Mysql error in log
bagu
Mysql error in log
Post by bagu » 2015-08-18 23:58
I have the same error that back between one and two times every day, and I do not understand why .
"ERROR"	4344	"2015-08-18 23:33:23.805"	"Severity: 2 (High), Code: HM5032, Source: DALConnection::Execute, Description: MySQL: Incorrect string value: '\xF0\x9F\x8D\x92 w...' for column 'metadata_subject' at row 1 (Additional info: INSERT INTO hm_message_metadata (metadata_accountid, metadata_folderid, metadata_messageid, metadata_dateutc, metadata_from, metadata_subject, metadata_to, metadata_cc) VALUES (84, 477, 484126, '2015-08-01 17:59:48', 'Populaire au sein de votre réseau <info@twitter.com>', 'MORTEN a tweeté : Unreal walking into @pacha
Can you help me to solve this ?
I use HmailServer 5.6.4 build 2283 and Mariadb 10.0.21
Re: Mysql error in log
Post by SorenR » 2015-08-19 01:40
bagu wrote:Hello,
EMOJI's... It's a utf8mb4 issue with "metadata_subject", "metadata_from", "metadata_to", "metadata_cc" in table "hm_message_metadata". Change the 4 columns from utf8_general_ci to utf8mb4_general_ci and varchar(255) to varchar(191). Disable message indexing, wait 5 minutes and enable message indexing again.
bagu
Post by bagu » 2015-08-19 11:52
Thanks a lot for your answer.
I have made changes and waiting to see if it happen again.
Post by jimimaseye » 2017-01-04 15:46
Presumably the MySQL commands will be:
ALTER TABLE hm_message_metadata CONVERT TO CHARACTER SET utf8 COLLATE utf8mb4_general_ci;
ALTER TABLE hm_message_metadata MODIFY metadata_subject VARCHAR(191),
ALTER TABLE hm_message_metadata MODIFY metadata_from VARCHAR(191),
ALTER TABLE hm_message_metadata MODIFY metadata_to VARCHAR(191),
ALTER TABLE hm_message_metadata MODIFY metadata_cc VARCHAR(191);
(Not tried it, though, because I dont have the problem (I don't use indexing) and my MySQL version is too old for utf8mb4_general_ci).
Can anyone confirm?
Post by SorenR » 2017-01-04 17:55
The Internet says...
ALTER TABLE table_name
CHANGE column_name column_name
VARCHAR(191)
CHARACTER SET utf8mb4
COLLATE utf8mb4_unicode_ci;
Not tested!
Anyways, UTF8 is contained within UTF8MB4 so no actual conversion is done except adding 1 byte address space per char, thus the reduction from 255 to 191 characters.
