myssl use .pFX
tonysbsw
myssl use .pFX
Post by tonysbsw » 2016-07-22 16:41
why hmailserver ask for private key and .cer how can i add my .pfx
tonysbsw
Re: myssl use .pFX
Post by tonysbsw » 2016-07-22 17:54
tonysbsw wrote:why hmailserver ask for private key and .cer how can i add my .pfx
i tried to use a self signed certificate with windows
Re: myssl use .pFX
Post by percepts » 2016-07-22 18:11
you provide the location of your certificates in settings/advanced/ssl certificates
read the following:
https://www.hmailserver.com/documentati ... rtificates
and
https://www.hmailserver.com/documentati ... nce_ssltls
I'm not sure that you can use a pfx format certificate. You need a certicate and a private key.
You can convert pfx certicates to a crt file by using openssl although if you are generating a self signed certificate then you probably have following already and should generate a crt file and not a pfx file
see https://www.openssl.org/
I get my copy of it from http://slproweb.com/products/Win32OpenSSL.html
Re: myssl use .pFX
Post by jimimaseye » 2016-07-22 18:37
