Enabling SSL Where Did i Go wrong ?
timex163
Post by timex163 » 2014-08-31 22:55
Greetings !
So i just created an SSL certificate with startssl and installed it on hmailserver. I followed the installation process in the https://www.hmailserver.com/documentati ... rtificates . I also opened inbound 465 and 993 on the firewall. And still can't get people to connect using ssl. Anyone got any sort of recommendation ?
I tried Thunderbird locally and from my computer to try to log in using ssl.
Thanks for all your help !
Re: Enabling SSL Where Did i Go wrong ?
Post by mattg » 2014-09-01 02:13
Did you remove the certificate password?
Does it work without using SSL?
timex163
Post by timex163 » 2014-09-01 08:13
OH GREAT ONE ! Thank you for answering my post.
Yes I did, I basically used this command.
openssl rsa -in privkey_with_passphrase.key -out privkey_without_passphrase.key
Did i mess up that part ?
Post by mattg » 2014-09-01 10:09
I don't use openSSL so I am unsure if that is correct or not
I like this walk through >> viewtopic.php?f=12&t=22371
timex163
Post by timex163 » 2014-09-02 03:12
Ok it seems to have fixed itself.
This what I did go figure why it did not accept incoming data.
I simply created the autoconfig file with subdomain, made a reboot And everything went good.
But what i am getting now is that my ssl are not Valid.
timex163
Post by timex163 » 2014-09-02 03:17
Fixed. I had to add the PEM certificat at the end of the main certificat.
