Can I "Move to IMAP folder" in OnDeliverMessage?
rstarkov
Post by rstarkov » 2014-02-16 20:28
I've been running into limitations of Rules for a while now, mostly the inability to write proper boolean conditions, like "A & (B | C | D)". I've always thought I will eventually just use scripting for this. Now that I've given it a go, however, it appears that I can't: OnDeliverMessage cannot move the message to an IMAP folder like a Rule can (although the last post I found to mention this was in 2008).
Another limitation is that I have some global rules that I want to run before all the account rules, then I want some per-account rules to run, and then some more global rules. Again, was hoping to fix this by using scripts.
Is it still the case that I cannot fully replicate the "Move to IMAP folder" action in a script?
Re: Can I "Move to IMAP folder" in OnDeliverMessage?
Post by percepts » 2014-02-17 05:16
REGEX is your friend.
rstarkov
Post by rstarkov » 2014-02-17 15:12
Not for the general case of "if (Header1 == A) && (Header2 == B || Header3 == C)". I did this once, by using multiple rules and setting an intermediate header value, but that is one unmaintainable mess of rules, so I was hoping to replace it all with a script.
Got my answer though. Thanks.
Post by mattg » 2014-02-17 15:40
It should be possible from a script
The complete Admin GUI is written using the COM API, so if it can be done using the Admin GUI, it can be done someway via the COM API.
I checked, I only use account or global level rules to move mail into public folders, I don't do it by script, but I feel sure that it should be possible.
