cgountanis
- Normal user
Post
by cgountanis » 2005-07-28 22:16
What if I want hMailServer to only listen on one public IP not all. Do I still need the 127.0.0.1?
- Developer
Post
by martin » 2005-07-28 22:18
As far as I know, there's no requirement that a Windows application _must_ listen on 127.0.0.1. And there couldn't really be one, because what if you have two SMTP servers running on the same machine both listening on port 25. Then both couldn't listen on 127.0.0.1.
Why do you ask?
cgountanis
- Normal user
Post
by cgountanis » 2005-07-28 22:36
I have a server on 8 public IP addresses. I only want one ip to be listening on 25,110 and 143 can that be done?
- Developer
Post
by martin » 2005-07-28 22:40
Yes.
But since you're not even bothering to write what version you're using, I'm not bothering to tell you how.
cgountanis
- Normal user
Post
by cgountanis » 2005-07-28 22:46
In SIG
Still need it to work with SM ALT.
