Questions on Distribution list
itsmesri
Post by itsmesri » 2016-04-14 02:24
Hi Friends,
I think you guys already using distribution list in hmail server. I have couple of questions on this. I send emails to external users from my id.
1. How can only internal users (domain users) can send to distribution list address?
If I selected "Membership" option.My email address needs to be in list to send email. Is it possible to send email without having my email address in the list?
If I selected "Public" option. Anyone send email to distribution email address (like from gmail, yahoo email). But I want only internal users can send email to it.
2. Require SMTP Authentication, If I am sending email from Roundcube it is throwing error for SMTP authentication.
How to enable SMTP authentication from RoundCube?
Re: Questions on Distribution list
Post by jimimaseye » 2016-04-14 09:38
1, There is a check box called "Require SMTP Authentication". Check that. Then only authenticated users (and therefore users local to the system) will be able to send to it. https://www.hmailserver.com/documentati ... butionlist
2, there are parameters in your roundcube config file to set the authentication details. I dont use/know it myself but maybe you can figure it out or wait for someone else to advise.
itsmesri
Post by itsmesri » 2016-04-14 18:58
I am able to fix this issue. I selected "Public" and also selected "SMTP Authentication" then changed in RoundCube config file.
Now, I need to import all emails to list from file. Please let me know what format file needs to be to import contact to list? any sample available.
Post by jimimaseye » 2016-04-14 20:13
itsmesri
Post by itsmesri » 2016-04-14 20:18
I think I don't need script for this. hmail has built in feature for import. But I don't find help for the format this.
Post by jimimaseye » 2016-04-14 20:34
Here's the thing....
I dont know, just like you. But, to find out I do little research (reading and searching) and even try stuff with logical thoughts trying to fill in the blanks based on things being obvious. What do YOU think an import file to populate an email address list might need to contain?
If I can do this (to get an answer to you for your problem), what do you think the possibilities are of you doing the same?
Please do report back when you have the answer so we can update the documentation accordingly (if and where required).
Post by katip » 2016-04-14 20:54
duh! i must be blind. have so frequently to do with d-lists and see this for the first time :lol:
since what version is this there?
Post by jimimaseye » 2016-04-14 20:56
katip wrote:duh! i must be blind. have so frequently to do with d-lists and see this for the first time :lol:
Yeah, me too. Never seen it before now (I personally dont know the history). Just tried it though and it works REALLY well.
itsmesri
Post by itsmesri » 2016-04-14 23:35
OK I am able to upload now
I created simple import.txt file and added these line
abc@abc.com
xyz@xyz.com
eec@eca.com
selected import... that's it. I got all them.
Post by jimimaseye » 2016-04-14 23:52
Good to hear. Easy wasnt it.
Post by jimimaseye » 2016-04-17 16:10
itsmesri wrote:I think I don't need script for this. hmail has built in feature for import. But I don't find help for the format this.
There you go, documentation updated: https://www.hmailserver.com/documentati ... butionlist
