What is 2? ANyone have a manual on using clamd with hMail for lower cpu usage.
"DEBUG" 2412 "2005-07-14 22:10:08.406" "ClamWinVirusScanner::Scan()"
"DEBUG" 3020 "2005-07-14 22:10:08.421" "SocketConnection::~SocketConnection()"
"DEBUG" 2412 "2005-07-14 22:10:08.437" "ClamWinVirusScanner::Scan() - C:\ClamAV\bin\clamdscan.exe --database='C:\ClamAV\share\clamav' '{2382597E-E10A-4EFA-BD54-A0F4266F56F0}.eml' --tempdir='C:\WINNT\Temp' - Returned 2"
"DEBUG" 2412 "2005-07-14 22:10:08.453" "ClamWinVirusScanner::~Scan()"
"DEBUG" 2412 "2005-07-14 22:10:08.453" "ClamWinVirusScanner::Scan()"
"DEBUG" 3020 "2005-07-14 22:10:08.468" "SocketConnection::SocketConnection()"
"DEBUG" 2412 "2005-07-14 22:10:08.468" "ClamWinVirusScanner::Scan() - C:\ClamAV\bin\clamdscan.exe --database='C:\ClamAV\share\clamav' '{9E20C12D-C8B9-45F2-847E-F77BF4374F2E}.tmp' --tempdir='C:\WINNT\Temp' - Returned 2"
"DEBUG" 2412 "2005-07-14 22:10:08.484" "ClamWinVirusScanner::~Scan()"
"DEBUG" 2412 "2005-07-14 22:10:08.484" "RuleApplier::ApplyRules"
"DEBUG" 2412 "2005-07-14 22:10:08.484" "RuleApplier::~ApplyRules"
"DEBUG" 2128 "2005-07-14 22:10:08.484" "PMADO:SaveObject()"
clamdscan.exe Returned 2 ?
- Normal user
This link lists the return codes a bit of the ways down
http://www.die.net/doc/linux/man/man1/clamdscan.1.html
2 is the uber descriptive, "An error occured."
- Normal user
How do you run in clamDscan hMail? I have the clamd running on 127.0.0.1 and start OK fromt he logs. Is there anything special I have to do in hMailServer EXE DB?
"DEBUG" 1456 "2005-07-14 23:13:01.000" "ADORecordset::~_GetRevertedIP()"
"DEBUG" 3208 "2005-07-14 23:13:01.000" "ClamWinVirusScanner::Scan() - C:\ClamAV\bin\clamdscan.exe --no-summary --stdout --database='C:\ClamAV\share\clamav' '{F7BD1C6A-BF1A-4405-8344-210BE68821DE}.eml' --tempdir='C:\WINNT\Temp' - Returned 2"
"DEBUG" 2172 "2005-07-14 23:13:01.000" "ClamWinVirusScanner::Scan() - C:\ClamAV\bin\clamdscan.exe --no-summary --stdout --database='C:\ClamAV\share\clamav' '{C571E23B-7F3B-49DE-B2DD-5836499B89D3}.tmp' --tempdir='C:\WINNT\Temp' - Returned 2"
"DEBUG" 1456 "2005-07-14 23:13:01.000" "BLCheck::~ClientExistsInDNSBL()"
USER CLAMWIN:
USER CLAMWIN:
- Normal user
Starting clamd just fine:
Thu Jul 14 23:12:44 2005 -> +++ Started at Thu Jul 14 23:12:44 2005
Thu Jul 14 23:12:44 2005 -> clamd daemon devel-20050712 (OS: cygwin, ARCH: i386, CPU: i686)
Thu Jul 14 23:12:44 2005 -> Log file size limited to 2097152 bytes.
Thu Jul 14 23:12:44 2005 -> Reading databases from C:\ClamAV\share\clamav
Thu Jul 14 23:12:47 2005 -> Protecting against 36446 viruses.
Thu Jul 14 23:12:47 2005 -> Bound to address 127.0.0.1 on tcp port 3310
Thu Jul 14 23:12:47 2005 -> Setting connection queue length to 30
Thu Jul 14 23:12:47 2005 -> Archive: Archived file size limit set to 15728640 bytes.
Thu Jul 14 23:12:47 2005 -> Archive: Recursion level limit set to 10.
Thu Jul 14 23:12:47 2005 -> Archive: Files limit set to 1000.
Thu Jul 14 23:12:47 2005 -> Archive: Compression ratio limit set to 250.
Thu Jul 14 23:12:47 2005 -> Archive support enabled.
Thu Jul 14 23:12:47 2005 -> Portable Executable support enabled.
Thu Jul 14 23:12:47 2005 -> Detection of broken executables enabled.
Thu Jul 14 23:12:47 2005 -> Mail files support enabled.
Thu Jul 14 23:12:47 2005 -> OLE2 support enabled.
Thu Jul 14 23:12:47 2005 -> HTML support enabled.
Thu Jul 14 23:12:47 2005 -> Self checking every 1800 seconds.
Thu Jul 14 23:23:23 2005 -> Exiting (clean)
Thu Jul 14 23:23:23 2005 -> --- Stopped at Thu Jul 14 23:23:23 2005
If clamscan works clamdscan shoud as well. Scanning with command lines that work with clamscan just fine but getting Returned 2 from hMailServer logs:
"ClamWinVirusScanner::Scan() - C:\ClamAV\bin\clamdscan.exe --no-summary --stdout --database='C:\ClamAV\share\clamav' '{7A087A84-4D96-4D71-ABD9-CFEC215D3FB9}.tmp' --tempdir='C:\WINNT\Temp' - Returned 2"
What am I doing wrong. One thing I can think of is how does clamdscan know what port to connect to? IS there a config or a command line param I should be using. I need returned 1 on the virus tests not 2 (error).
- Normal user
- Normal user
