Database connection lost - Error 25039
hmailadmin1
Post by hmailadmin1 » 2014-07-30 17:25
Hi Ladies and gents,
Hope everyone is well and TIA for taking a look at my post.
Here is my situation and I am hoping this is just as easy to fix.
1: All was working perfect - love hmailserver!!!
2. I purchased a bigger SSD and moved the entire hmailserver dir to the SSD via symbolic links in windows ( Stopped service of course )
3. Now the service starts but when I try to logon to the server I get the error stated in the subject line :
" The connection to the database is not available. Database connection error : Source: Microsoft SQL SErver Compact OLE DB Provider, Error: 25039.
Check your database settings in hmailserver.ini"
4. Checked them and saw it was still pointing to my old dir, so I pointed the file to the new dir. ( Thinking it might not be understanding sym links that well)
I am stumped right now and performed a search for my specific error and only found one post with my error.
I did not want to continue to play around and rather ask for assistance ( If it wasnt a mail server I would continue to play and try to figure out more)
Any help would be completely appreciated!
P.S I do not see a microsoft sql service under my services and I downloaded a tool to connect to it and it also states there are no connections currently on the machine. Is that normal?
Thank you in advance!
Tony.
hmailadmin1
Re: Database connection lost - Error 25039
Post by hmailadmin1 » 2014-07-30 17:30
Never mind just figured it out..... Though I will post my response in case anyone has same issue.
Check NTFS permissions - I needed to remove a user group even though I had added my user running the service.
NTFS is most restrictive and I had not noticed the "Users" group was set to Read, thus trumping my other user with the modify access.
Hope this helps someone in the future!
Post by ^DooM^ » 2014-07-31 23:11
Thanks for posting your response. Hate windows permissions at times :D
