OpenSSL 1.0.1h Fixes Serious Bug
Need to integrate OpenSSL 1.0.1h ASAP.
Re: OpenSSL 1.0.1h Fixes Serious Bug
Thx will work on getting a new experimental posted ASAP. In the meantime you can always use the special build I posted with openssl dynamically linked if need be.mpfrench wrote:Need to integrate OpenSSL 1.0.1h ASAP.
Ok posted:
2014-06-05 5.4-B2014060501
* IMPORTANT: This build has a LOT of extra debug logging but NOT shown by default. [Settings]LogLevel=10 for some extra to 100 for extremely verbose
* URGENT: Critical OpenSSL MitM vulnerability http://www.pcworld.com/article/2360560/ ... pying.html
* Upated hmailserver to openssl-1.0.1h
* FIX: Added new 250 Help as always last EHLO response to fix 250-STARTTLS gmail issue (Last in list MUST be space not dash)
Bill, your log date is off by a month.
are you sure?mpfrench wrote:Bill, your log date is off by a month.
Did you try it?
thx
Somebody corrected the date. It is OK now.
lol yes i didmpfrench wrote:Somebody corrected the date. It is OK now.
Soo.. Did you actually try the new build since you were the one who pointed out the bug?
So take it no one was excited that I posted up a new build so quickly?
I just installed the new build and will let you know how it does after it runs a while.
Thx. Guess it's a good sign if it actually runs as I didn't test it at all.mpfrench wrote:I just installed the new build and will let you know how it does after it runs a while.
People must not be as concerned with this as heartbleed as seems less of a sense of urgency from people.
Thx
This one had been in the wild for 15 years, and relies on a Man-in-the-middle type attack.
Still very troubling though
THX Bill for your fast response. I'll test it too.
Indeed been around a long time but once exposed all bets are off as it'll be hot spot for attacks now. I mean it's a 15 year old bug turned into a zero day vulnerability now that it's publicized lolmattg wrote:This one had been in the wild for 15 years, and relies on a Man-in-the-middle type attack.
Ok great thanks.prisma wrote:THX Bill for your fast response. I'll test it too.
Yes indeed...Bill48105 wrote:I mean it's a 15 year old bug turned into a zero day vulnerability now that it's publicized lol
To be honest I gave up on SSL after the heartbleed stuff.
I would have to pay to revoke the StartSSL certificates that I was using, and well, if I'm going to pay, I'll buy a certificate up front from a company with some real customer service, not just attitude.
I haven't done that yet, as SSL isn't a complete solution to security or privacy issues.
So sorry, I can't help test this at the moment...
indeed. all boils down to what you are trying to protect from who. if someone wants yer stuff bad enough they will get it. so I figure it's for casual protection. sadly many people assume it protects more than it does but that's not our problem.mattg wrote:Yes indeed...Bill48105 wrote:I mean it's a 15 year old bug turned into a zero day vulnerability now that it's publicized lol
cheers
For what it's worth, a new release is now up which includes OpenSSL 1.0.1h
ok thanks martinmartin wrote:For what it's worth, a new release is now up which includes OpenSSL 1.0.1h
Bill, I have been running your beta build for a week now without noticing any problems. I assume that this is equivalent to the latest production build that Martin released.
OK cool glad it's working. Actually the 2 builds are so out of sync these days in reality they are quite different. But you'd have to compare changelogs to see what changed in each & if they apply to you or not. For most people using either should be close enough to the same to not make a difference but for others it could be. Generally speaking though if things are working & you don't need feature that's in the other then stick with what you have. I use the experimental builds myself but then again they are my builds more suited for my needs too.mpfrench wrote:Bill, I have been running your beta build for a week now without noticing any problems. I assume that this is equivalent to the latest production build that Martin released.
