Script Upgrade5320to5400MSSQL.sql
mns17
Post by mns17 » 2011-05-26 16:57
This script in hMailServer-5.4-B1925.exe is incorrect.
Script must by like this:
insert into hm_settings (settingname, settingstring, settinginteger) values ('EnableWhitelisting', '', 1)
update hm_whitelist set whiteemailaddress = replace(whiteemailaddress, '/', '//')
update hm_whitelist set whiteemailaddress = replace(whiteemailaddress, '%', '/%')
update hm_whitelist set whiteemailaddress = replace(whiteemailaddress, '_', '/_')
update hm_whitelist set whiteemailaddress = replace(whiteemailaddress, '?', '_')
update hm_whitelist set whiteemailaddress = replace(whiteemailaddress, '*', '%')
update hm_greylisting_whiteaddresses set whiteipaddress = replace(whiteipaddress, '/', '//')
update hm_greylisting_whiteaddresses set whiteipaddress = replace(whiteipaddress, '%', '/%')
update hm_greylisting_whiteaddresses set whiteipaddress = replace(whiteipaddress, '_', '/_')
update hm_greylisting_whiteaddresses set whiteipaddress = replace(whiteipaddress, '?', '_')
update hm_greylisting_whiteaddresses set whiteipaddress = replace(whiteipaddress, '*', '%')
delete from hm_settings where settingname = 'tarpitdelay'
delete from hm_settings where settingname = 'tarpitcount'
insert into hm_settings (settingname, settingstring, settinginteger) values ('MaxNumberOfMXHosts', '', 15)
insert into hm_settings (settingname, settingstring, settinginteger) values ('ClamAVEnabled', '', 0)
insert into hm_settings (settingname, settingstring, settinginteger) values ('ClamAVHost', 'localhost', 0)
insert into hm_settings (settingname, settingstring, settinginteger) values ('ClamAVPort', '', 3310)
update hm_dbversion set value = 5400
Re: Script Upgrade5320to5400MSSQL.sql
Post by ^DooM^ » 2011-05-26 17:03
Why do you say that?? You cant just say it's wrong and not give reasons why.
mns17
Post by mns17 » 2011-05-26 17:06
Doom
Script Upgrade5320to5400MSSQL.sql is wrong.
Because original script is DELETE table and CREATE table!!!
DBUpdater give the error if you try original script!
hm_drop_table_objects 'hm_accounts'
alter table hm_accounts alter column accountaddress nvarchar(255) not null
alter table hm_accounts alter column accountpassword nvarchar(255) not null
alter table hm_accounts alter column accountforwardaddress nvarchar(255) not null
ALTER TABLE hm_accounts ADD CONSTRAINT hm_accounts_pk PRIMARY KEY NONCLUSTERED (accountid)
ALTER TABLE hm_accounts ADD CONSTRAINT u_accountaddress UNIQUE NONCLUSTERED (accountaddress)
CREATE CLUSTERED INDEX idx_hm_accounts ON hm_accounts (accountaddress)
hm_drop_table_objects 'hm_aliases'
alter table hm_aliases alter column aliasname nvarchar(255) not null
alter table hm_aliases alter column aliasvalue nvarchar(255) not null
ALTER TABLE hm_aliases ADD CONSTRAINT hm_aliases_pk PRIMARY KEY NONCLUSTERED (aliasid)
ALTER TABLE hm_aliases ADD CONSTRAINT u_aliasname UNIQUE NONCLUSTERED (aliasname)
CREATE CLUSTERED INDEX idx_hm_aliases ON hm_aliases (aliasdomainid, aliasname)
hm_drop_table_objects 'hm_domains'
alter table hm_domains alter column domainname nvarchar(80) not null
alter table hm_domains alter column domainpostmaster nvarchar(80) not null
alter table hm_domains alter column domainplusaddressingchar nvarchar(1) not null
ALTER TABLE hm_domains ADD CONSTRAINT hm_domains_pk PRIMARY KEY NONCLUSTERED (domainid)
ALTER TABLE hm_domains ADD CONSTRAINT u_domainname UNIQUE NONCLUSTERED (domainname)
CREATE CLUSTERED INDEX idx_hm_domains ON hm_domains (domainname)
alter table hm_domain_aliases alter column daalias nvarchar(255) not null
alter table hm_messages alter column messagefilename nvarchar(255) not null
alter table hm_messages alter column messagefrom nvarchar(255) not null
hm_drop_table_objects 'hm_settings'
alter table hm_settings alter column settingname nvarchar(30) not null
ALTER TABLE hm_settings ADD CONSTRAINT hm_settings_pk PRIMARY KEY NONCLUSTERED (settingid)
ALTER TABLE hm_settings ADD CONSTRAINT u_settingname UNIQUE NONCLUSTERED (settingname)
hm_drop_table_objects 'hm_distributionlists'
alter table hm_distributionlists alter column distributionlistaddress nvarchar(255) not null
alter table hm_distributionlists alter column distributionlistrequireaddress nvarchar(255) not null
ALTER TABLE hm_distributionlists ADD CONSTRAINT hm_distributionlists_pk PRIMARY KEY NONCLUSTERED (distributionlistid)
ALTER TABLE hm_distributionlists ADD CONSTRAINT u_distributionlistaddress UNIQUE NONCLUSTERED (distributionlistaddress)
ALTER TABLE hm_distributionlistsrecipients alter column distributionlistrecipientaddress nvarchar(255) NOT NULL
CREATE CLUSTERED INDEX idx_hm_distributionlists_distributionlistdomainid ON hm_distributionlists (distributionlistdomainid)
hm_drop_table_objects 'hm_messagerecipients'
alter table hm_messagerecipients alter column recipientaddress nvarchar(255) not null
alter table hm_messagerecipients alter column recipientoriginaladdress nvarchar(255) not null
ALTER TABLE hm_messagerecipients ADD CONSTRAINT hm_messagerecipients_pk PRIMARY KEY NONCLUSTERED (recipientid)
CREATE CLUSTERED INDEX idx_hm_messagerecipients_recipientmessageid ON hm_messagerecipients (recipientmessageid)
hm_drop_table_objects 'hm_imapfolders'
alter table hm_imapfolders alter column foldername nvarchar(255) not null
ALTER TABLE hm_imapfolders ADD CONSTRAINT hm_imapfolders_pk PRIMARY KEY NONCLUSTERED (folderid)
CREATE CLUSTERED INDEX idx_hm_imapfolders_folderaccountid ON hm_imapfolders (folderaccountid)
ALTER TABLE hm_imapfolders ADD CONSTRAINT idx_hm_imapfolders_unique UNIQUE NONCLUSTERED (folderaccountid, folderparentid, foldername)
hm_drop_table_objects 'hm_routes'
alter table hm_routes alter column routedomainname nvarchar(255) not null
alter table hm_routes alter column routetargetsmthost nvarchar(255) not null
alter table hm_routes alter column routeauthenticationusername nvarchar(255) not null
alter table hm_routes alter column routeauthenticationpassword nvarchar(255) not null
ALTER TABLE hm_routes ADD CONSTRAINT hm_routes_pk PRIMARY KEY NONCLUSTERED (routeid)
ALTER TABLE hm_routes ADD CONSTRAINT u_routedomainname UNIQUE NONCLUSTERED (routedomainname)
alter table hm_routeaddresses alter column routeaddressaddress nvarchar(255) not null
alter table hm_dnsbl alter column sbldnshost nvarchar(255) not null
alter table hm_dnsbl alter column sblresult nvarchar(255) not null
alter table hm_dnsbl alter column sblrejectmessage nvarchar(255) not null
alter table hm_fetchaccounts alter column faaccountname nvarchar(255) not null
alter table hm_fetchaccounts alter column faserveraddress nvarchar(255) not null
alter table hm_fetchaccounts alter column fausername nvarchar(255) not null
alter table hm_fetchaccounts alter column fapassword nvarchar(255) not null
alter table hm_fetchaccounts_uids alter column uidvalue nvarchar(255) not null
alter table hm_rule_criterias alter column criteriaheadername nvarchar(255) not null
alter table hm_rule_criterias alter column criteriamatchvalue nvarchar(255) not null
alter table hm_rule_actions alter column actionimapfolder nvarchar(255) not null
alter table hm_rule_actions alter column actionfromaddress nvarchar(255) not null
alter table hm_rule_actions alter column actionscriptfunction nvarchar(255) not null
alter table hm_rule_actions alter column actionheader nvarchar(255) not null
alter table hm_surblservers alter column surblhost nvarchar(255) not null
alter table hm_surblservers alter column surblrejectmessage nvarchar(255) not null
hm_drop_table_objects 'hm_greylisting_triplets'
alter table hm_greylisting_triplets alter column glsenderaddress nvarchar(200) not null
alter table hm_greylisting_triplets alter column glrecipientaddress nvarchar(200) not null
ALTER TABLE hm_greylisting_triplets ADD CONSTRAINT hm_glid_pk PRIMARY KEY NONCLUSTERED (glid)
ALTER TABLE hm_greylisting_triplets ADD CONSTRAINT u_gltriplet UNIQUE NONCLUSTERED (glipaddress1, glipaddress2, glsenderaddress, glrecipientaddress)
hm_drop_table_objects 'hm_greylisting_whiteaddresses'
alter table hm_greylisting_whiteaddresses alter column whiteipaddress nvarchar(255) not null
ALTER TABLE hm_greylisting_whiteaddresses ADD CONSTRAINT hm_glwhite_pk PRIMARY KEY NONCLUSTERED (whiteid)
ALTER TABLE hm_greylisting_whiteaddresses ADD CONSTRAINT u_glwhite UNIQUE NONCLUSTERED (whiteipaddress)
alter table hm_servermessages alter column smname nvarchar(255) not null
alter table hm_whitelist alter column whiteemailaddress nvarchar(255) not null
Post by ^DooM^ » 2011-05-26 17:14
I see the additional commands but how do you know they are not necessary?
mns17
Post by mns17 » 2011-05-27 04:22
It's a very critical error!
Please, correct from the following version
Post by ^DooM^ » 2011-05-27 09:28
You should contact martin@hmailserver.com with your findings.
snico
Post by snico » 2011-10-09 16:28
Hello mns17,
I think you were scared when you see "hm_drop_table_objects 'hm_accounts'"
But this does not remove tables.
:D :D
Nicolas Cavaré
hMailServer 5.4.1 B1951 external MSSQL 2008 r2
Windows 2008 r2 | 2 x Intel Xeon E5-2650v2 | 64 Go DDR3 | 2 x Intel SSD 600go
