Disable local mail - treat as external
nmay1990
Post by nmay1990 » 2014-06-09 17:49
Hi everyone,
I have been playing with hmail server for a few weeks now with no luck. Basically i want to use it an outgoing relay for all mail so it adds a signature and disclaimer to all emails sent from within our offices.
The client computers would connect to hmailserver (it would add the signature) then send it to our hosting companies mail server to be sent out the recipients.
Got it all working as far as external emails go, but i can send to anyone within the offices, as its treating the emails as internal and doing a local delivery so no one is receiving mail, i need all mail to be treated as external mail. I have tried changing my domain to 'domain.local' which work but then it fails to add the signature and disclaimer?
I have used the SMTP relay and routes but still no luck!
I really am banging my head against a wall, is this even possible?
Thanks in advance
Re: Disable local mail - treat as external
Post by mattg » 2014-06-10 00:19
If the address is hosted locally, hmailserver will ALWAYS deliver locally
This is NOT configurable.
Other addresses at the same domain can be sent externally using a route
Post by Bill48105 » 2014-06-10 02:09
sounds like you got the right idea using .local but you won't be able to use hmail's built-in signatures. Just do it in a script then.
