Hello All,
This morning when I came to the office I found that a couple of my accounts arent able to access webmail, well...kinda.
Once I log in, the counter shows up (Email counter that loads all emails upon entry) and it wont get past a particular number. It seems to me that an email is corrupted, but I just cant seem to be able to find which one.
Also, I do get an error:
Internal Server Error. Please, contact your system administrator in order to report the problem.
which is very generic, Could someone please direct me in the right direction?
Thanks!
-DiTOH1
Unable to access any mailbox via webmail - Error found
Re: Unable to access any mailbox via webmail - Error found
Do you have all logging enabled?
Have you followed the troubleshooting docs?
If your webmail is in PHP, then you hit PHP memory limit in those emails.ditoh1 wrote:Hello All,
Thanks!
-DiTOH1
I am currently using AfterLogic WebMail Lite.
I do logging enabled on the server itself, but I cannot find anything related to webmail since the application is separate from HMail.
Thanks!!!
-D
-D
It can be in ASP or in PHP. Two different scripting engines. Two different ways of debugging it.ditoh1 wrote:I am currently using AfterLogic WebMail Lite.
