An error occured while executing 'IOCPQueueWorkerTask'
Lamprecht
Post by Lamprecht » 2016-07-24 13:55
An IMAP Folder read over java mail api, an message getMessag to get an eml creates an folder close event
in hmail log:
"IMAPD" 6740 3 "2016-07-24 13:34:55.243" "87.138.176.236" "RECEIVED: A1606 FETCH 13 (BODY[]<98304.16384>)"
"ERROR" 6740 "2016-07-24 13:34:55.243" "Severity: 3 (Medium), Code: HM5136, Source: TCPConnection::AsyncReadCompleted, Description: An error occured while parsing data. Data length: 36, Data: A1606 FETCH 13 (BODY[]<98304.16384>). Remote IP: 87.138.176.236"
"ERROR" 6740 "2016-07-24 13:34:55.243" "Severity: 2 (High), Code: HM4208, Source: ExceptionHandler::Run, Description: An error occured while executing 'IOCPQueueWorkerTask'"
i attached minidump_2016-07-24 133455_{87353B69-43B7-44C9-8EFF-D0C99ABC4DBE}.dmp
but there is the message in the web frontend : invalidfile extension
i zip it
best regards
Norbert Lamprecht
minidump.zip
(33.62 KiB) Downloaded 59 times
Re: An error occured while executing 'IOCPQueueWorkerTask'
Post by jimimaseye » 2016-07-24 14:15
I dont know the full format of an IMAP protocol 'fetch' command but I just tested and compared it to my log. I get
"IMAPD" 2484 40 "2016-07-24 14:02:31.651" "127.0.0.1" "RECEIVED: 28 UID fetch 1563 (UID RFC822.SIZE BODY.PEEK[])"
compare this to yours:
They look very different.
Mine was done using an known proven mail client (Thunderbird), whereas yours is (you say) with a Java API. So to be sure:
Does the format of your line look the same as every other 'fetch' line?
Do you get the same problem trying to view the same folder/message if you use an established email client (eg, Thunderbird)? (If it works with TB then this would suggest that the cause is with the java API and its command).
Post by mattg » 2016-07-24 15:03
Also, what version of hMailsevrer?
This was a known issue back with 5.4, and is fixed in newer releases
Post by Dravion » 2016-07-24 17:53
Kernel Debugger crashdump analyses
Problem: General protectionf ault / EAccessViolation
Microsoft (R) Windows Debugger Version 6.3.9600.17200 X86
APP: hmailserver.exe
FAULTING_MODULE: 76280000 kernel32
EXCEPTION_CODE: (NTSTATUS)
0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_hMailServer.exe!Unknown
Last event: 1314.1a54: Access violation - code c0000005 (first/second chance not available)
debugger time: Sun Jul 24 17:11:38.523 2016 (UTC + 2:00)
Error c0000005 In this case, it simply means the hMailServer function
" IOCPQueueWorkerTask::DoWorkInner() file: IOQueueWorkerTask.cpp "
https://github.com/hmailserver/hmailser ... erTask.cpp
Is trying to access memory which is allready deallocated. If this leads to a stop of hMailServer.exe service this is an flaw. As far as i can see this type of error isnt catched anywhere local and will be redirected to the general, global exception handler.
Post by mattg » 2016-07-25 00:10
Yes dravion, that is the fixed version.
Currently these errors will dump a mini-crash anaylsis and keep working.
Quite a few versions back, hmailserver stopped silently with these errors.
The IOCP errors would suddenly appear, sometimes after years of normal use. Once they started it was hard to get them to stop.
Once of the causes was found and a patch built. part of the patch is to do the minidumps (but only 10 of them in a day), but keep working.
Post by percepts » 2016-07-25 02:12
OP posted a minidump. He must have a recent version methinks.
Lamprecht
Post by Lamprecht » 2016-07-25 10:35
Lamprecht wrote:An IMAP Folder read over java mail api, an message getMessag to get an eml creates an folder close event
in hmail log:
i zip it
best regards
Norbert Lamprecht
java mail api function are used
Lamprecht
Post by Lamprecht » 2016-07-25 10:36
mattg wrote:Also, what version of hMailsevrer?
last version from last week
Lamprecht
Post by Lamprecht » 2016-07-25 10:37
percepts wrote:OP posted a minidump. He must have a recent version methinks.
minidump is in attach
Lamprecht
Post by Lamprecht » 2016-07-25 10:41
jimimaseye wrote:I dont know the full format of an IMAP protocol 'fetch' command but I just tested and compared it to my log. I get
problem occurs in a getMessage() function -> java.mail.api -> the function get the massage as .eml file
Post by jimimaseye » 2016-07-25 10:47
Lamprecht wrote:problem occurs in a getMessage() function -> java.mail.api -> the function get the massage as .eml file
And what happens if you try a normal email client to read the same account/message? Does it still crash the same way?
Post by percepts » 2016-07-25 15:52
I think that's what I said!
Post by Dravion » 2016-07-25 17:44
Manual Telnet IMAP sequence
Thunderbird Message compose:
Telnet manual login and message fetch
Lamprecht
Post by Lamprecht » 2016-07-26 15:47
the problem exits only with java mail api, on thunderbird and emClient the is no problem
but hmail should not crash i think ?
Post by percepts » 2016-07-26 16:10
you should email the minidump direct to martin at hmailserver dot com
that way you'll get a faster more direct response with action for this sort of problem. That is what minidumps are for.
Having said that, it looks highly likely that your java api has either got a bug or is not being used correctly (but it could be hmailserver too).
