Hmailserver in windows 8.1?
manyul
Post by manyul » 2016-07-27 09:31
Hi guys does anyone tried to install HMS in windows 8.1 pro?
Is it okay to install HMS in windows 8.1 Pro? We have 700+ users.
Hmail server alone in windows 8.1 pro, with 4gb ram, 500gb hard disk.
MySQL database will be in different machine.
Re: Hmailserver in windows 8.1?
Post by jimimaseye » 2016-07-27 09:34
OS is not a problem. Many have it installed on 8 and even 10.
Post by percepts » 2016-07-27 12:05
if you have 700 users all using IMAP then I would suggest minimum of 16GB ram. Ram is so cheap in the greater scheme of things that 32GB or even 64GB should be a non issue for a 700 user system.
For optimum performance I would also use Postgre DB and put your spam/anitivirus checking on another server box using something like ASSP infront of the hmailserver box or consider using an external service for spam/antivirus checking such as SpamExperts which will remove a lot of admin/monitoring/problem solving/fixing from you the administrator.
That should give you some built in scalability so you won't see a degredation of performance if user numbers grow siginficantly or user load is heavy.
Having said that, 1000 mail accounts is only a medium size setup. There are implementations of hmailserver with many times that number of accounts so hmail is quite capable but yo need to be sure your hardware/software infrastructure is right. And you'll probably need backup hmail servers on other boxes.
manyul
Post by manyul » 2016-07-28 05:07
Here is my setup now,
HMAILSERVER and WAMP are on the same machine, inside the Virtual Machine to be exact and then will create a high availability in case the hmail server is down. And, will create also a backup for Database in other machine.
is it ok to install HMS and wamp on the same machine?
hard disk = 1tb, is this enough for 700 users?
RAM = 8GB, is this enough for 700 users?
By the way, this is only POP3 users.
Post by percepts » 2016-07-28 05:55
if its only pop3 users then it should be fine. And if its only pop3 then disk space should not be an issue.
manyul
Post by manyul » 2016-07-28 07:30
So my setup now is Good to go?
Done with all sending and receiving test scenarios. My only pending now is that i need to create their email accounts.
Post by mattg » 2016-07-28 08:25
