Connection to database is not available
MandoesaM
Post by MandoesaM » 2015-10-21 12:48
Hi Folks,
After installing HmailServer when i tried to open admin console i get error attached after doing some google search i read that i have to copy C:\Program Files (x86)\hMailServer\Bin\libmysql.dll ,, i did but unfortunately same issue.
OS : Windows Server 2012 R2
LOG Folder : is empty
Re: Connection to database is not available
Post by jimimaseye » 2015-10-21 13:25
Have you installed and checked the MySQL database service is actually running? Can you access the service using MySQL Workbench?
As for the DLL, I assume you followed this guide: viewtopic.php?f=21&t=27557
MandoesaM
Post by MandoesaM » 2015-10-21 14:58
Thanks for trying to help me !
i just opened services.msc i didn't find any service related to SQL. should i install separate SQL i used the default installation options.
thanks again
Post by jimimaseye » 2015-10-21 15:02
Hang on.....
...are you using MySQL or not??
MandoesaM
Post by MandoesaM » 2015-10-22 13:48
no i don't use, i tried to install HMailServer on windows 7 and works fine without configuring any database, is there special configuration should i do in windows server 2012 r2 ?
Thanks in advance
Post by jimimaseye » 2015-10-22 16:18
MandoesaM wrote:no i don't use,
That explains why it cant find the service then!
Uninstall HMS completely, and reinstall by stating internal database. You shouldnt and dont have to copy MYsql DDL's if you are not using MySQL. HOWEVER....if you WANT to using MySQL (recommended), then make sure you install MySQL first!
karishma
Post by karishma » 2016-10-11 08:13
Im having this same problem installing hmailserver on windows server 2012, i chose the internal database, but yet i get error connection to database is not available. Nothing in the logs directory either. This is so different from installing on windows 7, it was seamless.
Can anyone help?
