Need help with "Forward to" in Rules
Atreyu4055
Post by Atreyu4055 » 2015-07-31 16:13
Hello, I am running HMS 5.6.3 build 2449 on Server 2008 R2 with multiple domains and many accounts.
Everything works perfectly.
Now I am being asked by one of the domains, lets say ABC, that for ALL messages, received and sent out, must be copied to another account. For example, I have john@abc.com. Every message received via SMTP for john@abc.com must be copied to mary@abc.com. And likewise anytime john@abc.com relays a message through HMS via SMTP, I need a copy to go to mary@abc.com as well.
Basically everything that is received via SMTP for abc.com should be copied to mary@abc.com and anytime HMS relays a message from the abc.com domain, mary@abc.com must be copied. Keep in mind that multiple domains are hosted here and its just this one domain that wants this functionality.
In the Domains - Accounts, screen, I set the "Forward to" and "Keep Message" and that appears to works perfectly. But I cannot figure out how to set up the latter problem?
I tried to define a rule as follows:
"Where From contains @abc.com Forward to mary@abc.com"
Nothing I try is working? Any help is appreciated,
Atreyu
8)
Re: Need help with "Forward to" in Rules
Post by katip » 2015-07-31 18:58
create an account such as fwd_abc@abc.com
goto settings -> advanced -> mirror -> fwd_abc@abc.com
define your rules in account rules of fwd_abc@abc.com where you forward anything related to abc.com to mary@abc.com and don't forget to drop (delete) all the rest.
this isn't an elegant solution but it should work i think.
scripting will do the job perfectly. i've no clue how.
Atreyu4055
Post by Atreyu4055 » 2015-07-31 20:37
Thanks for the reply, I will continue to research this and look into scripting.
Post by mattg » 2015-08-01 01:28
Atreyu4055 wrote: But I cannot figure out how to set up the latter problem?
In a global rule, NOT AN ACCOUNT LEVEL RULE, this should work (it does for me. I have rules to get copies of all email sent by my kids. I have a rule for each kid)
