Restricting E-mailing by Certian Users
jckelley
Post by jckelley » 2005-10-19 23:38
What i have done is restrict sending outside of the domain for only certian individuals, but allow free reign to the rest of the users. I did this by using this code:
	Dim ReRoute
	ReRoute = False
	Dim oRecipients
	Set oRecipients = oMessage.Recipients
	For i = 0 To oRecipients.Count - 1
		If oRecipients(i).IsLocalUser = False Then ReRoute = True
	If InStr(oMessage.From, "someone@somewhere") And ReRoute = True Then
		ReRoute = True
		ReRoute = False
	If ReRoute = True Then
		Result.Value = 1
		Result.Value = 0
Now the problem with this code it is not very scalable. My thought to improve it is to create a list of names in an array and compare aginst the array. Not sure how to do that in vbScript, but i am sure someone has, and when i figure it out i will post it. However if there is a better way of doing this i would be greatly appreciative.
Jason C. Kelley
