Issue 264: Searching for strings in UTF8 format did not work
Tim Josten
Post by Tim Josten » 2012-10-16 11:55
Hello Martin!
Looks like UTF-8 searching still doesn't work in 5.3.3 or newer versions. I am using Roundcube 0.8 beta. I am russian. If I search for email subjects written in english it works fine. Once I enter any russian word, it returns empty list. I think this is not a Roundcube problem. Here's the log:
"IMAPD"	4376	85538	"2012-10-16 16:29:02.365"	"127.0.0.1"	"SENT: * OK IMAPrev1"
"IMAPD"	4376	85538	"2012-10-16 16:29:02.367"	"127.0.0.1"	"RECEIVED: A0001 CAPABILITY"
"IMAPD"	4376	85538	"2012-10-16 16:29:02.367"	"127.0.0.1"	"SENT: * CAPABILITY IMAP4 IMAP4rev1 CHILDREN IDLE QUOTA SORT ACL NAMESPACE RIGHTS=texk[nl]A0001 OK CAPABILITY completed"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.368"	"127.0.0.1"	"RECEIVED: A0002 LOGIN tim@***.ru ***"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.371"	"127.0.0.1"	"SENT: A0002 OK LOGIN completed"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.376"	"127.0.0.1"	"RECEIVED: A0003 SELECT INBOX"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.377"	"127.0.0.1"	"SENT: * 55 EXISTS[nl]* 0 RECENT[nl]* FLAGS (\Deleted \Seen \Draft \Answered \Flagged)[nl]* OK [UIDVALIDITY 1332767657][nl]* OK [UIDNEXT 325][nl]* OK [PERMANENTFLAGS (\Deleted \Seen \Draft \Answered \Flagged)][nl]A0003 OK [READ-WRITE] SELECT completed"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.378"	"127.0.0.1"	"RECEIVED: A0004 UID SORT (DATE) UTF-8 ALL TEXT {12}"
"IMAPD"	4412	85538	"2012-10-16 16:29:02.379"	"127.0.0.1"	"SENT: + Ready for additional command text."
"IMAPD"	4376	85538	"2012-10-16 16:29:02.380"	"127.0.0.1"	"RECEIVED: запрос"
"IMAPD"	4376	85538	"2012-10-16 16:29:03.687"	"127.0.0.1"	"SENT: * SORT"
"IMAPD"	4376	85538	"2012-10-16 16:29:03.689"	"127.0.0.1"	"SENT: A0004 OK UID completed"
"IMAPD"	4416	85538	"2012-10-16 16:29:03.691"	"127.0.0.1"	"RECEIVED: A0005 LOGOUT"
"IMAPD"	4416	85538	"2012-10-16 16:29:03.692"	"127.0.0.1"	"SENT: * BYE Have a nice day[nl]A0005 OK Logout completed"
hMailServer correctly outputs UTF-8 string in log (RECEIVED: запрос), but no search results. I found this code in hMailServer source:
   bool ContainsNoCase(PCMYSTR szSub) const
      MYTYPE sFindIn = this->c_str();
      MYTYPE sLookFor = szSub;
      // Convert to lower case so that we'll do the search in
      // an in-case sensitive manner.
      sFindIn.ToLower();
      sLookFor.ToLower();
      if (sFindIn.Find(sLookFor) >= 0)
         return true;
      else
         return false;
Maybe it incorrectly compares strings in Unicode? Or lowercase function corrupts data?
Tim Josten
Re: Issue 264: Searching for strings in UTF8 format did not
Post by Tim Josten » 2012-10-17 18:21
Well, I figured it by myself.
Roundcube sends the incorrect command. :) Totally no offense to the author of hMailServer.
It miss the CHARSET word:
A0004 UID SORT (DATE) UTF-8 ALL TEXT ...
Correct command is:
A0004 UID SORT (DATE) CHARSET UTF-8 ALL TEXT ...
Now it works fine!
Tim Josten
Post by Tim Josten » 2012-10-18 06:51
Here comes another problem, now on the server side. There are lots of messages in my inbox folder. Some of them are in UTF-8, some are in Windows-1251, some are in KOI8-R codepage. I can only search for UTF-8 messages.
For example:
Subject: =?KOI8-R?B?UmU6IO/v7yDu4ec=?=
Notice the KOI8-R prefix. hMailServer doesn't handle this currently.
dzekas
Post by dzekas » 2012-10-18 07:31
Tim Josten wrote:Here comes another problem, now on the server side. There are lots of messages in my inbox folder. Some of them are in UTF-8, some are in Windows-1251, some are in KOI8-R codepage. I can only search for UTF-8 messages.
For example:
If you think that you have found deficiency in hmailserver implementation and have a way to reproduce it in latest published dev version, could you register ticket in bug tracker?
