Add a common message at the bottom of the mails
FAWTS
Post by FAWTS » 2005-06-24 00:58
Is it possible to ask to hMailServer for adding a message at the end of the mails sent from him like :
Post thanks to hMailServer
Analyse thanks to ClamWin, no virus found in this mail
And if it is possible, how to do it ?
Thank You
FAWTS
FAWTS
Post by FAWTS » 2005-06-24 02:27
I found a way via SquirrelMail.
Open the compose page compose.php in the src/ folder.
Go to line 366 (
$body = explode("\n", $body);
just before (but after the comment) add :
$body = $body . "\n\nyour text\n" ;
And it works!!!
But this is a solution only if everybody use SquirrelMail, not a mail software as Thunderbird :cry: So if you have a better solution, I am waiting for it! :lol:
FAWTS
Bram
Post by Bram » 2005-06-24 09:14
This question is asked ofter before and it is also a feature request. It can in version 4.0 accomplished by vbscripting.
(http://www.hmailserver.com/forum/viewtopic.php?t=1413)
hmailserver 4.3 (242 Live)
hmailserver 5.0 (605 Test)
Windows 2003
MSSQL
ASSP 1.3.2
ClamAV (SOSDG)
http://www.realdesign.nl
FAWTS
Post by FAWTS » 2005-06-24 12:26
Thank you for your answer. I look for it in the forum, but did not find it, that is the problem when you're not good enough in Englush, you don't use the good key word...
Do you have an idea of date for a stable HMS V4 stable version?
Thank you.
FAWTS
Bram
Post by Bram » 2005-06-24 13:35
I don't know the dates. Martin is the developer and he decides when a realease is done. 4.0 is in beta for a few months now, so it souldn't take long. The biggest bugs are solved and het download counter for the 4.0 version keeps getting higher.
(I read a post that it would take days now, but can't find the post anymore)
Windows 2003
MSSQL
ASSP 1.3.2
ClamAV (SOSDG)
cmurphy54
Post by cmurphy54 » 2005-06-24 14:19
The issue isn't completely solved in v4 since the HTMLBody of a message is still read only.
This means that you can add a common message on the regular text body of a message, but messages that have html bodies could not have the message attached to the html email.
Here is where martin says "in a few days" as far as the hMailServer release.
Post by martin » 2005-07-25 17:19
In hMailServer 4.1, the HTMLBody property is read/write.
