Spool Counter?
ditoh1
Spool Counter?
Post by ditoh1 » 2011-06-23 15:50
Hi All,
I was wondering if there is a script, or any type of application that would check the spool, and, depending on its size, send a notification via email; you know, in case of a spam attack.
Thanks!
-D
Thanks!!!
-D
Re: Spool Counter?
Post by ^DooM^ » 2011-06-23 16:56
none to my knowledge but you can easily access the database and check how many messages are in the queue or access the data directory and see how many files are in there.
Re: Spool Counter?
Post by Bill48105 » 2011-06-23 18:33
Actually I believe JamesDR in IRC made such a beast & thought he planned to share in the scripting forum but will check with him.
rolaids0
Re: Spool Counter?
Post by rolaids0 » 2011-06-23 19:09
Does with Nagios, however, could be modified to suit.
http://www.hmailserver.com/forum/viewto ... 20&t=20057
Re: Spool Counter?
Post by Bill48105 » 2011-06-23 19:15
Woo cool thx James! Reminds me I need to get that up & running here.
Re: Spool Counter?
Post by Bill48105 » 2011-06-23 22:20
OK I posted up a mod'd version of rolaids0 queue script that doesn't require nagios so can be run from task scheduler or called from monitoring tool (checking the return code if desired) where it sends an email if the queue is above the defined limit: http://www.hmailserver.com/forum/viewto ... 32#p126932
