Your mailbox is already locked
karishma
Post by karishma » 2016-10-20 07:15
I am running hmailserver 5.4.2 on windows server 2008. One of our email is used by multi-users over their outlook client, we have noticed the below error at some times:
Receiving error reported. Your mailbox is temporarily unavailable because another email message is being devliered to it or another mail application is accessing it. The server responded: -ERR Your mailbox is already locked.
Does this mean hmailserver does not allow multi-users logging into the same email ID? Is there a workaround?
Re: Your mailbox is already locked
Post by mattg » 2016-10-20 07:28
That is a limitation of the POP protocol not of hMailserver
If you 'need' simultaneous access then you should use IMAP, and preferably IMAP public folders
karishma
Post by karishma » 2016-10-20 08:22
Even our previous usage (from other email provider was POP3) had no issues with simultaneous access.
How is IMAP public folder?
Post by mattg » 2016-10-20 09:38
IMAP is alternative to pop3
Public folders is IMAP folders where access is designed with multiple users simultaneously accessing the same mail folders
karishma wrote:Even our previous usage (from other email provider was POP3) had no issues with simultaneous access.
Does your user notice any issues, or just that you notice the line in the logs?
karishma
Post by karishma » 2016-10-24 05:09
my user noticed the error msg while trying to access the shared email ID... thats how i know, otherwise no other additional issues
