Failed to create COM object `hMailServer.Application':
dgaebler
Post by dgaebler » 2012-01-24 12:48
I know this is already discussed in several topics. I have read them all. I try to get the web admin to work since one year now without success. And there where no new posts regarding this topic since months.
My settings:
The error message is:
Failed to create COM object `hMailServer.Application': Zugriff verweigert
This problem is often caused by DCOM permissions not being set.
I run a Windows Web Server 2008 R2 with SP1 German language
with IIS 7.5
hmailserver 5.3.3
PHP Version 5.2.13 with Windows Cache Extension 1.0 for PHP 5.2
I use fast CGI
I followed the DCOM permission guideline and tried even to allow "everyone" without success. The php.ini files are changed regarding the required section settings.
What else can be done?
Re: Failed to create COM object `hMailServer.Application':
Post by mattg » 2012-01-24 13:50
Is the phpwebadmin being installed on the SAME computer that hMailserver is installed on?
Did you install the phpwebadmin that came with the current version of hMailserver?
dgaebler
Post by dgaebler » 2012-01-24 16:09
both yes
Post by mattg » 2012-01-25 05:55
Can you post a link to your phpinfo, or copy the text and post it please
dgaebler
Post by dgaebler » 2012-01-25 09:50
I attached the phpinfo as gz pdf document.
phpinfo().pdf.gz
(74.98 KiB) Downloaded 272 times
Post by mattg » 2012-01-25 15:44
I have windows 7 Ultimate(SP1) - IIS 7.5, PHP 5.3.8 fast CGI
My PHPInfo shows that 'DCOM support' is NOT enabled, and 'com.allow_dcom' is 0 for both local and master value.
I used the PHP manager from >> http://php.iis.net/
I set DCOM permissions as per this >> http://www.hmailserver.com/documentatio ... ermissions
PHPWebAdmin works for me
Also, my 'sendmail_from' is null - but that should only matter if you use PHP to send email.
dgaebler
Post by dgaebler » 2012-01-25 16:15
Thank you for the hints.
I tried to set
com.allow_dcom = 0
but nothing changed.
Regarding the dcomcnfg.exe I tryed even to grant permission to everyone. But it did not work. Unfortunately all the given examples name the englisch names of the users. So I am not 100% sure if I took the right ones.
At the moment I have given IUSR and IIS_IUSRS the right for "Lokaler Start" and "Lokale Aktivierung". Maybe there is something wrong?
dzekas
Post by dzekas » 2012-01-25 19:11
dgaebler wrote:Thank you for the hints.
I tried to set
com.allow_dcom = 0
Newer PHPs do not run on IUSRsomething. They run on network service account.
dgaebler
Post by dgaebler » 2012-01-25 20:36
I tried "Netzwerk" and "Netzwerkdienst" as well and it does not change anything. Can someone post a screen shot of the settings. In the meanwhile I do not trust in me anymore.
eXpress48
Post by eXpress48 » 2012-01-29 00:17
Hi
I have exactly the same as dgaebler. I tried all the tips in this Thread but i only get:
when i want to access to the webadmin.
I'm running PHP 5.3.9 on IIS 7.5 on a Windows Server 2008 R2 Datacenter.
Anyone has an idea what is wrong?
Thx
Regards
eXpress48
Khurram
Post by Khurram » 2012-10-03 16:40
I know its an old thread, but I fixed the same problem (Failed to create COM object `hMailServer.Application'.....) I had with php 5.4.7 on XP. So I am posting it here for others.
Giving the anonymous user permissions in DCOM does not do anything because the newer PHPs don't run under that account. I used the excellent SysInternal's Process Monitor to find out which user account PHP was using. It turned out to be the IWAM_<machinename> account. I gave this account permissions in DCOM and PHPWebAdmin started running.
NOTE: Your installation might be different. So before giving this account DCOM permissions, run Process Monitor to double check which account PHP is using.
chrish76
Post by chrish76 » 2013-02-26 11:42
Hi
actual i facing the same issue as dgaebler
dgaebler can you fix the Problem in the Meantime?
jr3151006
Post by jr3151006 » 2013-07-01 20:46
I faced the same trouble here, you should set DCOM permissions as the article (http://www.hmailserver.com/documentatio ... ermissions) for the following objects;
User = "SERVERNAME\IUSR"
Group = "SERVERNAME\IIS_IUSRS"
Worked fine!
