S/MIME signature corrupted with attachments
mikew
Post by mikew » 2012-07-13 17:08
hMailserver 5.3.3-B1879 is corrupting S/MIME signatures, when the mail has attachments.
The problem occurs due to modified MIME headers in multi-part messages.
For example, the correct mail contains the following MIME header (note: multiple lines; "filename" indented). That's how Thunderbird creates the mail.
Content-Disposition: attachment;
 filename="attachment.txt"
After reception with hMailserver it looks like this (note: a single line).
Content-Disposition: attachment; filename="attachment.txt"
When I copy the original MIME headers to the received mail, the S/MIME signature matches again. The MIME body is not touched.
smime.zip
Mail bodies.
(1.98 KiB) Downloaded 95 times
Re: S/MIME signature corrupted with attachments
Post by ^DooM^ » 2012-07-13 17:45
Anything else in the way such as AV / ASSP / SA / DPI firewall etc?
mikew
Post by mikew » 2012-07-13 18:26
Nope.
The test mails have been sent directly to hMail's local SMTP. The issue also occurs when hMail is collecting from extern POP3.
ClamAV is called as a command line scanner in hMailserver when receiving the Mail. This was the only virus scanner in the whole send-receive-chain and should have no way to modify the message content.
The client (Thunderbird) fetches via IMAP. With other (external) servers this issue does not occur.
Post by ^DooM^ » 2012-07-14 09:57
Ok check to see if the issue is not listed here http://www.hmailserver.com/devnet/?page=issuetracker if it's not please add it with steps on exactly how to recreate the issue.
Cheers!
mikew
Post by mikew » 2012-07-14 12:08
I created issue 385.
Thanks for the help so far!
