source
			OBJoutfile.WriteLine"Description : " & Err.Description
			Err.Clear
		On Error Goto 0
bagu
Post by bagu » 2019-09-10 22:44
Work well for 504.
I have made a small change to search through hmailserver_STMP-date.log instead of hmailserver_date.log
I will try to adapt it for 550 unknown user because the dravion utility just don't work on my system (sad, really sad for me)
Rem
Rem Checks logs and bans AUTH attempts from unknown user
Rem
Option Explicit
Private const g_sAdminPassword = "supersecretpassword"
Dim oApp
DateToUse = Now()
if  iMonth < 10 then
Else 'iMonth >= 10
End if
If iDay < 10 then
Else 'sDay >= 10
	sDay = cstr(iDay)
End if
FileOut = Filebase + "\550 Rejections" & "_" & sYear & "-" & sMonth & ".log"
FileIn = filebase & "\hMailserver_SMTP_" & cstr(sYear) & "-" & sMonth & "-" & sDay & ".log"
		LastLogLine(1) = s
		If InStr(s,"SENT: 550 Unknown user") > 0 Then
			a = Split(s,Chr(9))
			i = 0
			For Each c In a
				b(i) = c
				i = i + 1
			Next 'c
						e = Split(t,Chr(9))
						j = 0
						For Each f In e
							g(j) = f
							j = j + 1
						Next 'f
						Call AutobanIP(Replace(g(4),Chr(34),""),7,"Unknown 550 AUTH - " & Replace(g(5),"RECEIVED: ",""))
			Wend
	Wend
	OBJfile.close
		Dim txtFile
		txtFile.close
	'custom event
	'uses functions:
	Dim i
		.priority = 20
		.expires = True
		.save
			Err.Clear
		On Error Goto 0
