Integration with AD
jr3151006
Integration with AD
Post by jr3151006 » 2015-01-12 15:56
there is a way to integrate with AD? Let me explain two situations:
- create mailboxes for each user account inside our AD (during install of a new server for that environment);
- enable user to use their mailbox with the same password as their AD credentials (obvisouly sync when changed). In this case, If I disable an account at AD, this mailbox should be unable to log-in, ok!?
>>> Is that possible?
tks,
Renato P
Re: Integration with AD
Post by mattg » 2015-01-12 16:24
AD integration in hmailserver is limited
https://www.hmailserver.com/documentati ... ce_account
