Error: Failed to load certificate file
Rainer
Post by Rainer » 2012-07-20 10:42
I've orderd a 2048 Bit SSL-Cerificate via Symantec.
I've copied the certificate-text to a file named mycert.cert
In HMS I used the key-file for the private-key-file and the cert-file for the certificate-file.
The ports for SMPTS is 465, for IPMAPS is 993 and for POP3S is 995.
The server was restarted.
After restart I get the following error: Failed to load certificate file.
My cert-file begins with: -----BEGIN PKCS #7 SIGNED DATA-----
And ends with: -----END PKCS #7 SIGNED DATA-----
I thing my ssl-certificate is wrong?
Kind regards
Rainer Noa
Caspar
Re: Error: Failed to load certificate file
Post by Caspar » 2012-07-20 12:17
are you sure that the certificate that Hmailserver is using is not encrypted, so it does not require a password to access it?
Also try to follow the folloing manual: http://www.hmailserver.com/forum/viewto ... 12&t=22371
Post by ^DooM^ » 2012-07-20 12:33
Check admin and see if you have multiple \\ in certificate path.
Rainer
Post by Rainer » 2012-07-20 12:56
Hello Caspar, and hello Doom,
THX for your fast answers!
I used this: http://www.hmailserver.com/forum/viewto ... 12&t=22371 and it looks like the ssl now works.
No more errors - is ist possible to test it?
Kind regards :)
Rainer Noa
Caspar
Post by Caspar » 2012-07-20 12:57
In the first post there, you can see how you can check it using OpenSSL just scroll down to the last part of it.
Rainer
Post by Rainer » 2012-07-20 13:05
Hello Caspar,
mea culpa - RTFM helps!
All works fine!
THX for your help and greetings from Germany :P
Rainer Noa
