Moving Hmail to new machine
abgar
Post by abgar » 2017-05-24 11:10
Hello
After many years we decided to move whole Apache server to new machine.
At this occasion I decided to change structure of folders on new server to be more logic.
So what I did:
- copied hmail server mysql database to new machine - OK
- installed hmail server in new location C:\uniserver\hmailserver ( old location was: C:\server\bin\stable\hmailserver )
- connected properly hmail to new mysql, copied DATA folder, modified hmail.ini and changing values C:\server\bin\stable\hmailserver to C:\uniserver\hmailserver
Everything seemed to work OK BUT it appeared that C:\server\bin\stable\hmailserver\data was created spontaneously and there are message files appearing.
I digged deeper and found that in Mysq database hmailserver\hm_messages\messagefilename still entries of file locations remain C:\server\bin\stable\hmailserver\data. I inderstand what happens
And now my question: will it be enough if I do Mysql mass search/replace query to change C:\server\bin\stable\hmailserver\data TO C:\server\bin\stable\hmailserver\data in "messagefilename " ?
Should it work fine or there are another entries in database which can do mess ?
abgar
Re: Moving Hmail to new machine
Post by abgar » 2017-05-24 12:43
Sorry, I messed. This should go this way:
And now my question: will it be enough if I do Mysql mass search/replace query to change C:\server\bin\stable\hmailserver\data TO C:\uniserver\hmailserver\data in "messagefilename
prisma
Post by prisma » 2017-05-24 13:32
If you use a newer hmailserver version, you should completely remove absolute file paths instead of updating to new absolute paths. The path to messages is taken from the INI.
Search this forum, there should be examples for SQL queries.
Post by jimimaseye » 2017-05-24 13:37
prisma wrote:If you use a newer hmailserver version, you should completely remove absolute file paths instead of updating to new absolute paths. The path to messages is taken from the INI.
Search this forum, the should be examples for SQL queries.
viewtopic.php?f=21&t=28914
abgar
Post by abgar » 2017-05-24 13:49
Thank you for this hint. I am currently running 5.6.5B7
From what I read, during upgrades the database should be cleared from absolute paths but seems it has not happened.
I will dig into this.
Problem is I am not mysql guru :cry:
Post by jimimaseye » 2017-05-24 14:18
abgar wrote: Problem is I am not mysql guru :cry:
You dont need to be. That article tells you EXACTLY how to do it in MySQL.
abgar
Post by abgar » 2017-05-24 16:53
Indeed. I managed to do it easily. :D
Thank you for help.
