Using IP ranges to block SMTP auth from outside
Tim Josten
Post by Tim Josten » 2012-03-28 06:44
Hello!
I am currently setting up hMailServer and faced the following problem.
For example, I created user Tim, set password to 1234. I can send email to the outside from my local network.
I can receive emails from the outside. But how do I block access to SMTP from the outside (so no one can send email using Tim's account and his password, leaving only incoming "extrernal to local" mail allowed from the outside)?
Yes, I can set the more strong password, but that's the other thing...
Re: Using IP ranges to block SMTP auth from outside
Post by ^DooM^ » 2012-03-28 10:34
You would have to script this checking IP on Auth to make sure it's local/lan.
The code below rejects connections on SMTP except for local, you can expand on this to check for auth and so on.
Sub OnClientConnect(oClient)
    Result.Value = 0
    If oClient.Port = 25 Then
        If StrComp("127.0.0.0", "127.0.0.1") Then
        ' We only allow SMTP connections from local host.
        Result.Value = 1
        End if
http://www.hmailserver.com/documentatio ... ce_scripts
http://www.hmailserver.com/documentatio ... om_objects
Tim Josten
Post by Tim Josten » 2012-03-28 10:57
Thank you! That's what I was looking for. Will give it a try.
Tim Josten
Post by Tim Josten » 2012-03-29 05:26
Well, OnClientConnect cannot be expanded to process auth stuff, since it is fired right after TCP connection is established (long before SMTP HELO is sent, etc).
So, I am thinking about other events like:
OnAcceptMessage
OnDeliveryStart
OnDeliverMessage
Post by mattg » 2012-03-29 06:24
it depends on what you want to do
OnClientConnect does have port and connecting IP address, but not much else
The others give a bit more that you can use, and of course the timing is different between them
