can not delete emails
associates
Post by associates » 2011-01-17 03:26
I have a problem with deleting some of my emails from the deleted items folder. I use Squirrelmail to check/read my emails and just recently I am having an issue with deleting emails from the deleted items folder. By that I mean the emails are still there even after I have selected those I want to get rid of and clicked delete button from the squirrelmail.
I currently use hMailServer 5.3-B1617.
Thank you
Re: can not delete emails
Post by mattg » 2011-01-17 04:58
Squirelmail has a 'purge' link.
If you 'check mail' you will see a 'purge' beside the 'deleted items' folder.
Typically, for most IMAP clients delete just marks a message for deletion, not actually deletes the item. Purge is used to actually delete the message
