Reload root directory files
kevin@wine.co.za
Post by kevin@wine.co.za » 2013-09-12 16:49
Is it possible to only reload the root data directory files into the database ( using DataDirectorySynchronizer ) / re-queue files in the root data folder
I have had to manually remove a whole load of spam files and clean up the hm_messages table
But now I have 1000+ legitimate looking emails in my root folder that I need to get into the queue
Any ideas ?
Re: Reload root directory files
Post by percepts » 2013-09-12 17:23
yes, running dds should deliver them all to inboxes
kevin@wine.co.za
Post by kevin@wine.co.za » 2013-09-12 17:28
Thanks - But how do I do this ONLY on the root folder , so that it does not screw up all the client folders
Post by percepts » 2013-09-12 17:52
you can't. If the eml files are in the data folder then they will get delivered (to local addresses only) and be in the users inbox with unread status.
Post by mattg » 2013-09-13 01:18
If the files are in the root data directory, simply restarting hMailserver service should cause them all to be picked up
