mail delivery problem - verification failed from remote server
cijiro
Post by cijiro » 2018-01-12 11:19
I have interesting problem,
have HMS with 2 domains and some acccounts,
one domain has problem to send mail to customer, message returns to sender, but if i tried to send it from second domain, mail arrives to customer.
Customers mailhoster sais, thas is problem at our side, because of valid identification and verification.
Here is returned message:
Sent: Mon, 9 Jan 2018 14:21:24 +0000
Subject: some subject
customers@mail.com
Error Type: SMTP
Remote server (217.67.30.112) issued an error.
hMailServer sent: RCPT TO:<customers@mail.com>
Remote server replied: 550-Verification failed for <our@mail.com>
550 Sender verify failed
Have you any ideas, what can be wrong? If I know to anyone else messages going fine.
Re: mail delivery problem - verification failed from remote server
Post by jimimaseye » 2018-01-12 11:59
Please run this and post the results: viewtopic.php?f=20&t=30914
cijiro
Post by cijiro » 2018-01-12 12:50
2018-01-12   Hmailserver: 5.6.5-B2367
DOMAINS
   "Domain1.com" - doxxx.net                     Enabled: True
                   Max size of accounts:    0
        Greylisting:     False
   "Domain2.com" - unxxxxx.sk                    Enabled: True
  Enabled: False   Max size:                0   Enabled: False     Catchall: call@Domain73.com
        Greylisting:     False
IP RANGES
IP: 94.102.2.108 - 94.102.2.108     Priority: 20     Name: Auto-ban:
     SMTP:  False                              Antispam :  False
     POP3:  False                              Antivirus:  False
IP: 118.69.194.184 - 118.69.194.184     Priority: 20     Name: Auto-ban: administrator
IP: 155.133.82.143 - 155.133.82.143     Priority: 20     Name: Auto-ban: apple
IP: 107.161.124.146 - 107.161.124.146     Priority: 20     Name: Auto-ban: atendimento
IP: 45.119.125.202 - 45.119.125.202     Priority: 20     Name: Auto-ban: www
IP: 101.37.25.181 - 101.37.25.181     Priority: 20     Name: Auto-ban: zs
IP: 199.168.139.84 - 199.168.139.84     Priority: 20     Name: Auto-ban: zs (1)
   !!  Warning:  DEFAULT DOMAIN is SET  !! - "Domain1.com"
AUTOBANNED Local Addresses:
    No entries
AUTOBAN
  Autoban Enabled: True       Max invalid logon attempts:     10
                              Minutes Before Reset:           60  (1,00 hours, 0,04 days)
                              Minutes to Autoban:            120  (2,00 hours, 0,08 days)
There is a total of 5 auto-ban IP ranges.
INCOMING RELAYS
   No entries
MIRRORING         Disabled
PROTOCOLS
SMTP
                     Host: Domain1.com        Empty sender:       True  Batch recipients:   100
        Loop limit:           5
        Recipient hosts:     15
  Routes:
     No routes defined.
POP3
  No. Connections: 0
IMAP
                                                              IMAP Quota: True
                                                              IMAP Idle:  True
                                                              IMAP ACL:   True
                                                              Delim: "."
ANTISPAM
  Spam Mark:                  5       Use SPF:            True - 10    Use Spamassassin:    True
  Add X-HmailServer-Spam:    False    Check HELO host:    True - 3    Hostname:       127.0.0.1
  Add X-HmailServer-Reason:  False    Check MX records:   True - 3    Port:                 783
  Add X-HmailServer-Subject:  True    Verify DKIM:        True - 3    Use SA score: False -  10
              Subject Text: "[SPAM]"
  Spam delete threshold: 10         Maximum message size: 1024
DNSBL ENTRIES:
                  zen.spamhaus.org      Score: 10     Result: 127.0.0.2-8|127.0.0.10-11
                    bl.spamcop.net      Score: 10     Result: 127.0.0.2
                  all.spamrats.com      Score: 10     Result: 127.0.0.36-38
SURBL ENTRIES:
                   multi.surbl.org      Score: 10
GREYLISTING:
  Greylisting:   True       Defer mins: 30       Days Unused: 1      Days Used: 36
                            Bypass SPF: True     Bypass A/MX: True
Greylist WHITELIST ENTRIES:
   No entries
Greylist DOMAINS enabled:
  !! No active domains enabled - GREYLISTING INEFFECTIVE !!
WHITELISTING
              0.0.0.0            to    255.255.255.255              *[@t]karmen[dot]net
ANTIVIRUS
GENERAL:
  When found - Delete email. Notify Sender: False,  Notify Receiver: False
  Max Message Size: 500
     CLAM AV:   True       Hostname: 127.0.0.1    Port: 3310
     CLAMWIN:   False
     CUSTOMAV:  False
  Block Attachments: True
               *.com             Command
               *.csh             CSH script
               *.inf             Setup file
               *.jar
               *.js
               *.vbs
SSL CERTIFICATES
   Domain1.com
       Certificate: C:\Program Files (x86)\hMailServer\Cert\cert2017.pem
       Private key: C:\Program Files (x86)\hMailServer\Cert\server2017.key
SSL/TLS
             SSL 3.0 :   True
             TLS 1.0 :   True
             TLS 1.1 :   True
SslCipherList  :
               0.0.0.0         / 366   / SMTP   -   None
               0.0.0.0         / 465   / SMTP   -   SSL/TLS             Cert: Domain1.com
               0.0.0.0         / 993   / IMAP   -   SSL/TLS             Cert: Domain1.com
               0.0.0.0         / 995   / POP3   -   SSL/TLS             Cert: Domain1.com
  Paths:-
    Current:  C:\Program Files (x86)\hMailServer\Logs\hmailserver_2018-01-12.log
    Error:    C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2018-01-12.log - !! ERRORS PRESENT !!
                        APPLICATION -    True
                        SMTP        -    True
                        POP3        -    True
                        IMAP        -    True
                        TCPIP       -    True
                        DEBUG       -      .
                        AWSTATS     -    True
SYSTEM TESTS
Database type: MSSQL
ERROR: Backup directory C:\Users\Administrator\Desktop\backup is not writable.
HMAILSERVER.INI
Database folder:
Type=              MSSQL
Username=          sa
Port=              0
Server=            .\MSSQL
Internal=          0
Generated by HMSSettingsDiagnostics v1.88, Hmailserver Forum
cijiro
Post by cijiro » 2018-01-12 12:57
to jimimaseye:
thanks for reply, I tried to paste report, but it not show, only in edit...
i check certificate, and it can be a problem, i use certificate for main domain, but don't have for another one, if i test certificates with online tests main domain pass, but second domain have exclamation, that domain and certificate domain not the same.
I'm using certificate for both domains for pop3 communcation, is there any option to disable certificate for smtp cmmunication? Or how can I resolve it?
Thanks so much
Post by mattg » 2018-01-12 15:01
cijiro wrote: Error: C:\Program Files (x86)\hMailServer\Logs\ERROR_hmailserver_2018-01-12.log - !! ERRORS PRESENT !!
Can you please show the contents of the error log
Post by Dravion » 2018-01-12 16:31
Check if the remote email adress really exists or if you misspelled something.
Test the troublesome Email Address testwise with a diffrent Email service then Yours (for example Gmail)
and report back.
mikedibella
Post by mikedibella » 2018-01-12 18:41
The destination server is doing a callback validation based on the sender address and it is failing. This callback validation is typically done by looking up the sender address domain MX and making and connection to send mail, and passing or failing based on the MX response to RCPT TO verb.
To pass, you need the sender domain MX record to point to a server that will accept a message for that address.
Post by Dravion » 2018-01-13 07:21
If its indeed a MX missconfiguration, you need to check if at least a primary DNS MX entry is avaiable in your
DNS-Zone, pointing to a A) Record which has to the IPv4 or IPv6 Address of you hMailServer
(if your hMailServer is running on a Windows VPS/Root Server. If your hMailServer is installed in a local lan
(LAN) and is connected to a Outside SMTP Server like Postfix/Exim/Sendmail or MS-Exchange or
IIS/SMTP as Relayserver you need to make sure your Relayserver has its required MX Entry.
Check your Domains mx entry with the following command on a command prompt
nslookup -type=mx yourdomain.com
The output should be a list of servers. If there is no MX entry, you need to add a MX entry to you DNS-Zone.
cijiro
Post by cijiro » 2018-01-13 18:55
my situation is next:
all MX are good
I have HMS with 2 domains configured,
for 1., default domain I have ssl certificate,
for 2. I have not ssl certificate, and using domain name of 1. domain in mail client to communicate with pop3/imap and smtp securely,7
and I think this can be the trouble.
By me, remote server, if i send mail from 2. domain can verifi sender, but through secure connection, but there is not certificate for second domain, and because certificate is for another domain it reply with error of verification.
Is this possible? How can i set, to force remote servers to communicate through no ssl?
I have my server for cca 5 year and never have this problem and few days ago this happens, and I no change nothing...
mikedibella
Post by mikedibella » 2018-01-13 20:08
It is not required that the SSL certificate match the recipient domain.
It is required that the subject Common Name of the SSL certificate match the DNS name used to connect to the server. This is the hostname returned as the "mail exchanger =" portion of the MX record query response.
It is also best practice to configure the server to include this hostname in the connection banner.
cijiro
Post by cijiro » 2018-01-13 22:41
I try to explain my problem again,
I have 1 hmail server,
have 2 domains, for example ex1.com and ex2.com
I have configured HMS for ex1.com, have correct MX, ex1.com as default domain, correct PTR, valid SPF, valid wildcard certificate for *.ex1.com,
next i have added next domain ex2.com to HMS, everything like ex1.com, but without certificate.
At mail client i'm using mail.ex1.com for both domains, because of secure connection.
Everything work fine for years, no problem like that,
but few days ago, emails for ex2.com starts return from cust1.com, no other domain have problem, and if i send mail to cust1.com from ex1.com it arrives, but if I send from ex2.com, message returns with description:
customers@cust1.com
Error Type: SMTP
hMailServer sent: RCPT TO:<customers@cust1.com>
Remote server replied: 550-Verification failed for <our@ex2.com>
I don't know why message returns, but if I try to solve problem with other side, it says, that problem is at my side and he's server can't verify sender.
I think that problem can be, that customers remote server communicates through secure connection with ex2.com, and it's has not valid certificate and certificate for ex1.com is used and because it's not valid for ex2.com, remote serve return false verification, because of no connection.
Is that possible and can be this problem? If yes, can be ex2.com set to communicate without certificate with other servers?
Post by mattg » 2018-01-14 00:51
I'll try and state the answer again.
mikedibella wrote:The destination server is doing a callback validation based on the sender address and it is failing. This callback validation is typically done by looking up the sender address domain MX and making and connection to send mail, and passing or failing based on the MX response to RCPT TO verb.
Unless you tell us the actual domain, we can't check your mx records from the internet.
ALSO, your system is generating errors
cijiro
Post by cijiro » 2018-01-15 15:39
thanks for reply, posting error file content:
"ERROR" 564 "2018-01-12 07:50:41.027" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 42, Data: 141 UID FETCH 84 (RFC822.SIZE BODY.PEEK[]). Remote IP: 185.5.137.192"
"ERROR" 564 "2018-01-12 12:17:37.295" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
"ERROR" 5416 "2018-01-12 23:55:54.072" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 156, Data: y6n1 UID FETCH 222:320,326:327,329:330,340,382:416,419:428,432,457:466,513,531,601:1172,1198:1211,1218,1220 (UID FLAGS RFC822.SIZE BODY.PEEK[] INTERNALDATE). Remote IP: 87.197.187.16"
"ERROR" 5416 "2018-01-12 23:55:54.072" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
problematic domain is: quXXXXX.XXX
Reason: domain name removed
Post by mattg » 2018-01-16 00:41
Those errors are unrelated to your issue. Updating to newest Beta will slow them down we think.
I think that your issue is related to your DNS settings
Your PTR record is for your other domain, not this one.
You can only really have one PTR record, so I'd suggest changing your DNS MX record for this domain to the same as you have it for your other domain, ie mail.dXXXX.net
also making sure that your local host name in SMTP settings says mail.dXXXX.net and see if that works.
I'd guess that THIS remote server is looking to match your PTR record to your mail server FQDN - I have seen a few servers do that, it's not very common but does limit their incoming SPAM, and also reject a lot of genuine mail.
cijiro
Post by cijiro » 2018-01-16 10:22
Hi mattg,
thanks so much for your help,
I tried to change DNS MX, but it not work, still same reply from remote server,
I try to leave only mail.dXXXX.net, try mail.dXXXX.net and quXXXXX.XXX, try with and without SPF, nothing changed.
Now I think, I can't do nothing with it? What you think?
Post by Dravion » 2018-01-16 11:12
Use mx lookup to proof ur DNS mx entry is realky working. No SMTP-Server can do its Job correctly without a working MX Record.
cijiro
Post by cijiro » 2018-01-16 12:06
Hi Dravion,
I checked MX multiple times, with multiple external online tools and checked DNS propagation, MX are ok.
Thanks for idea.
Post by mattg » 2018-01-16 12:57
cijiro wrote:I tried to change DNS MX, but it not work, still same reply from remote server,
Did you wait long enough for it to propagate across the DNS network??
cijiro
Post by cijiro » 2018-01-16 13:18
Mattg,
I think yes, 9 hours, and check public DNS servers for updated records,
I have added some new domains, every with different DNS settings, for testing, but it looks, every configuration has same result.
I try it after some hours again, but I thing it not helps.
I wrote to remote server provider, but they are very slow in reactions, and not very helpful.
Post by Dravion » 2018-01-16 15:36
I can verify your DNS-Entries for you or i can take a look via Teamviewer.
Sent me your domainname where hMailServer is listening or sent me your temporary Teamviewer details and i will
take a look.
Post by mattg » 2018-01-20 09:08
Also check the three things mentioned at the bottom of this page >> https://www.hmailserver.com/documentati ... sages_smtp
cijiro
Post by cijiro » 2018-02-09 16:11
my problem is solved now,
problem ha been at 3rd side, remote provider using infrastructure with 3rd company and that company has old DNS record for my domain at system,
the remove DNS entries and everything works fine now.
Thanks so much for help.
