Rule for empty Sender needed
cyberflip
Post by cyberflip » 2016-07-14 09:39
I use hMailServer between an local Exchange2013 and the Smtp-Server of my provider. Normal Sending works fine,
but when i turn on "autoreplay" in an users postbox on the exchange server - mails are not delivered ... The problem
is that the exchange server sends the mail with no Sender address...
in the logging of hmailserver i see:
RECEIVED: MAIL FROM:<> SIZE=11304
SENT: 250 OK
my provider doesn't accept mails with empty sender field - so when hmailserver forwards the mail to the external smtp
i get an error
so how to use a global rule to replace an empty sender with an dummy noreply@xxx.xx ?
I tried:
Field: From Not contains @
Action: Set header value
Header name: From
Value: none@xxx.xx
doesn't work..
any ideas ?
thank you
greetings
Philipp
Re: Rule for empty Sender needed
Post by jimimaseye » 2016-07-14 10:26
That's unfortunate. I believe that's against RFC rules and advice. (Although they probably do it in a belief it adds some sort of security to ensure they are not abused).
Any reason why you are using the smtp relay from your provider and not sending out directly?
Maybe setup your relay as a route, and set a rule to use the route for all emails except for when the from is empty at which it could go directly? (It all comes down to, though, why using the SMTP relay in the first place).
Post by percepts » 2016-07-14 10:55
fix the problem at source which is exchange. It should be adding the from address correctly in the auto reply and not leaving it empty. I'm presuming its actually Return-Path: which is empty and not From:
take a look at the email and confirm this please.
cyberflip
Post by cyberflip » 2016-07-14 12:35
thanks for your answers - I know that the problem is the provider - he thinks it's unsecure ...
I can't fix the Problem at source - Exchange2013 sends autoreply without sender field
and you can't fix it (See: http://www.techieshelp.com/exchange-201 ... l-senders/)
I want to use hMail Server for this reason -> to replace the empty sender string..
I'm testing with vba to change it...
Rule with outgoing mail works - my vba function is executed
there i check the sender field (len=0)
and i replace the sender field with a string..
i get the the error:
"ERROR" 8164 "2016-07-14 12:17:12.625" "Severity: 3 (Medium), Code: HM4404, Source: SMTPDeliverer::_ApplyForwarding, Description: Did not submit bounce message for message 58 from none@xxxxxx.or.at since rule loop count was reached or Auto-Submitted header."
Here is my code
Sub OnReplaceSender(oMessage)
	EventLog.Write("SCRIPT: OnReplaceServer ")
	EventLog.Write("SCRIPT: Sender  " & oMessage.FromAddress)
	EventLog.Write("SCRIPT: Length  " & Len(oMessage.FromAddress))
	if Len(oMessage.FromAddress)="0" then
		EventLog.Write("SCRIPT: no Sender ... set Sender")
		oMessage.FromAddress = "none@xxxx.or.at"
	end if
Any tips or hints, what i have to do?
Thanks and greetings
Philipp
cyberflip
Post by cyberflip » 2016-07-14 12:47
okay - there was no error..
the error is because my provider doesn't accept the none@xxx.co.at mail address
when i use a valid mail adress in my script, it's executed without erorrs..
Script is working!
Thanks and
Greetings
Philipp
Post by jimimaseye » 2016-07-14 15:26
Good to hear.
By the way hmailserver also has empty sender address (from) when it does a rule induced reply.)
Return-Path: <>
HMS LOG:
"SMTPC" 2824 3685 "2016-07-14 11:23:10.683" "98.138.112.38" "SENT: MAIL FROM:<>"
"SMTPC" 2300 3685 "2016-07-14 11:23:11.058" "98.138.112.38" "RECEIVED: 250 null sender <> ok"
(but its not empty with a message via the Auto-reply feature)
