I am wondering how the field "receipient list" work?
I am trying to do filtering on the follow:
1) when receive unknown email account of local domain eg sde@abc.com,
I will do a catch-all using webmaster@abc.com and distribute to
user1@abc.com
2) Using filering at user level. At user1 account, i do a filtering to delete
those unknown email using rules "receipeint list" -> "not contains" ->
"user1@abc.com"
3) Whenever someone sent To or Cc to user1@abc.com, it is still working.
4) However I sent a test mail using test@abc.com (unknown account), the
filtering is not working. I suppose it will check for receipient user and do
a delete of the mail when the mail does not consist user1@abc.com.
5) I try to use "receipeint list" -> "not contains" -> "*user1@abc.com*",
hmm.. it can filter away the unknow user mail but when i try send To or
Cc, it is not working.
Any advise or other alternative to achieve the above scenario?
hMailServer 4.1 - Build 136
email filtering
similar problem ??? http://www.hmailserver.com/forum/viewtopic.php?t=2766
Linkit, you put a link to the wrong thread here but I assume you meant this one:
http://www.hmailserver.com/forum/viewto ... 6783#16783
Check out that thread, i just posted something for you.
