Hmailserver & ownCloud
RuiBranco
Post by RuiBranco » 2014-06-05 12:42
Anyone here have experienced with hMailServer + owncloud?
I not get any error from owncloud but also I not get emails from files I share via owncloud.
I have this configuration in owncloud, the same I use with gmail and works.
 'mail_smtpmode' => 'smtp',
  'allowZipDownload' => true,
  'mail_smtphost' => 'smtp.xxx.info',
  'mail_smtpport' => 465,
  'mail_smtpsecure' => 'ssl',
  'mail_smtpauth' => true,
  'mail_smtpauthtype' => 'LOGIN',
  'mail_smtpname' => 'no-reply@xxx.info',
  'mail_smtppassword' => 'mypasswd',
Any suggestion for hmailserver configuration?
timex163
Re: Hmailserver & ownCloud
Post by timex163 » 2014-08-31 22:31
Enable Debug,
Then disable Spam protection.
Test again if you receive message.
If you do that means something is wrong on your end. Check if you spam threshold is too low.
If you did not get anything Look on the debug log if there anything from there server.
Like an auth request or something.
Post by mattg » 2014-09-01 02:12
Also, do you have hMailserver set up with an SSL certificate?
Post by percepts » 2014-09-01 17:04
ALSO
port 465 is not enabled by default. You must create it in TCP/IP Ports settings
