associates
- Normal user
Post
by associates » 2010-07-09 02:58
I was wondering if I could get some help here. I have been using a normal PC as the mail server and recently decided to get myself a proper server to run 24x7 as the Mail Server. It does not come with any OS, however it needs at least Windows Server or Linux OS.
I decided to have a go with Ubuntu Server OS on the new Server. This means that I will no longer be able to use hMailServer as my favorite mail server
. I have been using hMailServer for the last three years with no drama and continue to be happy with it. I would like to say "A big Thank You" to Martin and whoever takes part in developing or maintaining this fantastic Mail Server.
Anyway, get to the point - I have been thinking of using PostFix as the Mail Server. My question is I wonder how to move all the email messages across from hMailServer to PostFix. By the way, I have been using IMAP all along. And I choose to use MailDir as the mail format with Postfix.
Thank you in advance
- Developer
Post
by Bill48105 » 2010-07-09 03:07
Bummer to see you go.
Perhaps you should install & play with the other mail servers you are considering before you make the decision to say bye to hmail. I've tested about every mail server out there & although nix ones are common wow are they a PITFA to setup & mantain.. Definitely something to consider!
As far as your question, people use imapcopy to move mail between accounts:
http://home.arcor.de/armin.diehl/imapcopy/imapcopy.html
Or if you are handy, the IMAP functions in PHP are pretty handy.. That's the method I've used in moving messages between servers.
associates
- Normal user
Post
by associates » 2010-07-09 03:49
Thank you Bill for your reply.
No, I have not yet stopped using hMailServer for now. I am still playing with other Mail Servers just to get a feel about them as sugggested by you - Obviously, the servers that run on Ubuntu Server OS.
All right, I am going to try out the imapcopy. However, am not sure if this imapcopy would only work depending on the type of the mail formats such as Maildir or Mbox or would it work just fine regardless of a different kind of Mail formats. Do you know this by any chance?
Anyway, I can try this out myself
Thanks a lot
- Moderator
Post
by mattg » 2010-07-09 04:01
IMAPcopy just connects to both servers using standard IMAP protocols I think. It doesn't matter what their back end is
cheekybuddha
- New user
Post
by cheekybuddha » 2013-02-28 18:02
Sorry to jump in on this old thread.
I am looking to replace my old windows box that I use as a server with a linux box and so too must bid farewell to hMailServer.
Can anyone tell me whether the methods described above for migration preserve the SENT/REPLIED/FORWARDED statuses of emails and conversation threads, or is this info lost?
Thanks in advance for any insight (and please let me know if I should start a new thread instead)
d
Caspar
- Senior user
Post
by Caspar » 2013-03-04 10:23
You can get any information from the database, should you have a migration tool that can read out databases or backup files of those you should be able to manage.
- Moderator
Post
by mattg » 2013-03-04 11:27
Actually, I don't believe that hMailserver handles conversations at all.
If you have conversation threading at the moment using hMailserver then your mail client is handling that.
Depends on how many accounts etc, but perhaps the easiest is to just use a mail client and connect to both servers, and drag 'n drop all messages and folders. That should keep all existing flags too.
How many accounts?
Which mail client do you use?
