trouble with autoban
westdam
Post by westdam » 2010-05-24 09:00
hi guys
i've got a strange error with autoban on a .1769 stable release.
i've got a hmailserver fully installed, working and configured correctly.on the same machine there's a roundcube installation working and configured correctly.
i've got 3 ip ranges set up.
internet (same as default): priority 10 accept delivery from ext to local, local to local, local to external but not external to external. needs authentication from local to ext, local to local, and for security reason external to external ( if someone can "spoof" ip address i've thought ) . external to local is NOT checked of course. antispam and anvirus is checked.
My computer (localhost): priority 99 , accept delivery from ALL , require auth from local to external, external to external, local to local. antivirus is checked, antispam is unchecked.
LAN (my lan ) : as mycomputer priority 30
autoban is ACTIVE.
autoban lockdown localhost due to too much invalid login.
why???
westdam
Re: trouble with autoban
Post by westdam » 2010-05-24 09:26
sorry missed a thing : the login is done on roundcube webmail installed on the same machine.
the account is the same ( info@domain ) and block localhost ip address.
cant figure out why. right now i've disabled autoban.
Post by mattg » 2010-05-24 10:14
if there is a autoban with a prioity of 20 and another IP range coving the same IP with a hogher priority the higher priority should just overrule the Autoban IP.
Did the Autoban Range actually prevent connections from Localhost?
Post by ^DooM^ » 2010-05-24 10:48
Can you show roundcube connections in the log being denied access?
westdam
Post by westdam » 2010-05-24 13:41
ok, i'll try tro reproduce it.
right now autoban is disabled. so i've to wait for the logs.
yeah the localhost is HIGHER ( priority 99 ) than the autoban range.(20)
