The local connect test was fail
trixas
Post by trixas » 2012-12-10 14:40
Hi sir,please check my problemn as following:
The test local connect was fail all the time.
The ports are opened.
And the test result was attached.
my computer OS is win7 pro.
What can I do? Thank you very much.
bagu
Re: The local connect test was fail
Post by bagu » 2012-12-10 15:02
Are you sure you allow hmailserver in windows 7 firewall ?
Is you port 25/TCP redirect to you server from your router ?
When i do a port check on 218.85.65.150 ( http://www.yougetsignal.com/tools/open-ports/ ) i get "Port 25 is closed on 218.85.65.150."
trixas
Post by trixas » 2012-12-10 16:21
I have tried to close the firewall,but still invalid .
Is you port 25/TCP redirect to you server from your router ? If no,what shall I do?
so what can I do as the port was closed? Change the IP? How ?
Thanks again.
Post by mattg » 2012-12-11 12:09
That 'test local connect' isn't necessarily fatal.
It is normally caused by your router not handling loopback.
If this actually affects usage (and mostly it won't) then you can add an entry to your C:\windows\system32\drivers\etc\hosts file
