can not send email out
associates
Post by associates » 2010-07-07 02:06
I am having an issue with sending emails out from hMailServer 5.3-B1617. The following information is obtained from diagnostic tool. I hope with the attached diagnostic file, it would help you to help me out.
Test: Collect server details
hMailServer version: hMailServer 5.3-B1617
Database type: MySQL
Test: Test IPv6
IPv6 support is not available in operating system.
Test: Test outbound port
Trying to connect to TCP/IP address 83.169.11.240 on port 25.
Test: Test MX records
Trying to resolve MX records for mycompany.com.au...
Host name found: www.mycompany.com.au
Host name found: mx2.mailhop.org
Test: Test local connect
Connecting to TCP/IP address in MX records for local domain domain mycompany.com.au...
Trying to connect to host www.mycompany.com.au...
Trying to connect to TCP/IP address 124.150.106.149 on port 25.
Connected successfully.
BTW, I have set the port forwarding (HTTP-80, ASSP-25, SMTP-25, IMAP-143) to this PC machine on the modem router. It still does not want to send out. I do not know what else I am missing out here.
Thank you in advance
Re: can not send email out
Post by Bill48105 » 2010-07-07 02:22
Do you know if your ISP blocks outbound port 25? (Common thing ISP's do to stop spambots) Simplest way to check is ask them but you can try TELNET to port 25 on other mail servers you find although the diagnostics essentially does that with the hmailserver.com server..
Otherwise I'd look for a firewall (either a software based one on the hmail server or hardware one in your or your ISP's router..)
associates
Post by associates » 2010-07-07 02:53
Hi Bill,
Thank you for your reply.
Yes, my ISP is blocking the port 25. I have decided to use their mail server as our SMTP relayer. The emails sitting in the queue have slowly gone out now.
Thanks once again for your assistance.
